Disks with exported pools vdev offline
I am having an issue with my vdev being offline. It looks like my pool has been exported. It will not let me import the pool back. None of my drives have failed. All seem to be ok. I tried zpool import but it I get back “zsh: command not found: zpool”
Any help would be greatly appreciated.
Please post details on your current system. How are drives attached? Did anything happen lately with your system like power outages?
I believe there was a power outage.
My system is a dell poweredge 730xd
Intel Xeon E5-2690 v4
64gb mem
8 - 8 TiB drives raid z2 I believe
4 - 4 TiB drives raid z1
1 - 500 GiB boot drive
all drives are attached in the server caddies
Please run these in the Shell or console and paste the results back using preformatted text mode </> on toolbar or Ctrl+e. Each in their own window
This should show import status and drive info. Last three won’t all return results but will give your controller info. You just needed ‘sudo’ before.
sudo ZPOOL_SCRIPTS_AS_ROOT=1 zpool status -vLtsc lsblk,serial,smartx,smart
sudo zpool import
lsblk -bo NAME,LABEL,MAJ:MIN,TRAN,ROTA,ZONED,VENDOR,MODEL,SERIAL,PARTUUID,START,SIZE,PARTTYPENAME
sudo sas2flash -list
sudo sas3flash -list
sudo storcli show all
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:03:21 with 0 errors on Tue Jul 22 03:48:23 2025
        NAME        STATE     READ WRITE CKSUM  SLOW    size  vendor           model  serial  hours_on  pwr_cyc  temp  health  ata_err  realloc  rep_ucor  cmd_to  pend_sec  off_ucor
        boot-pool   ONLINE       0     0     0     -
          sdl3      ONLINE       0     0     0     0  465.3G    DELL  PERC H730 Mini       -         -        -     -       -        -        -         -       -         -         -  (trim unsupported)
errors: No known data errors
  pool: four_by_four
 state: ONLINE
  scan: scrub repaired 0B in 07:34:13 with 0 errors on Sun Jul 27 07:34:14 2025
        four_by_four  ONLINE       0     0     0     -
          raidz1-0    ONLINE       0     0     0     -
            sdm1      ONLINE       0     0     0     0    3.6T    DELL  PERC H730 Mini       -         -        -     -       -        -        -         -       -         -         -  (trim unsupported)
            sda1      ONLINE       0     0     0     0    3.6T    DELL  PERC H730 Mini       -         -        -     -       -        -        -         -       -         -         -  (trim unsupported)
            sdk1      ONLINE       0     0     0     0    3.6T    DELL  PERC H730 Mini       -         -        -     -       -        -        -         -       -         -         -  (trim unsupported)
            sde1      ONLINE       0     0     0     0    3.6T    DELL  PERC H730 Mini       -         -        -     -       -        -        -         -       -         -         -  (trim unsupported)
  pool: eight_by_eight
 state: FAULTED
status: The pool metadata is corrupted.
action: The pool cannot be imported due to damaged devices or data.
        The pool may be active on another system, but can be imported using
        the '-f' flag.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-72
        eight_by_eight                            FAULTED  corrupted data
          raidz2-0                                ONLINE
            64c6badb-0c14-4e44-95b1-36e4713fc147  ONLINE
            8ca41cd1-7afc-4bb2-93dc-adca6da91c4d  ONLINE
            b60983d1-5050-4716-9819-f3fe1d1e397f  ONLINE
            ed19256f-a428-46b3-97d5-bb2a0d9737f3  ONLINE
            57ad91e2-75b4-467d-909a-753f667f6413  ONLINE
            f433c55c-1c23-49a0-87f2-9945913f8a79  ONLINE
            2ed91d12-33a4-4d5c-9bfe-07f27354b06d  ONLINE
            54804e36-7cdd-4d9f-bb2b-49f641e49b98  ONLINE
NAME LABEL MAJ:MIN TRAN ROTA ZONED VENDOR MODEL SERIAL PARTUUID                               START          SIZE PARTTYPENAME
sda          8:0           1 none  DELL   PERC  002dd1                                              4000225165312
└─sda1
     four_by_four
             8:1           1 none                      8720c4cd-f393-490c-b91a-69342c852a90    4096 4000222020096 Solaris /usr & Apple ZFS
sdb          8:16          1 none  DELL   PERC  0034f8                                              8000987201536
└─sdb1
     eight_by_eight
             8:17          1 none                      8ca41cd1-7afc-4bb2-93dc-adca6da91c4d    4096 8000984056320 Solaris /usr & Apple ZFS
sdc          8:32          1 none  DELL   PERC  005eee                                              8000987201536
└─sdc1
     eight_by_eight
             8:33          1 none                      57ad91e2-75b4-467d-909a-753f667f6413    4096 8000984056320 Solaris /usr & Apple ZFS
sdd          8:48          1 none  DELL   PERC  00bca7                                              8000987201536
└─sdd1
     eight_by_eight
