truenas:~$ sudo smartctl -x /dev/sdf
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.44-debug+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: ST16000NT001-3LV101
Serial Number: ZRS0YY9B
LU WWN Device Id: 5 000c50 0e80a00f5
Firmware Version: EN01
User Capacity: 16,000,900,661,248 bytes [16.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database 7.3/5625
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Dec 7 14:11:53 2024 EST
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Disabled
ATA Security is: Disabled, frozen [SEC2]
Write SCT (Get) Feature Control Command failed: Connection timed out
Wt Cache Reorder: Unknown (SCT Feature Control command failed)
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 567) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1400) minutes.
Conveyance self-test routine
SCT capabilities: (0x50bd) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-- 073 064 044 - 18683010
3 Spin_Up_Time PO---- 087 087 000 - 0
4 Start_Stop_Count -O--CK 100 100 020 - 49
5 Reallocated_Sector_Ct PO--CK 100 100 010 - 0
7 Seek_Error_Rate POSR-- 084 060 045 - 269855584
9 Power_On_Hours -O--CK 095 095 000 - 4450
10 Spin_Retry_Count PO--C- 100 100 097 - 0
12 Power_Cycle_Count -O--CK 100 100 020 - 58
18 Unknown_Attribute PO-R-- 100 100 050 - 0
187 Reported_Uncorrect -O--CK 100 100 000 - 0
188 Command_Timeout -O--CK 100 099 000 - 8590065666
190 Airflow_Temperature_Cel -O---K 064 049 000 - 36 (Min/Max 29/36)
192 Power-Off_Retract_Count -O--CK 100 100 000 - 31
193 Load_Cycle_Count -O--CK 100 100 000 - 256
194 Temperature_Celsius -O---K 036 051 000 - 36 (0 25 0 0 0)
197 Current_Pending_Sector -O--C- 100 100 000 - 0
198 Offline_Uncorrectable ----C- 100 100 000 - 0
199 UDMA_CRC_Error_Count -OSRCK 200 200 000 - 0
200 Multi_Zone_Error_Rate PO---K 100 100 001 - 0
240 Head_Flying_Hours ------ 100 253 000 - 4406 (201 205 0)
241 Total_LBAs_Written ------ 100 253 000 - 42720911687
242 Total_LBAs_Read ------ 100 253 000 - 6144000142197
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 5 Ext. Comprehensive SMART error log
0x04 GPL R/O 256 Device Statistics log
0x04 SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x08 GPL R/O 2 Power Conditions log
0x09 SL R/W 1 Selective self-test log
0x0a GPL R/W 8 Device Statistics Notification
0x0c GPL R/O 2048 Pending Defects log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x13 GPL R/O 1 SATA NCQ Send and Receive log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x24 GPL R/O 768 Current Device Internal Status Data log
0x2f GPL R/O 1 Set Sector Configuration
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa1 GPL,SL VS 160 Device vendor specific log
0xa2 GPL VS 16320 Device vendor specific log
0xa4 GPL,SL VS 160 Device vendor specific log
0xa6 GPL VS 192 Device vendor specific log
0xa8-0xa9 GPL,SL VS 136 Device vendor specific log
0xab GPL VS 1 Device vendor specific log
0xad GPL VS 16 Device vendor specific log
0xb1 GPL,SL VS 160 Device vendor specific log
0xb6 GPL VS 1920 Device vendor specific log
0xbe-0xbf GPL VS 65535 Device vendor specific log
0xc1 GPL,SL VS 8 Device vendor specific log
0xc3 GPL,SL VS 24 Device vendor specific log
0xc6 GPL VS 5184 Device vendor specific log
0xc7 GPL,SL VS 8 Device vendor specific log
0xc9 GPL,SL VS 8 Device vendor specific log
0xca GPL,SL VS 16 Device vendor specific log
0xcd GPL,SL VS 1 Device vendor specific log
0xce GPL VS 1 Device vendor specific log
0xcf GPL VS 512 Device vendor specific log
0xd1 GPL VS 656 Device vendor specific log
0xd2 GPL VS 10256 Device vendor specific log
0xd4 GPL VS 2048 Device vendor specific log
0xda GPL,SL VS 1 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Short offline Completed without error 00% 4294 -
