One of my pools is degraded due to a faulty drive suddenly. I checked with smartctl -x /dev/sdf the S.M.A.R.T. values but need some help. It would be great if somebody can give a short yes/no/why answer to my thoughts and in which state my drive is. I know the SMART values but this output gives me headache. I know, it’s an very old drive (the last one of my first set), so replacing it is okay.
root@asgard[/mnt/folkwang/USERS/odin]# zpool status -v
pool: folkwang
state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
Sufficient replicas exist for the pool to continue functioning in
a
degraded state.
action: Replace the faulted device, or use 'zpool clear' to mark the device
repaired.
scan: scrub in progress since Thu Jul 17 06:24:45 2025
29.7T / 29.7T scanned, 21.6T / 29.7T issued at 1.15G/s
16.5M repaired, 72.68% done, 02:00:51 to go
NAME STATE READ WRITE CKSUM
folkwang DEGRADED 0 0
0
raidz2-0 DEGRADED 0 0
0
839e92ba-203b-4c54-b720-867236b72d72 ONLINE 0 0
0
844f478d-1f10-4379-afa5-9357b85a0c06 ONLINE 0 0
0
b889d54e-8f56-4489-ae05-6c0c60db7d67 ONLINE 0 0
0
2d00b6d5-b64f-46da-8e3a-c7431d98a68c ONLINE 0 0
0
d8819c42-41ee-4bef-aee6-b74cc7a21bd1 FAULTED 787 0
0 too many errors
5ce42eae-c01a-4959-95c9-b4ef6f39aee2 ONLINE 0 0
0
28083615-7136-4551-8600-cff938193015 ONLINE 0 0
0
6e4853d7-fec5-4ba5-9bf6-36f78f9f5494 ONLINE 0 0
0
errors: No known data errors
Faulted with 787 read errors > too many errors. Where is the threshold for TrueNAS to set the “too many” flag? And is my RAIDZ2 pool currently safe with another disk as parity (I guess “faulted” means out ot the pool?)
Can TrueNAS repair that or do I need a new disk and resilvering in general?
Anything useful from here on beside general disk information?
root@asgard[/mnt/folkwang/USERS/odin]# smartctl -x /dev/sdf
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.12.15-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD60EFRX-68L0BN1
Serial Number: WD-WX31DA5LHRFN
LU WWN Device Id: 5 0014ee 20cf518f7
Firmware Version: 82.00A82
User Capacity: 6,001,175,126,016 bytes [6.00 TB]
Rotation Rate: 5700 rpm
Device is: In smartctl database 7.3/5528
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Jul 17 13:09:40 2025 CEST
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
without error or no self-test has
ever
been run.
data collection: ( 1544) seconds.
command.
Self-test supported.
power-saving mode.
General Purpose Logging supported.Short self-test routine
Extended self-test routine
recommended polling time: ( 669) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
Interesting part but need some explanations.
In general: if my VALUE is < TRESH, my disk is dying.
Regarding the pool status with 787 read errors I would assume that ID 1 (Raw_Read_Error_Rate) with 36 is the cause. The classics #5, #196, #197, #198, #200 are all zero.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 36
3 Spin_Up_Time POS--K 198 198 021 - 9058
4 Start_Stop_Count -O--CK 099 099 000 - 1900
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 100 253 000 - 0
9 Power_On_Hours -O--CK 001 001 000 - 75556
10 Spin_Retry_Count -O--CK 100 100 000 - 0
11 Calibration_Retry_Count -O--CK 100 100 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 271
192 Power-Off_Retract_Count -O--CK 200 200 000 - 48
193 Load_Cycle_Count -O--CK 195 195 000 - 15905
194 Temperature_Celsius -O---K 112 108 000 - 40
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 100 253 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
Can I find something interesting here?
