Currently unreadable (pending) sectors resulting in data corruption - Truenas Scale
Hey All,
After scouring the forums for a dozen hours around this issue I thought it’d be better to simply make a new thread.
Due to current life circumstances, I got into Truenas with a “0 budget mentality”. I was only going to use spare parts that I had lying around the house.
This means that my current setup is:
  • HP Elitedesk G1 Mini with a 500gb hdd (Boot-pool) and 16GB of ECC memory
  • 2 USB connected 4TB WD RED disks (CMR) [and yes I am aware usb is not recommended and I have read Arwen’s usb thread and I am fine with living with those problems]
I have these two disks setup into 2 pools:
  • wd_red_usb_data (referred as data from now on to save my fingers)
  • wd_red_usb_data_tooq (data_tooq)
data has an SMB share that I use and data_tooq is used as a backup pool.
I have hourly snapshots on both pools (expiry 2 weeks) and daily backups from data → data_tooq. I also have weekly scrubs setup. I can’t setup smart tests on usb devices as it is not supported by Truenas but I can run them throught the terminal (unfortunately I didn’t do it when setting up the machine.)
A couple weeks ago I started getting error messages on Currently unreadable (pending) sectors which I ignored :upside_down_face:
Last week I decided to get to the bottom of it and understood the following:
The disk used in data is failing SMART tests:
data SMART results
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.44-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke
Model Family: Western Digital Red (CMR)
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-WCC4E3YKXJ1Z
LU WWN Device Id: 5 0014ee 2b60650de
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
Device is: In smartctl database 7.3/5625
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Jan 14 02:36:21 2025 WET
SMART support is: Enabled
SMART Status not supported: Incomplete response, ATA output registers missing
Warning: This result is based on an Attribute check.
General SMART Values:
was never started.
been run.
data collection: (52980) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 530) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 1365
3 Spin_Up_Time 0x0027 182 174 021 Pre-fail Always - 7875
4 Start_Stop_Count 0x0032 082 082 000 Old_age Always - 18050
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 073 073 000 Old_age Always - 20429
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 096 096 000 Old_age Always - 4335
192 Power-Off_Retract_Count 0x0032 199 199 000 Old_age Always - 1449
193 Load_Cycle_Count 0x0032 188 188 000 Old_age Always - 36492
194 Temperature_Celsius 0x0022 114 090 000 Old_age Always - 38
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 13
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
1 Extended offline Completed: read failure 90% 20309 1587379024
2 Short offline Completed without error 00% 8334 -
3 Short offline Completed without error 00% 0 -
4 Short offline Completed without error 00% 0 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
The above only provides legacy SMART information - try ‘smartctl -x’ for more
and zfs complains about corrupted data:
  pool: wd_red_usb_data
 state: DEGRADED
        corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: https://ope  nzfs.gith ub.io/openzfs-docs/msg/ZFS-8000-8A
  scan: scrub repaired 0B in 02:39:18 with 11 errors on Mon Jan 13 21:30:49 2025
        NAME                                    STATE     READ WRITE CKSUM
        wd_red_usb_data                         DEGRADED     0     0     0
          03368416-c6c1-4e26-ae3d-453734067684  DEGRADED    21     0     0  too many errors
errors: 12 data errors, use '-v' for a list
These 12 data errors are 12 different files that zfs complains are corrupted.
12 in the live filesystem, but if I run zpool status -v it shows all the snapshots where the files have been saved (which is a lot with hourly snapshots.)
My question is:
Of the 12 files, 7 were added recently and 5 are older. Some of my older snapshots show only some of these files as corrupted.
e.g. snapshot from 2024-01-31_22-00 shows 4 corrupted files
but snapshot from 2025-01-01_23-00 shows 5 corrupted files
Now, from my understanding, since there were no changes to those files the snapshots won’t actually store any information so my data is lost on this disk correct?