# 2 Extended offline Aborted by host 90% 4221 -
# 3 Short offline Completed without error 00% 4127 -
# 4 Short offline Completed without error 00% 3959 -
# 5 Short offline Completed without error 00% 3791 -
# 6 Short offline Completed without error 00% 3622 -
# 7 Extended offline Interrupted (host reset) 00% 3586 -
# 8 Short offline Completed without error 00% 3456 -
# 9 Short offline Completed without error 00% 3288 -
#10 Short offline Completed without error 00% 3120 -
#11 Short offline Completed without error 00% 2952 -
#12 Extended offline Completed without error 00% 2856 -
#13 Short offline Completed without error 00% 2784 -
#14 Extended offline Interrupted (host reset) 10% 2177 -
#15 Extended offline Completed without error 00% 1395 -
#16 Extended offline Interrupted (host reset) 00% 1017 -
#17 Extended offline Completed without error 00% 848 -
#18 Extended offline Completed without error 00% 104 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 522 (0x020a)
Device State: Active (0)
Current Temperature: 36 Celsius
Power Cycle Min/Max Temperature: 29/36 Celsius
Lifetime Min/Max Temperature: 24/52 Celsius
Under/Over Temperature Limit Count: 0/0
SMART Status: 0xc24f (PASSED)
Vendor specific:
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 4 minutes
Temperature Logging Interval: 59 minutes
Min/Max recommended Temperature: 10/40 Celsius
Min/Max Temperature Limit: 5/60 Celsius
Temperature History Size (Index): 128 (8)
Index Estimated Time Temperature Celsius
9 2024-12-02 09:10 39 ********************
10 2024-12-02 10:09 39 ********************
11 2024-12-02 11:08 39 ********************
12 2024-12-02 12:07 42 ***********************
13 2024-12-02 13:06 43 ************************
14 2024-12-02 14:05 43 ************************
15 2024-12-02 15:04 41 **********************
16 2024-12-02 16:03 41 **********************
17 2024-12-02 17:02 41 **********************
18 2024-12-02 18:01 43 ************************
19 2024-12-02 19:00 43 ************************
20 2024-12-02 19:59 41 **********************
21 2024-12-02 20:58 40 *********************
22 2024-12-02 21:57 40 *********************
23 2024-12-02 22:56 42 ***********************
24 2024-12-02 23:55 43 ************************
25 2024-12-03 00:54 40 *********************
... ..( 2 skipped). .. *********************
28 2024-12-03 03:51 40 *********************
29 2024-12-03 04:50 39 ********************
30 2024-12-03 05:49 40 *********************
31 2024-12-03 06:48 42 ***********************
32 2024-12-03 07:47 43 ************************
... ..( 3 skipped). .. ************************
36 2024-12-03 11:43 43 ************************
37 2024-12-03 12:42 44 *************************
... ..( 2 skipped). .. *************************
40 2024-12-03 15:39 44 *************************
41 2024-12-03 16:38 43 ************************
42 2024-12-03 17:37 43 ************************
43 2024-12-03 18:36 44 *************************
44 2024-12-03 19:35 43 ************************
... ..( 5 skipped). .. ************************
50 2024-12-04 01:29 43 ************************
51 2024-12-04 02:28 42 ***********************
... ..( 12 skipped). .. ***********************
64 2024-12-04 15:15 42 ***********************
65 2024-12-04 16:14 41 **********************
66 2024-12-04 17:13 42 ***********************
69 2024-12-04 20:10 42 ***********************
70 2024-12-04 21:09 43 ************************
71 2024-12-04 22:08 42 ***********************
72 2024-12-04 23:07 42 ***********************
73 2024-12-05 00:06 40 *********************
74 2024-12-05 01:05 41 **********************
75 2024-12-05 02:04 40 *********************
76 2024-12-05 03:03 41 **********************
77 2024-12-05 04:02 42 ***********************
78 2024-12-05 05:01 41 **********************
79 2024-12-05 06:00 41 **********************
80 2024-12-05 06:59 41 **********************
81 2024-12-05 07:58 40 *********************