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb6 GPL,SL VS 1 Device vendor specific log
0xb7 GPL,SL VS 40 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 54 (device log contains only the most recent 24 errors)
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 54 [5] occurred at disk power-on lifetime: 10018 hours (417 days + 10 hours)
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 51 00 00 00 02 b7 41 71 c0 40 00 Error: WP at LBA = 0x2b74171c0 = 11664454080
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
61 01 60 00 00 00 02 b7 40 f8 98 40 00 6d+12:16:05.866 WRITE FPDMA QUEUED
60 00 10 00 18 00 02 ba 60 f6 10 40 00 6d+12:16:05.865 READ FPDMA QUEUED
60 00 10 00 10 00 02 ba 60 f4 10 40 00 6d+12:16:05.865 READ FPDMA QUEUED
60 00 10 00 00 00 00 00 00 0a 10 40 00 6d+12:16:05.865 READ FPDMA QUEUED
60 00 b8 00 08 00 02 b7 41 71 b0 40 00 6d+12:16:05.865 READ FPDMA QUEUED
Error 53 [4] occurred at disk power-on lifetime: 10018 hours (417 days + 10 hours)
40 -- 51 00 00 00 02 b7 41 6a b8 40 00 Error: WP at LBA = 0x2b7416ab8 = 11664452280
61 01 60 00 08 00 02 b7 40 f5 c8 40 00 6d+12:15:58.878 WRITE FPDMA QUEUED
60 07 e8 00 00 00 02 b7 41 69 c8 40 00 6d+12:15:58.877 READ FPDMA QUEUED
61 00 10 00 00 00 02 ba 60 f6 10 40 00 6d+12:15:58.877 WRITE FPDMA QUEUED
61 01 60 00 00 00 02 b7 40 f4 60 40 00 6d+12:15:58.876 WRITE FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 00 6d+12:15:58.875 READ LOG EXT
Error 52 [3] occurred at disk power-on lifetime: 10018 hours (417 days + 10 hours)
40 -- 51 00 00 00 02 b7 41 64 20 40 00 Error: WP at LBA = 0x2b7416420 = 11664450592
61 01 60 00 08 00 02 b7 40 f4 60 40 00 6d+12:15:51.890 WRITE FPDMA QUEUED
60 07 e8 00 00 00 02 b7 41 61 e0 40 00 6d+12:15:51.889 READ FPDMA QUEUED
61 00 10 00 00 00 02 ba 60 f4 10 40 00 6d+12:15:51.889 WRITE FPDMA QUEUED
61 01 60 00 00 00 02 b7 40 f2 f8 40 00 6d+12:15:51.888 WRITE FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 00 6d+12:15:51.888 READ LOG EXT
Error 51 [2] occurred at disk power-on lifetime: 10018 hours (417 days + 10 hours)
40 -- 51 00 00 00 02 b7 41 5d 68 40 00 Error: UNC at LBA = 0x2b7415d68
= 11664448872
60 07 e8 00 00 00 02 b7 41 59 f8 40 00 6d+12:15:44.902 READ FPDMA QUEUED
61 00 10 00 00 00 00 00 00 0a 10 40 00 6d+12:15:44.902 WRITE FPDMA QUEUED
61 01 60 00 00 00 02 b7 40 f1 90 40 00 6d+12:15:44.901 WRITE FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 00 6d+12:15:44.900 READ LOG EXT
61 01 60 00 00 00 02 b7 40 f1 90 40 00 6d+12:15:40.845 WRITE FPDMA QUEUED
Error 50 [1] occurred at disk power-on lifetime: 10018 hours (417 days + 10 hours)
40 -- 51 00 00 00 02 b7 41 52 10 40 00 Error: WP at LBA = 0x2b7415210 = 11664445968
60 07 e8 00 08 00 02 b7 41 52 10 40 00 6d+12:15:40.844 READ FPDMA QUEUED
61 01 60 00 00 00 02 b7 40 f0 28 40 00 6d+12:15:40.844 WRITE FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 00 6d+12:15:40.843 READ LOG EXT
61 01 60 00 08 00 02 b7 40 f0 28 40 00 6d+12:15:33.859 WRITE FPDMA QUEUED
Error 49 [0] occurred at disk power-on lifetime: 10018 hours (417 days + 10 hours)
40 -- 51 00 00 00 02 b7 41 4a 48 40 00 Error: WP at LBA = 0x2b7414a48 = 11664443976
60 00 10 00 18 00 02 ba 60 f6 10 40 00 6d+12:15:33.858 READ FPDMA QUEUED
60 00 10 00 10 00 02 ba 60 f4 10 40 00 6d+12:15:33.858 READ FPDMA QUEUED
60 00 10 00 08 00 00 00 00 0a 10 40 00 6d+12:15:33.858 READ FPDMA QUEUED
60 07 e8 00 00 00 02 b7 41 4a 28 40 00 6d+12:15:33.858 READ FPDMA QUEUED
Error 48 [23] occurred at disk power-on lifetime: 10018 hours (417 days +
10 hours)
40 -- 51 00 00 00 02 b7 41 43 08 40 00 Error: UNC at LBA = 0x2b7414308
= 11664442120
60 07 e8 00 08 00 02 b7 41 42 38 40 00 6d+12:15:26.871 READ FPDMA QUEUED
61 00 10 00 00 00 02 ba 60 f6 10 40 00 6d+12:15:26.871 WRITE FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 00 6d+12:15:26.870 READ LOG EXT
61 00 10 00 08 00 02 ba 60 f6 10 40 00 6d+12:15:19.885 WRITE FPDMA QUEUED
