Hi, I am not able to install Jdownloader from app repository from Truenas
Any advice please?
I select port 3129 but after install and running there is now web gui on that port
Any advice please?
i think you need to access to your local instance via API, because afaik mydownloader has not his webgui.
If you install directly via compose, in the image jlesage/jdownloader-2 there is a VNC built in to access directly without the api, but copy past is not so good via vnc
ok, I see now…
so I get API key from the MyJDownloader web and then use the API during instalation? Do I need have forvarded ports?
Thank you
no, no need to do anything else than set username and password during installation ![]()
ok, Thank you…Im conected…