82 2024-12-05 08:57 40 *********************
83 2024-12-05 09:56 40 *********************
84 2024-12-05 10:55 41 **********************
85 2024-12-05 11:54 42 ***********************
86 2024-12-05 12:53 41 **********************
87 2024-12-05 13:52 42 ***********************
88 2024-12-05 14:51 42 ***********************
89 2024-12-05 15:50 41 **********************
90 2024-12-05 16:49 40 *********************
91 2024-12-05 17:48 40 *********************
92 2024-12-05 18:47 40 *********************
93 2024-12-05 19:46 41 **********************
94 2024-12-05 20:45 43 ************************
98 2024-12-06 00:41 43 ************************
99 2024-12-06 01:40 40 *********************
100 2024-12-06 02:39 42 ***********************
101 2024-12-06 03:38 43 ************************
102 2024-12-06 04:37 40 *********************
103 2024-12-06 05:36 39 ********************
104 2024-12-06 06:35 40 *********************
105 2024-12-06 07:34 40 *********************
106 2024-12-06 08:33 39 ********************
107 2024-12-06 09:32 40 *********************
108 2024-12-06 10:31 43 ************************
109 2024-12-06 11:30 43 ************************
110 2024-12-06 12:29 41 **********************
... ..( 4 skipped). .. **********************
115 2024-12-06 17:24 41 **********************
116 2024-12-06 18:23 38 *******************
117 2024-12-06 19:22 38 *******************
118 2024-12-06 20:21 35 ****************
119 2024-12-06 21:20 35 ****************
120 2024-12-06 22:19 39 ********************
121 2024-12-06 23:18 39 ********************
122 2024-12-07 00:17 38 *******************
... ..( 8 skipped). .. *******************
3 2024-12-07 09:08 38 *******************
4 2024-12-07 10:07 39 ********************
5 2024-12-07 11:06 ? -
6 2024-12-07 12:05 39 ********************
7 2024-12-07 13:04 ? -
8 2024-12-07 14:03 29 **********
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 58 --- Lifetime Power-On Resets
0x01 0x010 4 4450 --- Power-on Hours
0x01 0x018 6 42711745207 --- Logical Sectors Written
0x01 0x020 6 278925590 --- Number of Write Commands
0x01 0x028 6 6143994533276 --- Logical Sectors Read
0x01 0x030 6 607900464 --- Number of Read Commands
0x01 0x038 6 - --- Date and Time TimeStamp
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 4433 --- Spindle Motor Power-on Hours
0x03 0x010 4 4428 --- Head Flying Hours
0x03 0x018 4 256 --- Head Load Events
0x03 0x020 4 0 --- Number of Reallocated Logical Sectors
0x03 0x028 4 0 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x03 0x038 4 0 --- Number of Realloc. Candidate Logical Sectors
0x03 0x040 4 31 --- Number of High Priority Unload Events
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 2 --- Resets Between Cmd Acceptance and Completion
0x04 0x018 4 0 -D- Physical Element Status Changed
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 36 --- Current Temperature
0x05 0x010 1 39 --- Average Short Term Temperature
0x05 0x018 1 40 --- Average Long Term Temperature
0x05 0x020 1 51 --- Highest Temperature
0x05 0x028 1 33 --- Lowest Temperature
0x05 0x030 1 46 --- Highest Average Short Term Temperature
0x05 0x038 1 38 --- Lowest Average Short Term Temperature
0x05 0x040 1 42 --- Highest Average Long Term Temperature
0x05 0x048 1 39 --- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 60 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 5 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 207 --- Number of Hardware Resets
0x06 0x010 4 93 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
0xff ===== = = === == Vendor Specific Statistics (rev 1) ==
0xff 0x008 7 0 --- Vendor Specific
0xff 0x010 7 0 --- Vendor Specific
0xff 0x018 7 0 --- Vendor Specific
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x000a 2 3 Device-to-host register FISes sent due to a COMRESET