For the older data it is not a problem as it should all be backed up in data_tooq However, my new data, which apparently immediately landed on bad sectors (my bad for not having run a smart test beforehand) is now lost, is that also correct?
Note: I have run 2 scrubs on data as a last resort but to no avail.
As next steps, I was considering the following:
  1. Smart test data_tooq’s drive and boot-pool (ongoing)
  2. Delete corrupted files from data
  3. Replicate all data from data to data_tooq (I was having trouble in the past with getting both pools data to match up.. replication was “successful” but data size wouldn’t match up. And since this error (unreadable sectors) popped up, replication was failing so I disabled it and need to restart.)
  4. Get rid of the bad disk
  5. Run a memtest for good measure (I didn’t test the machine at all before setting up truenas)
  6. I would like to make data_tooq the main pool and add a share to its copy of data while I try to find another 4TB drive somewhere :slight_smile:
  7. Add in the new drive and setup replication from data_tooq to it.
Is there any way to save my data that wasn’t backed up? Am I missing something from my next steps?
As a side note, assuming I do not want to move away from my elitedesk g1 mini and as such, move away from USB is there anything I can do to prevent situations like this? or is the daily replication as good as it gets?
Thanks a lot in advance!
P.S. I really did think this wouldn’t happen to me, guess you live and you learn some lessons :grin: thankfully this one was quite cheap!
Can you post the full output here? It will help answer your questions. You can sanitize it some if needed, but we’ll want to see what you are looking at.
Regardless of the other questions, if your drive is failing and has unreadable sectors, yeah, you’re going to want to prioritize that. Since the pool is in a precarious state and is physically in an unsupported configuration, you may want to consider leaving it off until you get the hardware issues sorted.
PS, the elitedesk 800 G1/2s/3s (SFF, non minis) all have two internal 3.5" slots. I’ve used these and older 8100/8200/8300s as FreeNAS systems in the past with great success… but USB enclosures… yeah man bad idea :stuck_out_tongue:
The whole purpose of redundant drives is to handle these types of situations, and when you only have one copy of your data, there is unfortunately no 2nd redundant copy to use for recovery.
As you surmise, a snapshot does NOT take a copy of your data - it only keeps the current copy when you delete it or overwrite it.
So, you need to accept that the errored files are gone for good and start focussing on saving the rest of your data on this disk by copying it off to a disk that is not failing.
Output of zpool status -v wd_red_usb_data
state: DEGRADED
see: link redacted for posting
    wd_red_usb_data/homestorage@auto-2025-01-01_17-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_17-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_17-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_17-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_20-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_20-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_20-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_20-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_20-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_20-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_20-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_20-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_20-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_20-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_23-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_23-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_23-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_23-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_16-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_16-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_16-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_16-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_16-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_16-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_16-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_16-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_16-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_16-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_16-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_16-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_16-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_16-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_10-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_10-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_10-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_10-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_10-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_10-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_10-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_10-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_10-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_10-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_13-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_13-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_13-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_13-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_13-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_13-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_13-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_13-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_13-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_13-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_00-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_00-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_00-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_00-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_20-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_20-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_20-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_20-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_20-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_20-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_20-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_20-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_20-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_20-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_20-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_20-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_20-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_21-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_21-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_21-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_21-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_11-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_11-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_11-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_11-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_11-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_11-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_11-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_11-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_11-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_11-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_16-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_16-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_16-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_16-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_16-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_16-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_16-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_16-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_16-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_16-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_03-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_03-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_03-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_03-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_22-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_22-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_22-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_22-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_02-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_02-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_02-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_02-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_02-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_02-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_02-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_02-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_02-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_02-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_04-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_04-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_04-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_04-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_21-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_21-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_21-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_21-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_21-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_21-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_21-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_21-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_21-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_21-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_00-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_00-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_00-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_00-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_03-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_03-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_03-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_03-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_03-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_03-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_03-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_03-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_03-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_03-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_09-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_09-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_09-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_09-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_09-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_09-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_09-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_09-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_09-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_09-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_01-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_01-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_01-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_01-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_07-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_07-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_07-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_07-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_23-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_23-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_23-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_23-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_23-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_23-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_23-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_23-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_23-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_23-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_23-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_23-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_23-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_23-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_23-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_23-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_23-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_23-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_23-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_23-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_04-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_04-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_04-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_04-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_04-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_04-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_04-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_04-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_04-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_04-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_09-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_09-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_09-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_09-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_09-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_09-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_09-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_09-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_09-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_09-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_02-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_02-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_02-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_02-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_09-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_09-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_09-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_09-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_13-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_13-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_13-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_13-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_13-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_13-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_13-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_13-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_13-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_13-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_04-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_04-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_04-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_04-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_07-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_07-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_07-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_07-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_07-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_07-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_07-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_07-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_07-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_07-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_19-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_19-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_19-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_19-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_09-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_09-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_09-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_09-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_15-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_15-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_15-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_15-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_15-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_15-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_15-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_15-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_15-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_15-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_20-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_20-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_20-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_20-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_12-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_12-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_12-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_12-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_12-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_12-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_12-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_12-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_12-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_12-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_00-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_00-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