Help with Disk Replacement
Hi
I have a faulted disk, and am trying to replace it. I have offlined the faulted disk and physically removed it.
When I plug in the new disk (a brand new disk), and click ‘Replace’, I get:
I have tried:
  • repartitioning the disk
  • reformatting the disk
I’ve looked up various posts but not sure if it’s the same problem and/or running into the same solutions as above.
Grateful if someone could help point me in the right direction for next steps to troubleshoot.
Many thanks
Have you ticked the box that says force during the replace procedure?
Is the new disk the same size / make / model as the old? If not can you detail the two different types.
Thanks
Blockquote
Yes, same Errno 5 (Input/output error) in both cases
Blockquote
Old Disk: Seagate Exos X16 10TB
New Disk: Seagate Exos X10 10TB
Check the label on the new disk vs old disk. Is the new disk with different formatting? What is the model number of the new disk.
I think this command will give all all the necessary info. Run this in the CLI and post the results back using Preformatted Text (</> on toolbar or Ctrl+e)
lsblk -bo NAME,LABEL,MAJ:MIN,TRAN,ROTA,ZONED,VENDOR,MODEL,SERIAL,PARTUUID,START,SIZE,PARTTYPENAME
Thanks
admin@server[~]$ lsblk -bo NAME,LABEL,MAJ:MIN,TRAN,ROTA,ZONED,VENDOR,MODEL,SERIAL,PARTUUID,START,SIZE,PARTTYPENAME
NAME        LABEL     MAJ:MIN TRAN   ROTA ZONED VENDOR   MODEL                   SERIAL           PARTUUID                                START           SIZE PARTTYPENAME
sda                     8:0   sata      1 none  ATA      ST10000NM001G-ZNW103    ZV1Z6P7F                                                       10000831348736
└─sda1      Storage     8:1             1 none                                                    eefdfe2b-4cf8-4999-9eb2-c4e7cd677ec8     4096 10000828203520 Solaris /usr & Apple ZFS
sdb                     8:16  sata      1 none  ATA      ST10000NM001G-ZNW103    ZNVZ4815                                                       10000831348736
└─sdb1      Storage     8:17            1 none                                                    d66ad027-8180-4fab-a0cf-dde23d04b5e7     4096 10000828203520 Solaris /usr & Apple ZFS
sdc                     8:32  sata      1 none  ATA      ST10000NM001G-ZNW103    ZV1Z79F5                                                       10000831348736
└─sdc1      Storage     8:33            1 none                                                    1b5a81dc-fc02-4da0-8df5-463fddee7260     4096 10000828203520 Solaris /usr & Apple ZFS
sdd                     8:48  sata      1 none  ATA      ST10000NM001G-ZNW103    ZNVZ4P7T                                                       10000831348736
└─sdd1      Storage     8:49            1 none                                                    6116cdab-5ae8-4e4d-ae99-3fb84de7c1d2     4096 10000828203520 Solaris /usr & Apple ZFS
sde                     8:64  sata      0 none  ATA      KINGSTON SUV400S37240G  50026B776605ACC7                                                 240057409536
├─sde1                  8:65            0 none                                                    e181aa02-e055-41e4-9919-3043fffe463d     4096        1048576 BIOS boot
├─sde2      EFI         8:66            0 none                                                    b060f12f-64a2-4c8c-b5f5-00f28508cac2     6144      536870912 EFI System
├─sde3      boot-pool   8:67            0 none                                                    06cb2b58-6360-447c-84f4-566336b9385d 34609152   222337506816 Solaris /usr & Apple ZFS
└─sde4                  8:68            0 none                                                    77d65fe6-5859-462c-9d86-d0c338ce8a9e  1054720    17179869184 Linux swap
  └─sde4              253:0             0 none        17179869184
sdf                     8:80  sata      1 none  ATA      ST10000NM0086-2AA101    ZA26Q2JT                                                       10000831348736
└─sdf1      Storage     8:81            1 none                                                    4edacb4f-2080-4e2a-b34f-93589bba28d9     4096 10000828203520 Solaris /usr & Apple ZFS
sdg                     8:96  sata      1 none  ATA      ST10000NM0016-1TT101    ZA23Z6Q4                                                       10000831348736
zd0                   230:0             0 none        68719493120
nvme0n1               259:0   nvme      0 none           Samsung SSD 990 PRO 2TB S6Z2NJ0TB38790R                                                 2000398934016
└─nvme0n1p1 Apps_VM   259:1   nvme      0 none                                                    11c5848b-8380-4e06-86ca-e8a4f3493f2f     4096  2000396747264 Solaris /usr & Apple ZFS
the new disk is sdg above. have removed the partition since.
the old disk formatting is the same as all the other disks under ‘Storage’ above.
last time when I tried it with the partition, Replace wouldn’t work because there’s a partition (understand this is a protective mechanism to prevent accidental deletion)
so right now I’m also stuck here as putting a partition and formatting seems to stop me from doing the Replace?
To update, I can’t access the SMB share - not sure why this is the case but SMB share has been very reliable until the attempted disk replacement.
In Windows, the TrueNas computer is detected on Network however can’t access it.
  • Have replaced the new disk with the old disk and it’s the same result
  • Have also tried rebooting the NAS, and restarting the SMB service and each of the SMB shares
The disks don’t have a problem as the external file hosting service (FileBrowser) still works. Looks like it’s the SMB service itself only?
Appreciate any pointers … urgently? Many thanks
Edit: appears to be a Windows issue if it helps, using a file explorer from my phone does appear to successfully access the SMB share
Edit: turns out it was a DNS resolution issue, opened up hostfile editor and cleared out various duplicates and conflicts … have no idea how that got there
Maybe a quick wipe to the new disk and then a reboot after that helps.
There could be remaining partition info on it that interfere somehow.
thanks
yea that was the first thought, but I can’t even wipe the disk right now :frowning:
admin@server[~]$ sudo parted /dev/sdg mklabel gpt
Warning: The existing disk label on /dev/sdg will be destroyed and all data on this disk will be lost. Do you want to continue?
Yes/No? y
Error: Input/output error during write on /dev/sdg
Otherwise the disk may have an error.
Can you try writing to this disk on another computer?
Or could there something write protect it on another level (HBA?) ?
Yes starting to heavily suspect this, and thanks for the affirmation. Have returned the disk for a replacement
I ran CrystalDiskMark on it and it said it’s ok. Not sure if CrystalDiskMark has any write operations in doing its assessment though.
What’s this? How does write protect work on a hard drive? Could you explain a bit further?
CrystalDiskMark does write test too in default setting. Do you have a screenshot of that run?
If this works the error has to be somewhere else.
Well there’s several level in theory where write locks could be.