0x0001 2 0 Command failed due to ICRC error
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
Seagate FARM log (GP Log 0xa6) supported [try: -l farm]
Ad the 4 SSD connected to the NAS:
truenas:~$ sudo smartctl -x /dev/nvme3n1
Model Number: WDBRPG5000ANC-WRSN
Serial Number: 21441R806468
Firmware Version: 111130WD
PCI Vendor/Subsystem ID: 0x15b7
IEEE OUI Identifier: 0x001b44
Total NVM Capacity: 500,107,862,016 [500 GB]
Unallocated NVM Capacity: 0
Controller ID: 8215
NVMe Version: 1.3
Number of Namespaces: 1
Namespace 1 Size/Capacity: 500,107,862,016 [500 GB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: 001b44 8b4544493d
Local Time is: Sat Dec 7 14:12:21 2024 EST
Firmware Updates (0x14): 2 Slots, no Reset required
Optional Admin Commands (0x0017): Security Format Frmw_DL Self_Test
Optional NVM Commands (0x005f): Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Timestmp
Log Page Attributes (0x0e): Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg
Maximum Data Transfer Size: 128 Pages
Warning Comp. Temp. Threshold: 84 Celsius
Critical Comp. Temp. Threshold: 88 Celsius
Namespace 1 Features (0x02): NA_Fields
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 5.50W - - 0 0 0 0 0 0
1 + 3.50W - - 1 1 1 1 0 0
2 + 3.00W - - 2 2 2 2 0 0
3 - 0.0700W - - 3 3 3 3 4000 10000
4 - 0.0035W - - 4 4 4 4 4000 40000
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 2
1 - 4096 0 1
=== START OF SMART DATA SECTION ===
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 41 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 67%
Data Units Read: 561,162,195 [287 TB]
Data Units Written: 424,488,634 [217 TB]
Host Read Commands: 8,401,637,775
Host Write Commands: 10,538,824,184
Controller Busy Time: 15,221
Power Cycles: 103
Power On Hours: 15,518
Unsafe Shutdowns: 54
Media and Data Integrity Errors: 0
Error Information Log Entries: 1
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Error Information (NVMe Log 0x01, 16 of 256 entries)
No Errors Logged
Read Self-test Log failed: Invalid Field in Command (0x4002)
truenas:~$ sudo smartctl -x /dev/nvme0n1
Model Number: WDS500G3X0C-00SJG0
Serial Number: 203273803158
Firmware Version: 111110WD
Controller ID: 8215
NVMe Version: 1.3
Namespace 1 IEEE EUI-64: 001b44 8b491796ba
Local Time is: Sat Dec 7 14:12:34 2024 EST
4 - 0.0025W - - 4 4 4 4 4000 40000
0 + 512 0 2
1 - 4096 0 1
Temperature: 42 Celsius
Percentage Used: 99%
Data Units Read: 1,108,869,612 [567 TB]
Data Units Written: 523,283,326 [267 TB]
Host Read Commands: 14,992,402,456
Host Write Commands: 12,164,493,444
Controller Busy Time: 27,660
Power Cycles: 145
Power On Hours: 33,246
Unsafe Shutdowns: 72
No Errors Logged
truenas:~$ sudo smartctl -x /dev/nvme2n1
Model Number: Samsung SSD 980 PRO 1TB
Serial Number: S5P2NL0X113146T
Firmware Version: 5B2QGXA7
PCI Vendor/Subsystem ID: 0x144d
IEEE OUI Identifier: 0x002538
Total NVM Capacity: 1,000,204,886,016 [1.00 TB]
Controller ID: 6
NVMe Version: 1.3
Namespace 1 Size/Capacity: 1,000,204,886,016 [1.00 TB]
Namespace 1 Utilization: 65,769,283,584 [65.7 GB]
Namespace 1 IEEE EUI-64: 002538 b141a2790e
Local Time is: Sat Dec 7 14:12:42 2024 EST
Firmware Updates (0x16): 3 Slots, no Reset required
Optional NVM Commands (0x0057): Comp Wr_Unc DS_Mngmt Sav/Sel_Feat Timestmp
Log Page Attributes (0x0f): S/H_per_NS Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg
Warning Comp. Temp. Threshold: 82 Celsius
Critical Comp. Temp. Threshold: 85 Celsius
0 + 8.49W - - 0 0 0 0 0 0
1 + 4.48W - - 1 1 1 1 0 200
2 + 3.18W - - 2 2 2 2 0 1000
3 - 0.0400W - - 3 3 3 3 2000 1200
4 - 0.0050W - - 4 4 4 4 500 9500
0 + 512 0 0
Temperature: 35 Celsius
Percentage Used: 5%
Data Units Read: 20,476 [10.4 GB]
Data Units Written: 72,705,360 [37.2 TB]
Host Read Commands: 142,789
Host Write Commands: 428,286,079
Controller Busy Time: 7,241