_00-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_00-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_00-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_00-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_00-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_00-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_00-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_00-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_15-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_15-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_15-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_15-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_22-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_22-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_22-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_22-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_22-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_22-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_22-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_22-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_22-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_22-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_16-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_16-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_16-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_16-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_14-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_14-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_14-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_14-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_14-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_14-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_14-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_14-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_14-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_14-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_01-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_01-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_01-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_01-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_01-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_01-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_01-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_01-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_01-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_01-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_04-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_04-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_04-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_04-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_04-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_04-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_04-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_04-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_04-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_04-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_17-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_17-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_17-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_17-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_20-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_20-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_20-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_20-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_17-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_17-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_17-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_17-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_02-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_02-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_02-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_02-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_02-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_02-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_02-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_02-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_02-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_02-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_05-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_05-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_05-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_05-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_05-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_05-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_05-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_05-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_05-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_05-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_17-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_17-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_17-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-04_17-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_19-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_19-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_19-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_19-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_23-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_23-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_23-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_23-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_10-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_10-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_10-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_10-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_10-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_10-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_10-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_10-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_10-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_10-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_18-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_18-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_18-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_18-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_22-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_22-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_22-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_22-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_11-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_11-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_11-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_11-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_11-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_11-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_11-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_11-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_11-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_11-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_04-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_04-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_04-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_04-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_04-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_04-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_04-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_04-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_04-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_04-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_19-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_19-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_19-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-02_19-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_01-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_01-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_01-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_01-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_03-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_03-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_03-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_03-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_12-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_12-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_12-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_12-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_12-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_12-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_12-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_12-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_12-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_12-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_13-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_13-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_13-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_13-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_19-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_19-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_19-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_19-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_19-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_19-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_19-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_19-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_19-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-06_19-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_06-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_06-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_06-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_06-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_14-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_14-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_14-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_14-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_14-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_14-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_14-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_14-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_14-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_14-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_05-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_05-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_05-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_05-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_08-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_08-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_08-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_08-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_08-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_08-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_08-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_08-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_08-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_08-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_02-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_02-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_02-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_02-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_15-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_15-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_15-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_15-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_15-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_15-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_15-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_15-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_15-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_15-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_08-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_08-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_08-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_08-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_10-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_10-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_10-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_10-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_10-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_10-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_10-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_10-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_10-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_10-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_08-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_08-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_08-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_08-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_17-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_17-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_17-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_17-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_17-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_17-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_17-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_17-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_17-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_17-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_15-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_15-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_15-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_15-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_13-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_13-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_13-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_13-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_12-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_12-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_12-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_12-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_12-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_12-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_12-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_12-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_12-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_12-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_10-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_10-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_10-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_10-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_05-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_05-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_05-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_05-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_18-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_18-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_18-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2024-12-31_18-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_19-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_19-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_19-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-03_19-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_16-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_16-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_16-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-01_16-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_03-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_03-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_03-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_03-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_03-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_03-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_03-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_03-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_03-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-07_03-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_18-00:/Media/20241229 New year's campervan trip/20241231_C1572.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_18-00:/Media/20230325 Weekend in Alentejo/MVI_1566.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_18-00:/Joana's Older Files/Workout/MVI_2225.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_18-00:/Media/Other/20240804_C0039.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_18-00:/Media/20241229 New year's campervan trip/20250101_C1633.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_18-00:/Media/20241229 New year's campervan trip/20241231_C1507.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_18-00:/Media/20241229 New year's campervan trip/20241231_C1513.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_18-00:/Media/20241229 New year's campervan trip/20241231_C1515.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_18-00:/Media/20241214 Weightlifting competition/20241214_C1403.MP4
    wd_red_usb_data/homestorage@auto-2025-01-05_18-00:/Media/20230325 Weekend in Alentejo/MVI_1528.MP4
(Had to delete part of the output as I got a “An error occurred: Body is limited to 64000 characters; you entered 113632.” error but it was just more snapshots anyway.)