HDD could be locked by itself: ATA security
HBA could prevent writes to HDD, depends on features, firmware, state and it’'s configuration.
OS (TrueNAS) could prevent writes for multiple reasons.
Does your HBA offer options to configure its ports or settings to it’s attached drives?
dmesg | grep -i 'sdg\|seagate\|warn\|error\|fail' could also offer insights in OS.
Thanks, unfortunately not, but this helps my understanding
Thanks, will update further once I get my hands on the new drive
Update: got the new disk and plugged it - same error :thinking:
No issues with the disk
I do notice that although CrystalDiskInfo detects the disk as 12TB, TrueNas detects it as 10TB - hopefully not related to the disk and more a function of the disk pool?
For reference, this is the old ‘Degraded’ disk
Appreciate any ideas
I got this:
admin@server[~]$ dmesg | grep -i 'sdg\|seagate\|warn\|error\|fail' dmesg: read kernel buffer failed: Operation not permitted
Try sudo dmesg | grep -i 'sdg\|seagate\|warn\|error\|fail'
thanks, got something per below. the output is more than the screen (and it’s exceeding the maximum allowable characters for a post at any rate), but let me know if there’s anything else I can do.
what does this mean?
I’ve searched ‘ATA bus error’, when I re-insert the old damaged hard drive there’s no such error so it can’t be the cables. I’ve tried inserting and re-inserting a few times and the cradle does lock in - so probably not due to bad seating?
[900611.871763] ata6.00: error: { ICRC ABRT }
[900611.873784] ata6.00: failed command: READ FPDMA QUEUED
                         res 43/84:01:06:4f:c2/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[900611.882976] ata6.00: error: { ICRC ABRT }
[900611.885494] ata6.00: failed command: READ FPDMA QUEUED
[900611.895044] ata6.00: error: { ICRC ABRT }
[900611.897382] ata6.00: failed command: READ FPDMA QUEUED
                         res 43/84:01:01:4f:c2/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[900611.905882] ata6.00: error: { ICRC ABRT }
[900611.908389] ata6.00: failed command: READ FPDMA QUEUED
                         res 43/84:00:c0:4e:7b/00:08:da:00:00/00 Emask 0x10 (ATA bus error)
[900611.917114] ata6.00: error: { ICRC ABRT }
[900611.919523] ata6.00: failed command: READ FPDMA QUEUED
                         res 43/84:00:00:4f:c2/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
[900611.929282] ata6.00: error: { ICRC ABRT }
[900628.741331] ata6.00: irq_stat 0x48000008, interface fatal error
[900628.743322] ata6.00: failed command: READ FPDMA QUEUED
[900628.751552] ata6.00: error: { ICRC ABRT }
[900628.753556] ata6.00: failed command: READ FPDMA QUEUED
                         res 43/84:01:00:4f:c2/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[900628.761592] ata6.00: error: { ICRC ABRT }
[900628.763720] ata6.00: failed command: READ FPDMA QUEUED
[900628.771977] ata6.00: error: { ICRC ABRT }
[900628.774005] ata6.00: failed command: READ FPDMA QUEUED
[900628.781943] ata6.00: error: { ICRC ABRT }
[900628.784244] ata6.00: failed command: READ FPDMA QUEUED
[900628.792233] ata6.00: error: { ICRC ABRT }
[900628.794202] ata6.00: failed command: READ FPDMA QUEUED
[900628.802661] ata6.00: error: { ICRC ABRT }
[900628.804649] ata6.00: failed command: READ FPDMA QUEUED
                         res 43/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[900628.812801] ata6.00: error: { ICRC ABRT }
[900628.814872] ata6.00: failed command: READ FPDMA QUEUED
[900628.823227] ata6.00: error: { ICRC ABRT }
[900630.538325] ata6.00: irq_stat 0x48000008, interface fatal error
[900630.540274] ata6.00: failed command: READ FPDMA QUEUED
[900630.548645] ata6.00: error: { ICRC ABRT }
[900630.550748] ata6.00: failed command: READ FPDMA QUEUED
[900630.558655] ata6.00: error: { ICRC ABRT }
[900630.560607] ata6.00: failed command: READ FPDMA QUEUED
[900630.568377] ata6.00: error: { ICRC ABRT }
[900630.570152] ata6.00: failed command: READ FPDMA QUEUED
[900630.577972] ata6.00: error: { ICRC ABRT }
[900630.580223] ata6.00: failed command: READ FPDMA QUEUED
[900630.588655] ata6.00: error: { ICRC ABRT }
[900630.590867] ata6.00: failed command: READ FPDMA QUEUED
[900630.598939] ata6.00: error: { ICRC ABRT }
[900630.600955] ata6.00: failed command: READ FPDMA QUEUED
[900630.608864] ata6.00: error: { ICRC ABRT }
[900630.611056] ata6.00: failed command: READ FPDMA QUEUED
[900630.618969] ata6.00: error: { ICRC ABRT }
[900630.621164] ata6.00: failed command: READ FPDMA QUEUED
[900630.629564] ata6.00: error: { ICRC ABRT }
[900630.631507] ata6.00: failed command: READ FPDMA QUEUED
[900630.639823] ata6.00: error: { ICRC ABRT }
[900630.642207] ata6.00: failed command: READ FPDMA QUEUED
[900630.650675] ata6.00: error: { ICRC ABRT }
[900649.671288] ata6.00: irq_stat 0x48000008, interface fatal error
[900649.673279] ata6.00: failed command: READ FPDMA QUEUED
[900649.681683] ata6.00: error: { ICRC ABRT }
[900649.684191] ata6.00: failed command: READ FPDMA QUEUED
[900649.693136] ata6.00: error: { ICRC ABRT }
[900649.695453] ata6.00: failed command: READ FPDMA QUEUED
[900649.704040] ata6.00: error: { ICRC ABRT }
[900649.706577] ata6.00: failed command: READ FPDMA QUEUED
[900649.715453] ata6.00: error: { ICRC ABRT }
[900649.717480] ata6.00: failed command: READ FPDMA QUEUED
[900649.725477] ata6.00: error: { ICRC ABRT }
