Installled jdownloader and I also have an account there. However I am not sure how to launch and use the app… I tried connectting via 3129 port. No luck. Can anyone guide me?
I don’t know how specifically jdownloader need to be configured using the catalogue (and if he run via vnc as the default using thejlesage/jdownloader-2 image), and you not provide info about how you setup it… but if the container Is up and running (also check container logs for any error), you should just login into my.jdowloader, the instance will be visible on top of the page, select It and enjoy ![]()