For the life of me I can’t understand why the output isn’t sorted…
Also, you will notice the files only show up in snapshots and not in the live filesystem as I have already deleted them to prepare to replicate and get rid of the disk.
(But i still need to delete the snapshots for that to happen).
I’ll do this for now, thanks for the input!
Yup, I had imagined problems as user error, or stuff that would take longer than 24h to develop so I would be protected with the backup. Guess I am learning the hard way :slight_smile:
How bad of an idea is it to have a mirroring setup with 2 usb enclosures?
:saluting_face: Thanks for the clear assessment, I will do that!
Since they do all show in the snapshots, it’s possible that the files themselves are okay, but since this pool is a single disk in a USB enclosure that’s certainly not a given. When ZFS next goes to read them back you may encounter additional errors.
You’ll want to exfiltrate the data off this drive. Preferably with Replication to another pool that consists of at least 2 drives. Replication Tasks | TrueNAS Documentation Hub and then scrub scrub scrub on the new pool.
Suppose you have a mirror - and one USB-connected drive disconnects, and ZFS marks it as offline. The pool will keep going and you may not notice for some time - but meanwhile you write a file to it. Eventually you realise that the pool is degraded and you unplug and replug the offline USB disk, and now the 2nd drive needs to resilver (which might happen automatically but most likely you will need to make it happen).
This the consequences of a disconnect on one drive of a mirrored USB-connected pair are extremely heavy.
Fundamentally, an HP Elitedesk G1 Mini is NOT a good choice as a NAS server because of the extremely limited storage support that any mini-desktop like this has.
Let me know if you think I should open another thread, but I think the problem might be related.
I tried setting up a replication task to move data of this pool into the other healthy pool and my replication always fails with this error:
(...) Huge list of similar lines to below
send from @auto-2025-01-07_13-00 to wd_red_usb_data/homestorage@auto-2025-01-07_14-00 estimated size is 624B
send from @auto-2025-01-07_14-00 to wd_red_usb_data/homestorage@auto-2025-01-07_15-00 estimated size is 52.6K
send from @auto-2025-01-07_15-00 to wd_red_usb_data/homestorage@auto-2025-01-07_16-00 estimated size is 72.6K
total estimated size is 745G
warning: cannot send 'wd_red_usb_data/homestorage@auto-2024-12-31_13-00': Input/output error
cannot receive incremental stream: kernel modules must be upgraded to receive this stream.
Broken pipe.
From looking at the backups it seems that the replication has done around 807Gb out of 1.1TB. This would match up with the lattest batch of data that landed on the corrupted sectors which prompted this whole thing.
Could it be that the snapshots still point at the corrupted sectors and are causing this?
What would you advise in this situation?
Apparently I can’t add media, is there any easy way I can post my replication configs? They seem pretty sensible and normal though