             8:49          1 none                      64c6badb-0c14-4e44-95b1-36e4713fc147    4096 8000984056320 Solaris /usr & Apple ZFS
sde          8:64          1 none  DELL   PERC  005b5a                                              4000225165312
└─sde1
     four_by_four
             8:65          1 none                      85d352cd-1c2a-49e4-bf12-8d1523470722    4096 4000222020096 Solaris /usr & Apple ZFS
sdf          8:80          1 none  DELL   PERC  00af90                                              8000987201536
└─sdf1
     eight_by_eight
             8:81          1 none                      b60983d1-5050-4716-9819-f3fe1d1e397f    4096 8000984056320 Solaris /usr & Apple ZFS
sdg          8:96          1 none  DELL   PERC  003e62                                              8000987201536
└─sdg1
     eight_by_eight
             8:97          1 none                      ed19256f-a428-46b3-97d5-bb2a0d9737f3    4096 8000984056320 Solaris /usr & Apple ZFS
sdh          8:112         1 none  DELL   PERC  002bf7                                              8000987201536
└─sdh1
     eight_by_eight
             8:113         1 none                      54804e36-7cdd-4d9f-bb2b-49f641e49b98    4096 8000984056320 Solaris /usr & Apple ZFS
sdi          8:128         1 none  DELL   PERC  00d0ea                                              8000987201536
└─sdi1
     eight_by_eight
             8:129         1 none                      f433c55c-1c23-49a0-87f2-9945913f8a79    4096 8000984056320 Solaris /usr & Apple ZFS
sdj          8:144         1 none  DELL   PERC  0098d7                                              8000987201536
└─sdj1
     eight_by_eight
             8:145         1 none                      2ed91d12-33a4-4d5c-9bfe-07f27354b06d    4096 8000984056320 Solaris /usr & Apple ZFS
sdk          8:160         1 none  DELL   PERC  00211c                                              4000225165312
└─sdk1
     four_by_four
             8:161         1 none                      517bd2d0-b610-4fe8-81b8-74cf0cf527a6    4096 4000222020096 Solaris /usr & Apple ZFS
sdl          8:176         1 none  DELL   PERC  00b005                                               499558383616
├─sdl1
│            8:177         1 none                      7c8d9a2e-a930-426e-b24a-18a00ff30488    4096       1048576 BIOS boot
├─sdl2
│    EFI     8:178         1 none                      e77d3a82-952a-4516-b230-d34ebfb7e05c    6144     536870912 EFI System
└─sdl3
     boot-pool
             8:179         1 none                      f12f2e81-97c8-4bc4-974b-8230ea36c2f6 1054720  499018350080 Solaris /usr & Apple ZFS
sdm          8:192         1 none  DELL   PERC  001135                                              4000225165312
└─sdm1
     four_by_four
             8:193         1 none                      ab29d7ae-049b-43a4-888e-2b0d5e697647    4096 4000222020096 Solaris /usr & Apple ZFS
LSI Corporation SAS2 Flash Utility
Version 20.00.00.00 (2014.09.18)
Copyright (c) 2008-2014 LSI Corporation. All rights reserved
        No LSI SAS adapters found! Limited Command Set Available!
        ERROR: Command Not allowed without an adapter!
        ERROR: Couldn't Create Command -list
        Exiting Program.
Avago Technologies SAS3 Flash Utility
Version 16.00.00.00 (2017.05.02)
Copyright 2008-2017 Avago Technologies. All rights reserved.
        No Avago SAS adapters found! Limited Command Set Available!
        Exiting Program.
CLI Version = 007.2807.0000.0000 Dec 22, 2023
Operating system = Linux 6.12.15-production+truenas
Status Code = 0
Status = Success
Description = None
Number of Controllers = 1
Host Name = truenas730
Operating System  = Linux 6.12.15-production+truenas
System Overview :
Ctl Model        Ports PDs DGs DNOpt VDs VNOpt BBU sPR DS EHS ASOs Hlth
  0 PERCH730Mini     8  13  13     0  13     0 Opt On  3  N      0 Opt
Ctl=Controller Index|DGs=Drive groups|VDs=Virtual drives|Fld=Failed
PDs=Physical drives|DNOpt=Array NotOptimal|VNOpt=VD NotOptimal|Opt=Optimal
Msng=Missing|Dgd=Degraded|NdAtn=Need Attention|Unkwn=Unknown
sPR=Scheduled Patrol Read|DS=DimmerSwitch|EHS=Emergency Spare Drive
Y=Yes|N=No|ASOs=Advanced Software Options|BBU=Battery backup unit/CV
Hlth=Health|Safe=Safe-mode boot|CertProv-Certificate Provision mode
Chrg=Charging | MsngCbl=Cable Failure
ASO :
Ctl
  0
Ctl=Controller Index|Cl=Cluster|MD=Max Disks|WC=Wide Cache|SS=Safe Store|FP=Fast Path
Re=Recovery|CR=CacheCade(Read)|RF=Reduced Feature Set|CO=Cache Offload
CW=CacheCade(Read/Write)|X=Not Available/Not Installed|U=Unlimited|T=Trial
|HA=High Availability |SSHA=Single server High Availability
Your disk controller is a hardware RAID type, I think, and not recommended for use with TrueNAS / ZFS. Thanks for all the data. I am hoping the experienced users will see and post now
What’s all the noise about HBA’s, and why can’t I use a RAID controller?
OK. Thank you!
I finally got it to import with sudo zpool import -F
Thank you for SmallBarky!
