Hi everyone. First-timer here looking to setup a home server with a Wireguard VPN to access the NAS and one another machine on the network. I’ve gotten the VPN working but can’t seem to get NAT working to access the rest of the LAN. I’m a newcomer to Linux and this process has also revealed a lot of gaps in my networking knowledge, so there’s troubleshooting I’m not familiar with yet - please be kind if something obvious hasn’t been tried.
Goals:
- Setup a WG tunnel to my TrueNAS server
- Access SMB shares through the tunnel
- Access my desktop PC for Remote Desktop (Sunshine/Moonlight for now, maybe other methods later)
- Access virtual machines on Truenas
- Ideally, the IP addresses I use to talk to my server and my PC are the same whether I’m on the LAN or the VPN.
Setup:
- Truenas ElectricEel-24.10.2.4
- Reserved IP 10.0.0.2 for TrueNAS/WG, port forwarding 51820 to that address
- wg-easy (App Version 15.1.0; Version 2.0.7)
- wg subnet is 10.8.0.0/24. The endpoint is 10.8.0.1. Interface name is wg0. My laptop client is assigned 10.8.0.2
I’ve been following a tutorial on Reddit (the same steps I’ve observed in a few other forum posts, too), but the forums won’t let me post a link to it yet. The title is, " [Tutorial] Getting a WireGuard Server setup so the VPN client is treated as a local network client":
- No static routes set. I’m using a network bridge br0 and have made my network adapter, eno1, a member of the bridge.
- Sysctl: net.ipv4.ip_forward is set to 1
- Init/Shutdown Scripts (all are COMMAND, POSTINIT, enabled, 10-second timeout):
- nft add table ip nat
- nft ‘add chain ip nat prerouting { type nat hook prerouting priority 0 ; }’
- nft ‘add chain ip nat postrouting { type nat hook postrouting priority 100 ; }’
- nft ‘add rule nat postrouting iifname wg0 oifname br0 ip saddr 10.8.0.0/24 masquerade’
Outcomes:
- DDNS is working fine and connecting to the VPN is working fine. I can access the internet when tunneling. I’m only getting 200 Mbps, but I will look at that later.
- To mount SMB shares or access the TrueNAS webUI while tunneling, I have to use 10.8.0.1 rather than the 10.0.0.2 I use on my LAN. The hostname doesn’t appear in the Network tab of Finder.
- My PC is invisible and inaccessible.
Thoughts/Questions:
- I am wondering if the Init/Shutdown scripts aren’t being executed. I don’t know how to check for this.
- Are there other setup steps I have overlooked?
- Is my expectation of being able to use the same IP addresses to access LAN devices correct?
If I have overlooked important information, please let me know and I will collect it. It’s been a fun challenge learning about and setting up my first homelab and I’m looking forward to getting this piece solved.
Thank you, everyone!