60 07 e8 00 00 00 02 b7 41 3a 50 40 00 6d+12:15:19.884 READ FPDMA QUEUED
Error 47 [22] occurred at disk power-on lifetime: 10018 hours (417 days +
10 hours)
40 -- 51 00 00 00 02 b7 41 3c d0 40 00 Error: WP at LBA = 0x2b7413cd0 = 11664440528
61 01 60 00 00 00 02 b7 40 ed 58 40 00 6d+12:15:19.883 WRITE FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 00 6d+12:15:19.883 READ LOG EXT
60 07 e8 00 08 00 02 b7 41 32 68 40 00 6d+12:15:15.382 READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Short offline Completed without error 00% 9440
# 2 Short offline Completed without error 00% 8697
# 3 Short offline Completed without error 00% 7978
# 4 Short offline Completed without error 00% 7235
# 5 Short offline Completed without error 00% 6565
# 6 Short offline Completed without error 00% 5822
# 7 Short offline Completed without error 00% 5078
# 8 Short offline Completed without error 00% 4359
# 9 Short offline Completed without error 00% 3616
#10 Short offline Completed without error 00% 2896
#11 Short offline Completed without error 00% 2153
#12 Short offline Completed without error 00% 1410
#13 Short offline Completed without error 00% 691
#14 Short offline Completed without error 00% 65483
#15 Short offline Completed without error 00% 64764
#16 Short offline Completed without error 00% 64022
#17 Short offline Completed without error 00% 63327
#18 Short offline Completed without error 00% 62584
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
Device State: Active (0)
Current Temperature: 40 Celsius
Power Cycle Min/Max Temperature: 37/44 Celsius
Lifetime Min/Max Temperature: 2/44 Celsius
Under/Over Temperature Limit Count: 0/0
Vendor specific:
00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (338)
Index Estimated Time Temperature Celsius
339 2025-07-17 05:12 42 ***********************
... ..( 3 skipped). .. ***********************
343 2025-07-17 05:16 42 ***********************
344 2025-07-17 05:17 41 **********************
... ..( 28 skipped). .. **********************
373 2025-07-17 05:46 41 **********************
374 2025-07-17 05:47 40 *********************
... ..( 21 skipped). .. *********************
396 2025-07-17 06:09 40 *********************
397 2025-07-17 06:10 41 **********************
... ..( 12 skipped). .. **********************
410 2025-07-17 06:23 41 **********************
411 2025-07-17 06:24 40 *********************
... ..( 30 skipped). .. *********************
442 2025-07-17 06:55 40 *********************
443 2025-07-17 06:56 38 *******************
... ..( 57 skipped). .. *******************
23 2025-07-17 07:54 38 *******************
24 2025-07-17 07:55 39 ********************
46 2025-07-17 08:17 39 ********************
47 2025-07-17 08:18 40 *********************
... ..( 5 skipped). .. *********************
53 2025-07-17 08:24 40 *********************
54 2025-07-17 08:25 41 **********************
... ..( 11 skipped). .. **********************
66 2025-07-17 08:37 41 **********************
67 2025-07-17 08:38 42 ***********************
... ..( 37 skipped). .. ***********************
105 2025-07-17 09:16 42 ***********************
106 2025-07-17 09:17 43 ************************
... ..( 81 skipped). .. ************************
188 2025-07-17 10:39 43 ************************
189 2025-07-17 10:40 44 *************************
... ..( 74 skipped). .. *************************
264 2025-07-17 11:55 44 *************************
265 2025-07-17 11:56 43 ************************
... ..( 61 skipped). .. ************************
327 2025-07-17 12:58 43 ************************
328 2025-07-17 12:59 42 ***********************
... ..( 9 skipped). .. ***********************
338 2025-07-17 13:09 42 ***********************
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 1 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 297 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 569931 Vendor specific
Best next steps? directly replacing the disk?
