Channels DVR Storage Location
I have been struggling with Channels DVR for quite a while now. I have an instance running under Portainer but I have no idea where my recording’s are being saved. I had to resort to Portainer because I was unable to add a new TVE source when using the Truenas App.. The other day I was able to ad my Hulu account. I pointed the config storage /mnt/JAD01-Pool/app_data/channels_dvr2. Pointed the storage for recording to /mnt/JAD01-Pool/DVR_Recordings. The issue is during the initial setup my storage location is not listed. I was able to get an instance under Dockge installed in hosted mode & my storage location did show up this time. However, no folders are created & nothing is saved there. Today I tried to reinstall channels in host mode again using the app catalog. Today it will not even install, I get an error. This must be a new feature the newest update the appeared today.
Can someone please help me figure out what is going on? I shouldn’t be this difficult but apparently it is. I just want the ability to see & move my recordings around.
I am still on 25.04.2.6
EFAULT] Failed to render compose templates: Traceback (most recent call last): File “/usr/bin/apps_render_app”, line 33, in sys.exit(load_entry_point(‘apps-validation==0.1’, ‘console_scripts’, ‘apps_render_app’)()) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py”, line 48, in main render_templates_from_path(args.path, args.values) File “/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py”, line 19, in render_templates_from_path rendered_data = render_templates( ^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/catalog_templating/render.py”, line 31, in render_templates rendered_templates[i.name] = env.get_template(i.name).render( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/jinja2/environment.py”, line 1301, in render self.environment.handle_exception() File “/usr/lib/python3/dist-packages/jinja2/environment.py”, line 936, in handle_exception raise rewrite_traceback_stack(source=source) File “/mnt/.ix-apps/app_configs/channels-tn/versions/1.0.17/templates/docker-compose.yaml”, line 4, in top-level template code {% do tpl.funcs.fail(“The TV Everywhere image requires that the user and group are set to 0 (root)”) %} ^^^^^^^^^^^^^^^^^^^^^^^^^ File “/mnt/.ix-apps/app_configs/channels-tn/versions/1.0.17/templates/library/base_v2_1_65/functions.py”, line 46, in _fail raise RenderError(message) base_v2_1_65.error.RenderError: The TV Everywhere image requires that the user and group are set to 0 (root)
More info…
I’m getting the same sort of error just trying to install the app from the appstore using the version suggested in this post. I’ve tried looking into permissions but have not resolved what is happening. Did you ever resolve this?
I had it working 2 to 3 weeks ago. I have had it stopped because I cannot add a new TVE source like Hulu. I have another instance working on a Win10 VM. Today though when I tried updating the Truenas app it just errored out. They keep breaking & this has been going on for 2 plus years.
