Hello.
Have created a Plex jail & Sabnzbd jail no issues whatsoever.
Proxmox 8.2.2 running Truenas CORE 13.0-U6.1
Below error from logs & ifconfig.
Have looked at promiscuity to make sure all enabled from proxmox.
Have seen that I may need to set up all my interfaces manually?
What’s odd is that my two previous jails have had no issues in ‘auto setup’.
Cheers.
May 19 02:57:48 sonarr dhclient[40836]: receive_packet failed on epair0b: Device not configured
May 19 02:57:48 sonarr dhclient[40836]: ioctl(SIOCGIFFLAGS) on epair0b: Operation not permitted
May 19 02:57:48 sonarr dhclient[40836]: Interface epair0b no longer appears valid.
May 19 02:57:48 sonarr dhclient[40836]: No live interfaces to poll on - exiting.
May 19 02:57:48 sonarr dhclient[40836]: exiting.
May 19 02:57:48 sonarr dhclient[40836]: connection closed
May 19 02:57:48 sonarr syslogd: exiting on signal 15
May 19 02:58:11 sonarr syslogd: kernel boot file is /boot/kernel/kernel
root@truenas[~]# ifconfig
vtnet0: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu1500
options=c00b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
ether bc:24:11:ad:0b:f6
inet 192.168.0.146 netmask 0xffffff00 broadcast 192.168.0.255
media: Ethernet autoselect (10Gbase-T )
status: active
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
ether 58:9c:fc:00:3c:51
member: vnet0.25 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 8 priority 128 path cost 2000
member: vnet0.8 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 2000
member: vnet0.3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 2000
member: vtnet0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 2000
groups: bridge
vnet0.3: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: plex as nic: epair0b
options=8<VLAN_MTU>
ether be:24:11:14:fa:09
hwaddr 02:16:52:30:c9:0a
groups: epair
media: Ethernet 10Gbase-T (10Gbase-T )
status: active
vnet0.8: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: sabnzbd as nic: epair0b
options=8<VLAN_MTU>
ether be:24:11:ef:4d:38
hwaddr 02:73:56:25:ba:0a
groups: epair
status: active
bridge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 58:9c:fc:10:b7:29
groups: bridge
groups: bridge
vnet0.25: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: sonarr as nic: epair0b
options=8<VLAN_MTU>
ether be:24:11:a5:a4:7e
hwaddr 02:5d:61:5b:25:0a
groups: epair
status: active
