Hi, I’m wondering if I’ll be able to “go back” to the release branch of electric eel once it is shipped if I upgrade to the RC2 version now?
RELEASE is ahead of RC2, so you’re not “going back” - you’re still “going forward.” 24.10.0 will let you upgrade directly from RC2.
If you’re using a nightly release though, you should plan on a config backup and reinstall.
Thanks for the clarification, I’ll upgrade with no worries then ![]()
