Convert 2 disks from stripe to mirror
disk is gone! should i wipe it before extending the pool?
    NAME                                          STATE     READ WRITE CKSUM
    Spare                                         ONLINE       0     0     0
      gptid/90b7d36c-2f38-11ea-8442-0cc47a7558b5  ONLINE       0     0     0
I think the GUI does that automatically when you select it as a the disk to “Extend” the current disk with.
Before signing back into the GUI, restart the middleware while in SSH:
service middlewared restart
Then sign into the GUI.
Then “Extend” the device gptid/90b7d36c-2f38-11ea-8442-0cc47a7558b5 and choose the newly freed disk. (You might not see the GPTID shown in the GUI, but instead as ada0 or something.)
If it doesn’t work, you might first need to do a “Quick Wipe” of the freed disk from the Storage → Disks menu.
Oops, I took off ahead of you, did not do the middlewared restart, but the disks are mirrored and the resilver is in process!! thanks for your help!!!
I’ve got several truenas housekeeping tasks on my list including upgrading to Scale over the holidays (yikes!) and I thought this task was going to be the easiest!
You’re not done until it finishes and results in zero errors.
strange…
..should have worked via GUI too… (Version: TrueNAS-13.0-U6.8)
got it! it’ll be another hour+ and headed out of the house now. will update you tonite!
I’m on U4. must’ve been added in U6?
I would be surprised… but it’s not impossible…
I really can’t say… I haven’t yet had the need to remove a vdev (a single drive “stripe”) from a pool that has two vdevs (single drive “stripe”).
No known data errors. Case closed! :+1: :+1:
Not yet.
You need to remove the platters from inside the hard drives and place them under an electron microscope. Confirm each and every bit. When you’re done, we’ll be one step closer to concluding this case.
Bad timing! My electron microscope just went into the shop for calibration. Should be back Friday. I’ll update you then!
