Can CP1000AVRLCDA UPS work on Truenas scale?
I want buy this UPS CP1000AVRLCDA,but i just see Cyber Power Systems ups 2 CP1350AVRLCD USB (usbhid-ups) and CP1500AVRLCD driver,can i use these driver for CP1000AVRLCDA?
Thanks!
Which driver does that ups need? if its the usbhid-ups then you can choose any listed vendor that uses that driver and it should work. when i got my cyberpower ups it wasn’t listed initially so i just chose the same driver von apc and the ups would work.
If you purchase the ups and connect it to truenas, you can check which driver the ups expects by dropping to the shell or connect via ssh and use nut-scanner -U to find out the driver your ups wants.