Power Cycles: 82
Power On Hours: 1,004
Unsafe Shutdowns: 60
Error Information Log Entries: 0
Temperature Sensor 1: 35 Celsius
Temperature Sensor 2: 34 Celsius
Error Information (NVMe Log 0x01, 16 of 64 entries)
No Errors Logged
Read Self-test Log failed: Invalid Field in Command (0x002)
truenas:~$ sudo smartctl -x /dev/nvme1n1
Serial Number: S5P2NL0X113136N
Controller ID: 6
NVMe Version: 1.3
Namespace 1 IEEE EUI-64: 002538 b141a27904
Local Time is: Sat Dec 7 14:12:46 2024 EST
0 + 512 0 0
Percentage Used: 5%
Data Units Read: 12,761 [6.53 GB]
Data Units Written: 72,711,787 [37.2 TB]
Host Read Commands: 124,236
Host Write Commands: 428,311,674
Controller Busy Time: 7,162
Power Cycles: 82
Power On Hours: 1,005
Unsafe Shutdowns: 59
Temperature Sensor 1: 36 Celsius
Temperature Sensor 2: 36 Celsius
No Errors Logged
Here’s the Pool Status as we speak:
truenas:~$ sudo zpool status -v
[sudo] password for adminastered:
pool: RZ1_3x16TB
state: ONLINE
scan: scrub repaired 0B in 1 days 05:37:10 with 0 errors on Sat Nov 2 05:37:14 2024
NAME STATE READ WRITE CKSUM
RZ1_3x16TB ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
5b569614-3b3e-4b48-a410-04fd3cc66fca ONLINE 0 0 0
be781cec-f5d0-4401-8a75-aebdd0ab9242 ONLINE 0 0 0
dba821db-5293-47c6-a0d9-97b9537b1b71 ONLINE 0 0 0
raidz1-2 ONLINE 0 0 0
2b748709-ac9c-46bc-943b-dcebaf5b0a0a ONLINE 0 0 0
8e75bf79-64bc-4673-9a9e-b258394ab922 ONLINE 0 0 0
551e3e13-cca0-4b1a-8898-05cbc58d5716 ONLINE 0 0 0
logs
mirror-3 ONLINE 0 0 0
8de56c80-6e90-4d9a-8bff-0ed6c6114fe1 ONLINE 0 0 0
0e8d96f9-13aa-4242-a13a-42e32d2f5352 ONLINE 0 0 0
errors: No known data errors
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:16 with 0 errors on Sat Dec 7 03:45:17 2024
boot-pool ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
nvme2n1p3 ONLINE 0 0 0
nvme3n1p3 ONLINE 0 0 0
Just launched a Pool Scrub to see what will result from it
Does Upgrading the pool to the newest TrueNAS ZFS standard would help to mitigate anything?
The Scrub just finished, and no error message poped up
Good news!
I reactivated all services, one by one (SMB, NFS) and those are working
Things got complicated when I added back the pool to the Apps section : NAS server froze and restarted by itself. Whenever I restarted the NAS from there, it was stucked in a loop
It seems the Apps part of the NAS might be a major source of problem…
I successfully changed the Pool to a temporary Pool, but whenever I set back the problematic one in Apps settings, the server froze back and Boot Loop
Is there anything I can do to reset completely the Apps configs on the problematic Pool?
I might lose some configs, but at least I’ll be able to use it back as normal ![]()
Data Scrubbing didn’t showed any error message
While I was waiting for this to finish, a Bug Clerk on IX System’s Jira replied with that:
Thanks for the ticket but this is outside the scope of what we support. Your debug shows some intel kernel messages about power states and it seems there are other messages about amdgpu failing to send messages. This isn’t a wide-spread problem so this is more than likely related to your hardware/software. I’d suggest reaching out to our forums and/or ensuring you don’t have failing hardware and/or power state transitioning occurring.
The power state portion might be related to my UPS battery that needed to be changed ASAP. Did changed it in the meantime, but it’s possible that a power failure occurred before the corruption
Any clues on what can be done next?
Hello
Small but important update here:
- Docker apps became very buggy, hence I disabled it and stability is kinda back
- I discovered that the SLOG vdev might be the issue. Whenever I try to edit / remove it, the server crash
Is there a way to properly remove a SLOG from a Pool? A way fo “force” it since it’s really unstable?
Thanks!
