Jellyfin DLNA issue
I have a Panasonic TX-55FZW804 tv and have been using Jellyfin for years with the DLNA plugin.
October 31st I updated TrueNas to 25.04.2.6 and Jellyfin to 10.11.1 includeding DLNA plugin v 10.0.0.0.
Since then the Jellyfin WEB UI shows all existing movies and series, however my TV does NOT.
On my TV I can see the (default) Jellyfin folders “series” and “movies” however both are empty, they don’t show the existing video files.
Apart from the app updates nothing else has been changed.
I have been looking in configuration and permission settings but can’t find a reason for this behavior.
Yesterday I updated to Jellyfin 10.11.2 but that did not solve the issue.
Any help is very much appreciated.
Regards, Herman
As far as i can remember dlna only worked with host networking. Are you using host networking or did the update maybe change back from host networking to port mapping?
Yes I have been using “host networking” from the beginning, used to work fine till the update.
Yesterday I found that the series folders exist in the jellyfin default “new series” folders only.
That changed, tv series used to be only in my jellyfin default “series” folder, the other default folders used to be empty.
I tried to play each of the series but none of them plays they all errors ou, the same holds for all of the movies.
I only see the errors but can’t figure out what the cause is.
Help is very much appreciated.
Kind Regards, Herman
Odroid H3 with 2x Mirrored WD HDD 3.5" 6TB WD60EFPX Red Plus
Jellyfin log for: Law & Order - Special Victims Unit/Season 27/Law & Order - Special Victims Unit - S27E01 - In the Wind HDTV-720p.mkv
[2025-11-12 22:29:03.499 +01:00] [INF] [70] MediaBrowser.MediaEncoding.Transcoding.TranscodeManager: “/usr/lib/jellyfin-ffmpeg/ffmpeg” “-analyzeduration 200M -probesize 1G -f matroska -init_hw_device vaapi=va:,vendor_id=0x8086,driver=iHD -init_hw_device qsv=qs@va -filter_hw_device qs -hwaccel vaapi -hwaccel_output_format vaapi -noautorotate -i file:\”/tv/Law & Order - Special Victims Unit/Season 27/Law & Order - Special Victims Unit - S27E01 - In the Wind HDTV-720p.mkv\" -noautoscale -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -force_key_frames \“expr:gte(t,n_forced*5)\” -vf \“setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale_vaapi=format=nv12:extra_hw_frames=24,hwmap=derive_device=qsv,format=qsv\” -low_power 1 -preset veryfast -mbbrc 1 -b:v 4302050 -maxrate 4302051 -rc_init_occupancy 8604100 -bufsize 17208200 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 ac3 -ac 6 -ab 384000 -y \“/cache/transcodes/f6a4a5b2dec11f2b5580f02b55e26606.ts\”"
[2025-11-12 22:29:03.573 +01:00] [ERR] [70] MediaBrowser.MediaEncoding.Transcoding.TranscodeManager: FFmpeg exited with code 187
[2025-11-12 22:29:03.686 +01:00] [ERR] [70] Jellyfin.Api.Middleware.ExceptionMiddleware: Error processing request. URL “GET” “/dlna/videos/1fba98de-7104-192b-acb6-2e75389f8b29/stream.ts”.
