Generating LetsEncrypt Fails
Hey folks! Im trying to generate a Lets Encrypt cert
I got the Cloudflare integration done, but when I generate the Lets Encrypt cert, I see a dialog box flash, then close. When I look at the job history, there is nothing useful. I’'d post a screenshot, but I can’t?
My end goal is to setup TrueNAS + Nextcloud to act as a personal file server, photo storage, and all that stuff - but of course, nothing these days works properly without an SSL, and I’m too cheap to buy one.
Complete the tutorial you were invited to when you joined the forum. That will increase your trust level, and therefore your permissions here.
…and these days, there’s no reason you should. It’s a known bug, set to be fixed in SCALE, but probably never will be in CORE. See:
and:
and as an alternative, consider:
