How do I erase an unwanted directory?
TrueNAS Documentation Hub was unable to help me with what seems like a simple noob question that may have a complicated answer, but here goes:
How do I erase a directory that I don’t want? (in the GUI)
I can’t even see the directory under the Datasets menu, but if I go to Credentials>Users>Edit User>Directories and Permissions, I can see it but there is no mechanism to eliminate it there. Is the only way to do it from the Command Line?
I must have created these directories when I first installed TrueNAS (Dragonfish) and wasn’t sure what I was doing (maybe I’m still not) :confounded:
Command line or over a share from your desktop PC. There is no file management in the UI.
You must have created that directory by one of these two methods by the same reasoning :wink:
Thank you sir! Much appreciated.
