Issues running Mumble when using a dataset for container data storage
When store the container data in a dataset the app fails to start
App is running under the default app user and the permissions are set on the dataset as this user
The container just starts then stops after a few sections
When running this in a ixVolume this runs without issue
Any ideas what else to check?
The Run As Context box for Mumble indicates UID/GID 1000. Try mounting your host path using Enable ACL and adding an entry for the ID 1000, like this:
Select Force Flag too, to allow for updates.
Perfect, I did notice that in the context but thought it was a oddity as the app is set to use the permissions of the app user but i take it mumble ignore this. Thanks for that, i’m fairly new to truenas to getting to grip with it.