MediaBrowser.Common.FfmpegException: FFmpeg exited with code 187
at MediaBrowser.MediaEncoding.Transcoding.TranscodeManager.StartFfMpeg(StreamState state, String outputPath, String commandLineArguments, Guid userId, TranscodingJobType transcodingJobType, CancellationTokenSource cancellationTokenSource, String workingDirectory)
at Jellyfin.Plugin.Dlna.Playback.FileStreamResponseHelpers.GetTranscodedFile(StreamState state, Boolean isHeadRequest, HttpContext httpContext, ITranscodeManager transcodeManager, String ffmpegCommandLineArguments, TranscodingJobType transcodingJobType, CancellationTokenSource cancellationTokenSource)
at Jellyfin.Plugin.Dlna.Playback.Api.DlnaVideosController.GetVideoStream(Guid itemId, String container, Nullable1 static, String params, String tag, String deviceProfileId, String playSessionId, String segmentContainer, Nullable1 segmentLength, Nullable1 minSegments, String mediaSourceId, String deviceId, String audioCodec, Nullable1 enableAutoStreamCopy, Nullable1 allowVideoStreamCopy, Nullable1 allowAudioStreamCopy, Nullable1 breakOnNonKeyFrames, Nullable1 audioSampleRate, Nullable1 maxAudioBitDepth, Nullable1 audioBitRate, Nullable1 audioChannels, Nullable1 maxAudioChannels, String profile, String level, Nullable1 framerate, Nullable1 maxFramerate, Nullable1 copyTimestamps, Nullable1 startTimeTicks, Nullable1 width, Nullable1 height, Nullable1 maxWidth, Nullable1 maxHeight, Nullable1 videoBitRate, Nullable1 subtitleStreamIndex, Nullable1 subtitleMethod, Nullable1 maxRefFrames, Nullable1 maxVideoBitDepth, Nullable1 requireAvc, Nullable1 deInterlace, Nullable1 requireNonAnamorphic, Nullable1 transcodingMaxAudioChannels, Nullable1 cpuCoreLimit, String liveStreamId, Nullable1 enableMpegtsM2TsMode, String videoCodec, String subtitleCodec, String transcodeReasons, Nullable1 audioStreamIndex, Nullable1 videoStreamIndex, Nullable1 context, Dictionary2 streamOptions)
at lambda_method7692(Closure, Object)
at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.TaskOfActionResultExecutor.Execute(ActionContext actionContext, IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeActionMethodAsync>g__Awaited|12_0(ControllerActionInvoker invoker, ValueTask1 actionResultValueTask)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.g__Awaited|10_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.g__Awaited|13_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.g__Awaited|25_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Rethrow(ResourceExecutedContextSealed context)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.g__Awaited|20_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
at Jellyfin.Api.Middleware.ServerStartupMessageMiddleware.Invoke(HttpContext httpContext, IServerApplicationHost serverApplicationHost, ILocalizationManager localizationManager)
at Jellyfin.Api.Middleware.WebSocketHandlerMiddleware.Invoke(HttpContext httpContext, IWebSocketManager webSocketManager)
at Jellyfin.Api.Middleware.IPBasedAccessValidationMiddleware.Invoke(HttpContext httpContext, INetworkManager networkManager)
at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
at Jellyfin.Api.Middleware.QueryStringDecodingMiddleware.Invoke(HttpContext httpContext)
at Swashbuckle.AspNetCore.ReDoc.ReDocMiddleware.Invoke(HttpContext httpContext)
at Swashbuckle.AspNetCore.SwaggerUI.SwaggerUIMiddleware.Invoke(HttpContext httpContext)
at Swashbuckle.AspNetCore.Swagger.SwaggerMiddleware.Invoke(HttpContext httpContext, ISwaggerProvider swaggerProvider)
at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
at Jellyfin.Api.Middleware.RobotsRedirectionMiddleware.Invoke(HttpContext httpContext)