[900649.727501] ata6.00: failed command: READ FPDMA QUEUED
[900649.735468] ata6.00: error: { ICRC ABRT }
[900650.970823] ata6.00: irq_stat 0x48000008, interface fatal error
[900650.972748] ata6.00: failed command: READ FPDMA QUEUED
[900650.980390] ata6.00: error: { ICRC ABRT }
[900650.982271] ata6.00: failed command: READ FPDMA QUEUED
[900650.990505] ata6.00: error: { ICRC ABRT }
[900650.992422] ata6.00: failed command: READ FPDMA QUEUED
[900651.000410] ata6.00: error: { ICRC ABRT }
[900651.002430] ata6.00: failed command: READ FPDMA QUEUED
[900651.011151] ata6.00: error: { ICRC ABRT }
[900651.013663] ata6.00: failed command: READ FPDMA QUEUED
[900651.022000] ata6.00: error: { ICRC ABRT }
[900651.023990] ata6.00: failed command: READ FPDMA QUEUED
[900651.032024] ata6.00: error: { ICRC ABRT }
[900651.034016] ata6.00: failed command: READ FPDMA QUEUED
[900651.041980] ata6.00: error: { ICRC ABRT }
[900651.043937] ata6.00: failed command: READ FPDMA QUEUED
[900651.052173] ata6.00: error: { ICRC ABRT }
[900653.460371] ata6.00: irq_stat 0x48000008, interface fatal error
[900653.463253] ata6.00: failed command: READ FPDMA QUEUED
[900653.474631] ata6.00: error: { ICRC ABRT }
[900653.477410] ata6.00: failed command: READ FPDMA QUEUED
[900653.488559] ata6.00: error: { ICRC ABRT }
[900653.491586] ata6.00: failed command: READ FPDMA QUEUED
[900653.503027] ata6.00: error: { ICRC ABRT }
[900653.505474] ata6.00: failed command: READ FPDMA QUEUED
[900653.513237] ata6.00: error: { ICRC ABRT }
[900653.515224] ata6.00: failed command: READ FPDMA QUEUED
[900653.524244] ata6.00: error: { ICRC ABRT }
[900653.526322] ata6.00: failed command: READ FPDMA QUEUED
[900653.534332] ata6.00: error: { ICRC ABRT }
[900653.536720] ata6.00: failed command: READ FPDMA QUEUED
[900653.545238] ata6.00: error: { ICRC ABRT }
[900653.547340] ata6.00: failed command: READ FPDMA QUEUED
[900653.556123] ata6.00: error: { ICRC ABRT }
[900653.558445] ata6.00: failed command: READ FPDMA QUEUED
[900653.566633] ata6.00: error: { ICRC ABRT }
[900659.075844] ata6.00: irq_stat 0x08000000, interface fatal error
[900659.078694] ata6.00: failed command: READ FPDMA QUEUED
                         res 40/00:01:01:4f:c2/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[900659.086410] ata6.00: failed command: READ FPDMA QUEUED
                         res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[900659.094017] ata6.00: failed command: READ FPDMA QUEUED
[900659.102090] ata6.00: failed command: READ FPDMA QUEUED
                         res 40/00:01:06:4f:c2/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[900659.109292] ata6.00: failed command: READ FPDMA QUEUED
                         res 40/00:00:00:4f:c2/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
[900659.117070] ata6.00: failed command: READ FPDMA QUEUED
                         res 40/00:01:00:4f:c2/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[900659.124642] ata6.00: failed command: READ FPDMA QUEUED
[900659.132391] ata6.00: failed command: READ FPDMA QUEUED
[900668.561610] ata6.00: irq_stat 0x48000008, interface fatal error
[900668.563598] ata6.00: failed command: READ FPDMA QUEUED
[900668.571076] ata6.00: error: { ICRC ABRT }
[900668.572988] ata6.00: failed command: READ FPDMA QUEUED
[900668.580793] ata6.00: error: { ICRC ABRT }
[900668.582776] ata6.00: failed command: READ FPDMA QUEUED
[900668.590484] ata6.00: error: { ICRC ABRT }
[900668.592205] ata6.00: failed command: READ FPDMA QUEUED
[900668.600348] ata6.00: error: { ICRC ABRT }
[900668.602165] ata6.00: failed command: READ FPDMA QUEUED
[900668.609549] ata6.00: error: { ICRC ABRT }
[900668.611382] ata6.00: failed command: READ FPDMA QUEUED
[900668.618939] ata6.00: error: { ICRC ABRT }
[900668.620958] ata6.00: failed command: READ FPDMA QUEUED
[900668.629088] ata6.00: error: { ICRC ABRT }
[900668.631089] ata6.00: failed command: READ FPDMA QUEUED
[900668.639156] ata6.00: error: { ICRC ABRT }
[900715.246658] ata6.00: irq_stat 0x48000008, interface fatal error
[900715.248637] ata6.00: failed command: READ FPDMA QUEUED
[900715.256853] ata6.00: error: { ICRC ABRT }
[900715.259185] ata6.00: failed command: READ FPDMA QUEUED
[900715.267570] ata6.00: error: { ICRC ABRT }
[900715.269493] ata6.00: failed command: READ FPDMA QUEUED
[900715.278637] ata6.00: error: { ICRC ABRT }
[900715.281034] ata6.00: failed command: READ FPDMA QUEUED
[900715.289337] ata6.00: error: { ICRC ABRT }
[900715.291560] ata6.00: failed command: READ FPDMA QUEUED
[900715.300202] ata6.00: error: { ICRC ABRT }
[900715.302170] ata6.00: failed command: READ FPDMA QUEUED
[900715.310133] ata6.00: error: { ICRC ABRT }
[900715.312191] ata6.00: failed command: READ FPDMA QUEUED
[900715.320040] ata6.00: error: { ICRC ABRT }
[900715.321976] ata6.00: failed command: READ FPDMA QUEUED
[900715.330101] ata6.00: error: { ICRC ABRT }
[900723.840973] ata6.00: irq_stat 0x48000008, interface fatal error
[900723.843222] ata6.00: failed command: READ FPDMA QUEUED
[900723.851599] ata6.00: error: { ICRC ABRT }
[900723.853627] ata6.00: failed command: READ FPDMA QUEUED
[900723.862246] ata6.00: error: { ICRC ABRT }
[900723.864684] ata6.00: failed command: READ FPDMA QUEUED
[900723.874099] ata6.00: error: { ICRC ABRT }
[900723.876500] ata6.00: failed command: READ FPDMA QUEUED
[900723.886457] ata6.00: error: { ICRC ABRT }
[900723.888928] ata6.00: failed command: READ FPDMA QUEUED
[900723.898792] ata6.00: error: { ICRC ABRT }
[900723.901166] ata6.00: failed command: READ FPDMA QUEUED
[900723.911143] ata6.00: error: { ICRC ABRT }
[900723.913503] ata6.00: failed command: READ FPDMA QUEUED
[900723.922952] ata6.00: error: { ICRC ABRT }
[900723.925368] ata6.00: failed command: READ FPDMA QUEUED
[900723.934820] ata6.00: error: { ICRC ABRT }
[900727.692466] ata6.00: irq_stat 0x08000000, interface fatal error
[900727.696648] ata6.00: failed command: READ FPDMA QUEUED
[900727.712462] ata6.00: failed command: READ FPDMA QUEUED
[900727.722419] ata6.00: failed command: READ FPDMA QUEUED
[900727.730451] ata6.00: failed command: READ FPDMA QUEUED
[900727.738139] ata6.00: failed command: READ FPDMA QUEUED
[900727.746442] ata6.00: failed command: READ FPDMA QUEUED
[900727.755106] ata6.00: failed command: READ FPDMA QUEUED
[900727.762849] ata6.00: failed command: READ FPDMA QUEUED
[900731.851156] ata6.00: irq_stat 0x48000008, interface fatal error
[900731.855618] ata6.00: failed command: READ FPDMA QUEUED
[900731.869891] ata6.00: error: { ICRC ABRT }
[900731.872014] ata6.00: failed command: READ FPDMA QUEUED
[900731.880999] ata6.00: error: { ICRC ABRT }
[900731.883693] ata6.00: failed command: READ FPDMA QUEUED
[900731.893192] ata6.00: error: { ICRC ABRT }
[900732.412680] ata6.00: irq_stat 0x48000008, interface fatal error
[900732.414522] ata6.00: failed command: READ FPDMA QUEUED
[900732.422720] ata6.00: error: { ICRC ABRT }
[900732.424811] ata6.00: failed command: READ FPDMA QUEUED
[900732.433084] ata6.00: error: { ICRC ABRT }
[900732.435140] ata6.00: failed command: READ FPDMA QUEUED
[900732.443524] ata6.00: error: { ICRC ABRT }
[900732.445614] ata6.00: failed command: READ FPDMA QUEUED
[900732.454026] ata6.00: error: { ICRC ABRT }
[900732.456115] ata6.00: failed command: READ FPDMA QUEUED
[900732.464625] ata6.00: error: { ICRC ABRT }
[900732.466728] ata6.00: failed command: READ FPDMA QUEUED
[900732.473260] ata6.00: error: { ICRC ABRT }
[900732.473264] ata6.00: failed command: READ FPDMA QUEUED
[900732.484156] ata6.00: error: { ICRC ABRT }
[900732.488477] ata6.00: failed command: READ FPDMA QUEUED
[900732.488491] ata6.00: error: { ICRC ABRT }
[900735.341019] ata6.00: irq_stat 0x48000008, interface fatal error
[900735.343093] ata6.00: failed command: READ FPDMA QUEUED
[900735.351235] ata6.00: error: { ICRC ABRT }
[900735.353288] ata6.00: failed command: READ FPDMA QUEUED
[900735.361945] ata6.00: error: { ICRC ABRT }
[900735.364014] ata6.00: failed command: READ FPDMA QUEUED
[900735.372438] ata6.00: error: { ICRC ABRT }
[900735.374505] ata6.00: failed command: READ FPDMA QUEUED
[900735.382705] ata6.00: error: { ICRC ABRT }
[900735.384752] ata6.00: failed command: READ FPDMA QUEUED
[900735.392846] ata6.00: error: { ICRC ABRT }
[900735.394887] ata6.00: failed command: READ FPDMA QUEUED
[900735.403229] ata6.00: error: { ICRC ABRT }
[900735.405210] ata6.00: failed command: READ FPDMA QUEUED
[900735.413237] ata6.00: error: { ICRC ABRT }
[900735.415200] ata6.00: failed command: READ FPDMA QUEUED
[900735.423141] ata6.00: error: { ICRC ABRT }
[900735.425160] ata6.00: failed command: READ FPDMA QUEUED
[900735.433415] ata6.00: error: { ICRC ABRT }
[900737.374249] ata6.00: irq_stat 0x48000008, interface fatal error
[900737.376425] ata6.00: failed command: READ FPDMA QUEUED
[900737.384023] ata6.00: error: { ICRC ABRT }
[900737.385936] ata6.00: failed command: READ FPDMA QUEUED
[900737.393661] ata6.00: error: { ICRC ABRT }
[900737.395681] ata6.00: failed command: READ FPDMA QUEUED
[900737.403573] ata6.00: error: { ICRC ABRT }
[900737.405514] ata6.00: failed command: READ FPDMA QUEUED
[900737.413134] ata6.00: error: { ICRC ABRT }
[900737.414871] ata6.00: failed command: READ FPDMA QUEUED
[900737.422399] ata6.00: error: { ICRC ABRT }
[900737.424267] ata6.00: failed command: READ FPDMA QUEUED
[900737.432070] ata6.00: error: { ICRC ABRT }
[900737.434007] ata6.00: failed command: READ FPDMA QUEUED
[900737.441661] ata6.00: error: { ICRC ABRT }
[900737.443416] ata6.00: failed command: READ FPDMA QUEUED
[900737.450716] ata6.00: error: { ICRC ABRT }
[900737.452478] ata6.00: failed command: READ FPDMA QUEUED
[900737.460254] ata6.00: error: { ICRC ABRT }
[900737.462251] ata6.00: failed command: READ FPDMA QUEUED
[900737.470781] ata6.00: error: { ICRC ABRT }
[900737.473150] ata6.00: failed command: READ FPDMA QUEUED
[900737.481352] ata6.00: error: { ICRC ABRT }
[900737.483405] ata6.00: failed command: READ FPDMA QUEUED
[900737.492044] ata6.00: error: { ICRC ABRT }
[900737.494235] ata6.00: failed command: READ FPDMA QUEUED
[900737.503641] ata6.00: error: { ICRC ABRT }
[900737.505719] ata6.00: failed command: READ FPDMA QUEUED
[900737.514545] ata6.00: error: { ICRC ABRT }
[900748.676833] ata6.00: irq_stat 0x48000008, interface fatal error
[900748.679094] ata6.00: failed command: READ FPDMA QUEUED
[900748.687633] ata6.00: error: { ICRC ABRT }
[900748.689630] ata6.00: failed command: READ FPDMA QUEUED
[900748.698497] ata6.00: error: { ICRC ABRT }
[900748.700647] ata6.00: failed command: READ FPDMA QUEUED
[900748.708915] ata6.00: error: { ICRC ABRT }
[900748.710889] ata6.00: failed command: READ FPDMA QUEUED
[900748.718741] ata6.00: error: { ICRC ABRT }
[900748.720706] ata6.00: failed command: READ FPDMA QUEUED
[900748.728840] ata6.00: error: { ICRC ABRT }
[900748.730835] ata6.00: failed command: READ FPDMA QUEUED
[900748.738606] ata6.00: error: { ICRC ABRT }
[900748.740514] ata6.00: failed command: READ FPDMA QUEUED
[900748.748439] ata6.00: error: { ICRC ABRT }
[900748.750465] ata6.00: failed command: READ FPDMA QUEUED
[900748.759124] ata6.00: error: { ICRC ABRT }
[900750.379799] ata6.00: irq_stat 0x48000008, interface fatal error
[900750.381811] ata6.00: failed command: READ FPDMA QUEUED
[900750.390168] ata6.00: error: { ICRC ABRT }
[900750.392361] ata6.00: failed command: READ FPDMA QUEUED
[900750.400529] ata6.00: error: { ICRC ABRT }
[900750.402952] ata6.00: failed command: READ FPDMA QUEUED
[900750.411496] ata6.00: error: { ICRC ABRT }
[900750.413537] ata6.00: failed command: READ FPDMA QUEUED
[900750.422318] ata6.00: error: { ICRC ABRT }
[900750.424387] ata6.00: failed command: READ FPDMA QUEUED
[900750.432766] ata6.00: error: { ICRC ABRT }
[900750.434624] ata6.00: failed command: READ FPDMA QUEUED
[900750.443983] ata6.00: error: { ICRC ABRT }
[900750.446032] ata6.00: failed command: READ FPDMA QUEUED
[900750.454372] ata6.00: error: { ICRC ABRT }
[900750.456393] ata6.00: failed command: READ FPDMA QUEUED
[900750.464575] ata6.00: error: { ICRC ABRT }
[900769.546137] ata6.00: irq_stat 0x48000008, interface fatal error
[900769.548110] ata6.00: failed command: READ FPDMA QUEUED
[900769.555990] ata6.00: error: { ICRC ABRT }
[900769.557914] ata6.00: failed command: READ FPDMA QUEUED
[900769.565683] ata6.00: error: { ICRC ABRT }
[900769.567584] ata6.00: failed command: READ FPDMA QUEUED
[900769.575316] ata6.00: error: { ICRC ABRT }
[900769.577276] ata6.00: failed command: READ FPDMA QUEUED
[900769.585341] ata6.00: error: { ICRC ABRT }
[900769.587296] ata6.00: failed command: READ FPDMA QUEUED
[900769.595431] ata6.00: error: { ICRC ABRT }
[900769.597432] ata6.00: failed command: READ FPDMA QUEUED
[900769.605465] ata6.00: error: { ICRC ABRT }
[900769.607427] ata6.00: failed command: READ FPDMA QUEUED
[900769.615514] ata6.00: error: { ICRC ABRT }
[900769.617458] ata6.00: failed command: READ FPDMA QUEUED
[900769.625460] ata6.00: error: { ICRC ABRT }
[900775.795989] ata6.00: irq_stat 0x48000008, interface fatal error
[900775.797995] ata6.00: failed command: READ FPDMA QUEUED
[900775.806644] ata6.00: error: { ICRC ABRT }
[900775.808950] ata6.00: failed command: READ FPDMA QUEUED
[900775.817233] ata6.00: error: { ICRC ABRT }
[900775.819457] ata6.00: failed command: READ FPDMA QUEUED
[900775.828402] ata6.00: error: { ICRC ABRT }
[900775.830447] ata6.00: failed command: READ FPDMA QUEUED
[900775.838645] ata6.00: error: { ICRC ABRT }
[900775.840666] ata6.00: failed command: READ FPDMA QUEUED
[900775.848909] ata6.00: error: { ICRC ABRT }
[900775.851184] ata6.00: failed command: READ FPDMA QUEUED
[900775.859204] ata6.00: error: { ICRC ABRT }
[900775.861181] ata6.00: failed command: READ FPDMA QUEUED
[900775.869147] ata6.00: error: { ICRC ABRT }
[900775.871083] ata6.00: failed command: READ FPDMA QUEUED
[900775.879445] ata6.00: error: { ICRC ABRT }
[900778.386794] ata6.00: irq_stat 0x48000008, interface fatal error
[900778.389297] ata6.00: failed command: READ FPDMA QUEUED
[900778.399250] ata6.00: error: { ICRC ABRT }
[900778.401728] ata6.00: failed command: READ FPDMA QUEUED
[900778.411693] ata6.00: error: { ICRC ABRT }
[900778.414190] ata6.00: failed command: READ FPDMA QUEUED
[900778.424208] ata6.00: error: { ICRC ABRT }
[900778.426745] ata6.00: failed command: READ FPDMA QUEUED
[900778.437418] ata6.00: error: { ICRC ABRT }
[900778.439990] ata6.00: failed command: READ FPDMA QUEUED
[900778.450257] ata6.00: error: { ICRC ABRT }
[900778.452804] ata6.00: failed command: READ FPDMA QUEUED
[900778.463105] ata6.00: error: { ICRC ABRT }
[900778.465649] ata6.00: failed command: READ FPDMA QUEUED
[900778.475912] ata6.00: error: { ICRC ABRT }
[900778.478503] ata6.00: failed command: READ FPDMA QUEUED
[900778.488881] ata6.00: error: { ICRC ABRT }
[900778.491381] ata6.00: failed command: READ FPDMA QUEUED
[900778.501700] ata6.00: error: { ICRC ABRT }
[900778.504246] ata6.00: failed command: READ FPDMA QUEUED
[900778.514507] ata6.00: error: { ICRC ABRT }
[900778.517125] ata6.00: failed command: READ FPDMA QUEUED
[900778.527379] ata6.00: error: { ICRC ABRT }
[900817.257574] ata6.00: irq_stat 0x48000008, interface fatal error
[900817.259664] ata6.00: failed command: READ FPDMA QUEUED
[900817.268302] ata6.00: error: { ICRC ABRT }
[900817.270922] ata6.00: failed command: READ FPDMA QUEUED
[900817.280033] ata6.00: error: { ICRC ABRT }
[900817.282483] ata6.00: failed command: READ FPDMA QUEUED
[900817.290735] ata6.00: error: { ICRC ABRT }
[900817.292840] ata6.00: failed command: READ FPDMA QUEUED
[900817.301280] ata6.00: error: { ICRC ABRT }
[900817.303311] ata6.00: failed command: READ FPDMA QUEUED
[900817.311727] ata6.00: error: { ICRC ABRT }
[900817.313734] ata6.00: failed command: READ FPDMA QUEUED
[900817.321890] ata6.00: error: { ICRC ABRT }
[900817.323942] ata6.00: failed command: READ FPDMA QUEUED
[900817.332047] ata6.00: error: { ICRC ABRT }
[900817.334070] ata6.00: failed command: READ FPDMA QUEUED
[900817.342389] ata6.00: error: { ICRC ABRT }
[900819.925657] ata6.00: irq_stat 0x48000008, interface fatal error
[900819.927984] ata6.00: failed command: READ FPDMA QUEUED
[900819.936374] ata6.00: error: { ICRC ABRT }
[900819.938284] ata6.00: failed command: READ FPDMA QUEUED
[900819.946218] ata6.00: error: { ICRC ABRT }
[900819.948190] ata6.00: failed command: READ FPDMA QUEUED
[900819.956119] ata6.00: error: { ICRC ABRT }
[900819.958262] ata6.00: failed command: READ FPDMA QUEUED
[900819.966104] ata6.00: error: { ICRC ABRT }
[900819.968008] ata6.00: failed command: READ FPDMA QUEUED
[900819.975570] ata6.00: error: { ICRC ABRT }
[900819.977440] ata6.00: failed command: READ FPDMA QUEUED
[900819.985027] ata6.00: error: { ICRC ABRT }
[900819.986900] ata6.00: failed command: READ FPDMA QUEUED
[900819.994620] ata6.00: error: { ICRC ABRT }
[900819.996544] ata6.00: failed command: READ FPDMA QUEUED
[900820.004154] ata6.00: error: { ICRC ABRT }
[900820.006052] ata6.00: failed command: READ FPDMA QUEUED
[900820.013946] ata6.00: error: { ICRC ABRT }
[900820.016102] ata6.00: failed command: READ FPDMA QUEUED
[900820.024099] ata6.00: error: { ICRC ABRT }
[900820.026235] ata6.00: failed command: READ FPDMA QUEUED
[900820.034620] ata6.00: error: { ICRC ABRT }
[900820.036740] ata6.00: failed command: READ FPDMA QUEUED
[900820.045211] ata6.00: error: { ICRC ABRT }
[900820.047300] ata6.00: failed command: READ FPDMA QUEUED
[900820.055896] ata6.00: error: { ICRC ABRT }
[900820.058030] ata6.00: failed command: READ FPDMA QUEUED
[900820.066578] ata6.00: error: { ICRC ABRT }
[900820.068774] ata6.00: failed command: READ FPDMA QUEUED
[900820.077721] ata6.00: error: { ICRC ABRT }
[900829.813291] ata6.00: irq_stat 0x48000008, interface fatal error
[900829.815263] ata6.00: failed command: READ FPDMA QUEUED
[900829.823022] ata6.00: error: { ICRC ABRT }
[900829.824978] ata6.00: failed command: READ FPDMA QUEUED
[900829.832240] ata6.00: error: { ICRC ABRT }
[900829.833938] ata6.00: failed command: READ FPDMA QUEUED
[900829.841671] ata6.00: error: { ICRC ABRT }
[900829.843545] ata6.00: failed command: READ FPDMA QUEUED
[900829.851220] ata6.00: error: { ICRC ABRT }
[900829.853144] ata6.00: failed command: READ FPDMA QUEUED
[900829.861236] ata6.00: error: { ICRC ABRT }
[900829.863235] ata6.00: failed command: READ FPDMA QUEUED
[900829.871157] ata6.00: error: { ICRC ABRT }
[900829.873122] ata6.00: failed command: READ FPDMA QUEUED
[900829.882367] ata6.00: error: { ICRC ABRT }
[900829.884643] ata6.00: failed command: READ FPDMA QUEUED
[900829.894877] ata6.00: error: { ICRC ABRT }
[900829.897623] ata6.00: failed command: READ FPDMA QUEUED
[900829.908123] ata6.00: error: { ICRC ABRT }
[900829.910775] ata6.00: failed command: READ FPDMA QUEUED
[900829.921220] ata6.00: error: { ICRC ABRT }
[900829.923873] ata6.00: failed command: READ FPDMA QUEUED
[900829.935035] ata6.00: error: { ICRC ABRT }
[900831.047328] ata6.00: irq_stat 0x48000008, interface fatal error
[900831.049631] ata6.00: failed command: READ FPDMA QUEUED
[900831.057518] ata6.00: error: { ICRC ABRT }
[900831.059437] ata6.00: failed command: READ FPDMA QUEUED
[900831.067192] ata6.00: error: { ICRC ABRT }
[900831.069115] ata6.00: failed command: READ FPDMA QUEUED
[900831.076771] ata6.00: error: { ICRC ABRT }
[900831.078789] ata6.00: failed command: READ FPDMA QUEUED
[900831.086430] ata6.00: error: { ICRC ABRT }
[900831.088354] ata6.00: failed command: READ FPDMA QUEUED
[900831.096192] ata6.00: error: { ICRC ABRT }
[900831.098120] ata6.00: failed command: READ FPDMA QUEUED
[900831.105872] ata6.00: error: { ICRC ABRT }
[900831.107912] ata6.00: failed command: READ FPDMA QUEUED
[900831.116330] ata6.00: error: { ICRC ABRT }
[900831.118408] ata6.00: failed command: READ FPDMA QUEUED
[900831.126435] ata6.00: error: { ICRC ABRT }
[900831.128398] ata6.00: failed command: READ FPDMA QUEUED
[900831.136322] ata6.00: error: { ICRC ABRT }
[900831.138448] ata6.00: failed command: READ FPDMA QUEUED
[900831.146463] ata6.00: error: { ICRC ABRT }
[900831.148423] ata6.00: failed command: READ FPDMA QUEUED
[900831.156417] ata6.00: error: { ICRC ABRT }
[900837.480092] ata6.00: irq_stat 0x48000008, interface fatal error
[900837.482107] ata6.00: failed command: READ FPDMA QUEUED
[900837.490396] ata6.00: error: { ICRC ABRT }
[900837.492944] ata6.00: failed command: READ FPDMA QUEUED
[900837.501621] ata6.00: error: { ICRC ABRT }
[900837.503527] ata6.00: failed command: READ FPDMA QUEUED
[900837.511357] ata6.00: error: { ICRC ABRT }
[900837.513321] ata6.00: failed command: READ FPDMA QUEUED
[900837.521466] ata6.00: error: { ICRC ABRT }
[900837.523462] ata6.00: failed command: READ FPDMA QUEUED
[900837.531384] ata6.00: error: { ICRC ABRT }
[900837.533353] ata6.00: failed command: READ FPDMA QUEUED
[900837.541295] ata6.00: error: { ICRC ABRT }
[900837.543313] ata6.00: failed command: READ FPDMA QUEUED
[900837.551546] ata6.00: error: { ICRC ABRT }
[900837.553723] ata6.00: failed command: READ FPDMA QUEUED
[900837.561855] ata6.00: error: { ICRC ABRT }
[900837.564175] ata6.00: failed command: READ FPDMA QUEUED
[900837.572364] ata6.00: error: { ICRC ABRT }
[900837.574690] ata6.00: failed command: READ FPDMA QUEUED
[900837.583326] ata6.00: error: { ICRC ABRT }
[900839.519507] ata6.00: irq_stat 0x48000008, interface fatal error
[900839.522334] ata6.00: failed command: READ FPDMA QUEUED
[900839.530238] ata6.00: error: { ICRC ABRT }
[900839.532131] ata6.00: failed command: READ FPDMA QUEUED
[900839.540098] ata6.00: error: { ICRC ABRT }
[900839.542004] ata6.00: failed command: READ FPDMA QUEUED
[900839.549885] ata6.00: error: { ICRC ABRT }
[900839.552060] ata6.00: failed command: READ FPDMA QUEUED
[900839.560065] ata6.00: error: { ICRC ABRT }
[900839.561975] ata6.00: failed command: READ FPDMA QUEUED
[900839.569788] ata6.00: error: { ICRC ABRT }
[900839.571693] ata6.00: failed command: READ FPDMA QUEUED
[900839.579363] ata6.00: error: { ICRC ABRT }
[900839.581301] ata6.00: failed command: READ FPDMA QUEUED
[900839.588948] ata6.00: error: { ICRC ABRT }
[900839.590859] ata6.00: failed command: READ FPDMA QUEUED
[900839.599269] ata6.00: error: { ICRC ABRT }
[900839.601395] ata6.00: failed command: READ FPDMA QUEUED
[900839.610409] ata6.00: error: { ICRC ABRT }
[900839.612655] ata6.00: failed command: READ FPDMA QUEUED
[900839.621769] ata6.00: error: { ICRC ABRT }
[900839.624166] ata6.00: failed command: READ FPDMA QUEUED
[900839.632398] ata6.00: error: { ICRC ABRT }
[900839.634404] ata6.00: failed command: READ FPDMA QUEUED
[900839.642574] ata6.00: error: { ICRC ABRT }
[1135108.023220] ata5.00: irq_stat 0x48000008, interface fatal error
[1135108.025549] ata5.00: failed command: READ FPDMA QUEUED
[1135108.035126] ata5.00: error: { ICRC ABRT }
[1135108.471586] ata5.00: irq_stat 0x48000008, interface fatal error
[1135108.473767] ata5.00: failed command: READ FPDMA QUEUED
[1135108.482839] ata5.00: error: { ICRC ABRT }
[1135108.485076] ata5.00: failed command: READ FPDMA QUEUED
[1135108.494757] ata5.00: error: { ICRC ABRT }
[1135108.496996] ata5.00: failed command: READ FPDMA QUEUED
                          res 43/84:01:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[1135108.506201] ata5.00: error: { ICRC ABRT }
[1135108.950159] ata5.00: irq_stat 0x48000008, interface fatal error
[1135108.951964] ata5.00: failed command: READ FPDMA QUEUED
[1135108.959296] ata5.00: error: { ICRC ABRT }
[1135108.961097] ata5.00: failed command: READ FPDMA QUEUED
                          res 43/84:01:09:4f:c2/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[1135108.968413] ata5.00: error: { ICRC ABRT }
[1135108.970396] ata5.00: failed command: READ FPDMA QUEUED
[1135108.978066] ata5.00: error: { ICRC ABRT }
[1135109.411631] ata5.00: irq_stat 0x48000008, interface fatal error
[1135109.414381] ata5.00: failed command: READ FPDMA QUEUED
[1135109.430512] ata5.00: error: { ICRC ABRT }
[1135109.433495] ata5.00: failed command: READ FPDMA QUEUED
[1135109.444744] ata5.00: error: { ICRC ABRT }
[1135109.447367] ata5.00: failed command: READ FPDMA QUEUED
[1135109.457878] ata5.00: error: { ICRC ABRT }
[1135109.907318] ata5.00: irq_stat 0x48000008, interface fatal error
[1135109.909493] ata5.00: failed command: READ FPDMA QUEUED
[1135109.918169] ata5.00: error: { ICRC ABRT }
[1135109.920395] ata5.00: failed command: READ FPDMA QUEUED
[1135109.929751] ata5.00: error: { ICRC ABRT }
[1135109.932135] ata5.00: failed command: READ FPDMA QUEUED
[1135109.941619] ata5.00: error: { ICRC ABRT }
[1135110.408310] ata5.00: irq_stat 0x48000008, interface fatal error
[1135110.410817] ata5.00: failed command: READ FPDMA QUEUED
[1135110.420608] ata5.00: error: { ICRC ABRT }
[1135110.423144] ata5.00: failed command: READ FPDMA QUEUED
[1135110.433347] ata5.00: error: { ICRC ABRT }
[1135110.436151] ata5.00: failed command: READ FPDMA QUEUED
[1135110.447856] ata5.00: error: { ICRC ABRT }
[1135110.910652] ata5.00: irq_stat 0x48000008, interface fatal error
[1135110.914431] ata5.00: failed command: READ FPDMA QUEUED
[1135110.926814] ata5.00: error: { ICRC ABRT }
[1135110.928886] ata5.00: failed command: READ FPDMA QUEUED
[1135110.937373] ata5.00: error: { ICRC ABRT }
[1135110.939420] ata5.00: failed command: READ FPDMA QUEUED
[1135110.947926] ata5.00: error: { ICRC ABRT }
[1135111.320425] sd 4:0:0:0: [sdg] tag#7 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=2s
[1135111.325476] sd 4:0:0:0: [sdg] tag#7 Sense Key : Aborted Command [current]
[1135111.328317] sd 4:0:0:0: [sdg] tag#7 Add. Sense: Scsi parity error
[1135111.330521] sd 4:0:0:0: [sdg] tag#7 CDB: Read(16) 88 00 00 00 00 00 00 00 00 20 00 00 00 e0 00 00
[1135111.332541] I/O error, dev sdg, sector 32 op 0x0:(READ) flags 0x800 phys_seg 28 prio class 2
[1135111.334647] sd 4:0:0:0: [sdg] tag#8 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=2s
[1135111.336783] sd 4:0:0:0: [sdg] tag#8 Sense Key : Aborted Command [current]
[1135111.338849] sd 4:0:0:0: [sdg] tag#8 Add. Sense: Scsi parity error
[1135111.340899] sd 4:0:0:0: [sdg] tag#8 CDB: Read(16) 88 00 00 00 00 04 8c 3f f4 20 00 00 00 e0 00 00
[1135111.342945] I/O error, dev sdg, sector 19532870688 op 0x0:(READ) flags 0x800 phys_seg 28 prio class 2
[1135111.345025] sd 4:0:0:0: [sdg] tag#9 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=2s
[1135111.347099] sd 4:0:0:0: [sdg] tag#9 Sense Key : Aborted Command [current]
[1135111.349180] sd 4:0:0:0: [sdg] tag#9 Add. Sense: Scsi parity error
[1135111.351244] sd 4:0:0:0: [sdg] tag#9 CDB: Read(16) 88 00 00 00 00 00 00 00 12 20 00 00 00 e0 00 00
[1135111.353314] I/O error, dev sdg, sector 4640 op 0x0:(READ) flags 0x800 phys_seg 14 prio class 2
[1135111.430270] ata5.00: irq_stat 0x48000008, interface fatal error
