Best NAS device, Expert recommendations to choose
I researched the best NAS devices to find the perfect solution for reliable storage, media streaming and personal cloud use at home or in a homelab. After reading expert reviews and community discussions from trusted tech sources, two models consistently stand out as top-rated recommendations:
UGREEN NAS DXP6800 Pro 6-Bay Desktop NAS
https://www.amazon.com/UGREEN-DXP6800-Pro-Attached-Diskless/dp/B0D22HN6PT/
Synology DS225+ Private Cloud Media Server**
https://www.amazon.com/Synology-2-Bay-DiskStation-DS225-Diskless/dp/B0FB7KQLR1/
The UGREEN NAS DXP6800 Pro is a high-performance system powered by an Intel i5 1235U 10-core CPU with 8GB DDR5 RAM, making it ideal for demanding workloads like virtualization, high-speed file transfers, and media processing. It features dual 10GbE ports, multiple M.2 NVMe slots, and a built-in SSD for the operating system. This makes it a great choice for advanced users who want powerful hardware and future-proof networking capabilities.
On the other hand, the Synology DS225+ focuses more on ease of use and a polished software ecosystem. It is designed for seamless media streaming, automatic backups, and file sharing. Synology’s DSM software is widely regarded as one of the best NAS operating systems, making it perfect for beginners or users who want a stable and user-friendly experience without much technical setup.
However, I am having trouble deciding which one is best for my needs. I am mainly looking for a NAS that offers reliable performance, easy management, good media streaming capabilities, and long-term value. I also care about power efficiency and upgrade flexibility.
Does anyone here have experience with either of these devices? I would love to hear your thoughts or recommendations before I buy.
Thanks in advance
Easy management is more of a knowledge level of how to use TrueNAS and how to troubleshoot computer issues when they occur. Also, not jumping to conclsions too fast.
Honestly, I’m not sure how you ended up choosing between two such different devices :smile:
But… the Sinology just come with 2gb ram, not supports more than 6 at all… and are you sure you can install Truenas on it?
The Ugreen has 8gb, that are quite the minimum to run Truenas, but really far for talk about virtualization and demanding workloads…
Or you just not interested on Truenas at all?
I would use neither to run TrueNAS. And if you do not intend to run TrueNAS, you are in the wrong forum.
Could be helpful to expand on that reply to help with OP out to understand why these wouldn’t be suitable to run TrueNAS?
Other than the fact that OP looks like an AI bot, the reason’s already been given for the Synology: its maximum RAM capacity is 6 GB, and TrueNAS requires 8 GB RAM minimum. The UGREEN is fine; though I’m not currently running TrueNAS on it, I did for about a year. Its RAM is expandable, I think up to 64 GB. The onboard 10 GbE NICs aren’t the greatest, but they work. You won’t be able to use the Thunderbolt ports AFAIK. It doesn’t support ECC RAM though.
@dan Did you switch back to UGOS?
No, I’ve never used UGOS. I’m not using that system right now.