[1135111.432359] ata5.00: failed command: READ FPDMA QUEUED
[1135111.440771] ata5.00: error: { ICRC ABRT }
[1135111.442860] ata5.00: failed command: READ FPDMA QUEUED
[1135111.451481] ata5.00: error: { ICRC ABRT }
[1135258.982689] sd 4:0:0:0: [sdg] Synchronizing SCSI cache
[1135258.989024] sd 4:0:0:0: [sdg] Synchronize Cache(10) failed: Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[1135794.558498] sd 4:0:0:0: [sdg] 23437770752 512-byte logical blocks: (12.0 TB/10.9 TiB)
[1135794.567548] sd 4:0:0:0: [sdg] 4096-byte physical blocks
[1135794.572503] sd 4:0:0:0: [sdg] Write Protect is off
[1135794.574961] sd 4:0:0:0: [sdg] Mode Sense: 00 3a 00 00
[1135794.575030] sd 4:0:0:0: [sdg] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[1135794.578110] sd 4:0:0:0: [sdg] Preferred minimum I/O size 4096 bytes
[1135794.601702] sd 4:0:0:0: [sdg] Attached SCSI disk
[1135863.159620] ata5.00: irq_stat 0x48000008, interface fatal error
[1135863.161571] ata5.00: failed command: READ FPDMA QUEUED
[1135863.169020] ata5.00: error: { ICRC ABRT }
[1135891.542269] ata5.00: irq_stat 0x48000008, interface fatal error
[1135891.544557] ata5.00: failed command: WRITE FPDMA QUEUED
[1135891.554269] ata5.00: error: { ICRC ABRT }
[1135891.556038] ata5.00: failed command: WRITE FPDMA QUEUED
[1135891.563282] ata5.00: error: { ICRC ABRT }
[1135891.960898] ata5.00: irq_stat 0x48000008, interface fatal error
[1135891.964073] ata5.00: failed command: WRITE FPDMA QUEUED
[1135891.976684] ata5.00: error: { ICRC ABRT }
[1135891.978733] ata5.00: failed command: WRITE FPDMA QUEUED
[1135891.985808] ata5.00: error: { ICRC ABRT }
[1135892.381094] ata5.00: irq_stat 0x48000008, interface fatal error
[1135892.384389] ata5.00: failed command: WRITE FPDMA QUEUED
[1135892.393038] ata5.00: error: { ICRC ABRT }
[1135892.394584] ata5.00: failed command: WRITE FPDMA QUEUED
[1135892.401366] ata5.00: error: { ICRC ABRT }
[1135892.817041] ata5.00: irq_stat 0x48000008, interface fatal error
[1135892.820214] ata5.00: failed command: WRITE FPDMA QUEUED
[1135892.833415] ata5.00: error: { ICRC ABRT }
[1135892.835333] ata5.00: failed command: WRITE FPDMA QUEUED
[1135892.842587] ata5.00: error: { ICRC ABRT }
[1135893.241572] ata5.00: irq_stat 0x48000008, interface fatal error
[1135893.245200] ata5.00: failed command: WRITE FPDMA QUEUED
[1135893.259962] ata5.00: error: { ICRC ABRT }
[1135893.262259] ata5.00: failed command: WRITE FPDMA QUEUED
[1135893.271465] ata5.00: error: { ICRC ABRT }
[1135893.670072] ata5.00: irq_stat 0x48000008, interface fatal error
[1135893.674084] ata5.00: failed command: WRITE FPDMA QUEUED
[1135893.688703] ata5.00: error: { ICRC ABRT }
[1135893.690803] ata5.00: failed command: WRITE FPDMA QUEUED
[1135893.698645] ata5.00: error: { ICRC ABRT }
[1135894.048508] sd 4:0:0:0: [sdg] tag#6 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=2s
[1135894.052598] sd 4:0:0:0: [sdg] tag#6 Sense Key : Aborted Command [current]
[1135894.056595] sd 4:0:0:0: [sdg] tag#6 Add. Sense: Scsi parity error
[1135894.060474] sd 4:0:0:0: [sdg] tag#6 CDB: Write(16) 8a 00 00 00 00 00 00 00 05 40 00 00 02 c0 00 00
[1135894.065289] I/O error, dev sdg, sector 1344 op 0x1:(WRITE) flags 0x800 phys_seg 88 prio class 2
[1135894.069648] Buffer I/O error on dev sdg, logical block 168, lost async page write
[1135894.072707] Buffer I/O error on dev sdg, logical block 169, lost async page write
[1135894.074894] Buffer I/O error on dev sdg, logical block 170, lost async page write
[1135894.076903] Buffer I/O error on dev sdg, logical block 171, lost async page write
[1135894.079251] Buffer I/O error on dev sdg, logical block 172, lost async page write
[1135894.082145] Buffer I/O error on dev sdg, logical block 173, lost async page write
[1135894.084222] Buffer I/O error on dev sdg, logical block 174, lost async page write
[1135894.086176] Buffer I/O error on dev sdg, logical block 175, lost async page write
[1135894.088201] Buffer I/O error on dev sdg, logical block 176, lost async page write
[1135894.090200] Buffer I/O error on dev sdg, logical block 177, lost async page write
[1135894.092323] sd 4:0:0:0: [sdg] tag#7 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=2s
[1135894.094302] sd 4:0:0:0: [sdg] tag#7 Sense Key : Aborted Command [current]
[1135894.096919] sd 4:0:0:0: [sdg] tag#7 Add. Sense: Scsi parity error
[1135894.099575] sd 4:0:0:0: [sdg] tag#7 CDB: Write(16) 8a 00 00 00 00 00 00 00 00 00 00 00 05 40 00 00
[1135894.101526] I/O error, dev sdg, sector 0 op 0x1:(WRITE) flags 0x4800 phys_seg 168 prio class 2
Well there is the issue: read error.
Something prevents reads. Could be configuration, security, defects.
Same error at different SATA Port ?
so if I run sudo dmesg | grep -i ‘sdg|seagate|warn|error|fail’ on the old damaged hard drive on the same SATA port, I get:
admin@server[~]$ sudo dmesg | grep -i ‘sdg|seagate|warn|error|fail’
zsh: command not found: seagate
zsh: command not found: warn
zsh: command not found: error
zsh: command not found: fail’
this means the problem is with the hard drive and not the SATA port?
The quotes you used in that command are the wrong ones. Try
sudo dmesg | grep -i 'sdg|seagate|warn|error|fail'
Thank you
I then got basically no errors:
admin@server[~]$ sudo dmesg | grep -i 'sdg|seagate|warn|error|fail'
admin@server[~]$
so the problem is with the hard drive and not the SATA port?