at Jellyfin.Api.Middleware.LegacyEmbyRouteRewriteMiddleware.Invoke(HttpContext httpContext)
at Jellyfin.Api.Middleware.ResponseTimeMiddleware.Invoke(HttpContext context, IServerConfigurationManager serverConfigurationManager)
at Jellyfin.Api.Middleware.ExceptionMiddleware.Invoke(HttpContext context)
[2025-11-12 22:29:04.707 +01:00] [INF] [70] MediaBrowser.MediaEncoding.Transcoding.TranscodeManager: “/usr/lib/jellyfin-ffmpeg/ffmpeg” “-analyzeduration 200M -probesize 1G -f matroska -init_hw_device vaapi=va:,vendor_id=0x8086,driver=iHD -init_hw_device qsv=qs@va -filter_hw_device qs -hwaccel vaapi -hwaccel_output_format vaapi -noautorotate -i file:\”/tv/Law & Order - Special Victims Unit/Season 27/Law & Order - Special Victims Unit - S27E01 - In the Wind HDTV-720p.mkv\" -noautoscale -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -force_key_frames \“expr:gte(t,n_forced*5)\” -vf \“setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale_vaapi=format=nv12:extra_hw_frames=24,hwmap=derive_device=qsv,format=qsv\” -low_power 1 -preset veryfast -mbbrc 1 -b:v 4302050 -maxrate 4302051 -rc_init_occupancy 8604100 -bufsize 17208200 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 ac3 -ac 6 -ab 384000 -y \“/cache/transcodes/f6a4a5b2dec11f2b5580f02b55e26606.ts\”"
[2025-11-12 22:29:04.747 +01:00] [ERR] [70] MediaBrowser.MediaEncoding.Transcoding.TranscodeManager: FFmpeg exited with code 187
[2025-11-12 22:29:04.846 +01:00] [ERR] [70] Jellyfin.Api.Middleware.ExceptionMiddleware: Error processing request. URL “GET” “/dlna/videos/1fba98de-7104-192b-acb6-2e75389f8b29/stream.ts”.
[2025-11-12 22:29:05.857 +01:00] [INF] [39] MediaBrowser.MediaEncoding.Transcoding.TranscodeManager: “/usr/lib/jellyfin-ffmpeg/ffmpeg” “-analyzeduration 200M -probesize 1G -f matroska -init_hw_device vaapi=va:,vendor_id=0x8086,driver=iHD -init_hw_device qsv=qs@va -filter_hw_device qs -hwaccel vaapi -hwaccel_output_format vaapi -noautorotate -i file:\”/tv/Law & Order - Special Victims Unit/Season 27/Law & Order - Special Victims Unit - S27E01 - In the Wind HDTV-720p.mkv\" -noautoscale -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -force_key_frames \“expr:gte(t,n_forced*5)\” -vf \“setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale_vaapi=format=nv12:extra_hw_frames=24,hwmap=derive_device=qsv,format=qsv\” -low_power 1 -preset veryfast -mbbrc 1 -b:v 4302050 -maxrate 4302051 -rc_init_occupancy 8604100 -bufsize 17208200 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 ac3 -ac 6 -ab 384000 -y \“/cache/transcodes/f6a4a5b2dec11f2b5580f02b55e26606.ts\”"
[2025-11-12 22:29:05.884 +01:00] [ERR] [39] MediaBrowser.MediaEncoding.Transcoding.TranscodeManager: FFmpeg exited with code 187
[2025-11-12 22:29:05.983 +01:00] [ERR] [39] Jellyfin.Api.Middleware.ExceptionMiddleware: Error processing request. URL “GET” “/dlna/videos/1fba98de-7104-192b-acb6-2e75389f8b29/stream.ts”.
[2025-11-12 22:29:06.992 +01:00] [INF] [39] MediaBrowser.MediaEncoding.Transcoding.TranscodeManager: “/usr/lib/jellyfin-ffmpeg/ffmpeg” “-analyzeduration 200M -probesize 1G -f matroska -init_hw_device vaapi=va:,vendor_id=0x8086,driver=iHD -init_hw_device qsv=qs@va -filter_hw_device qs -hwaccel vaapi -hwaccel_output_format vaapi -noautorotate -i file:\”/tv/Law & Order - Special Victims Unit/Season 27/Law & Order - Special Victims Unit - S27E01 - In the Wind HDTV-720p.mkv\" -noautoscale -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -force_key_frames \“expr:gte(t,n_forced*5)\” -vf \“setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale_vaapi=format=nv12:extra_hw_frames=24,hwmap=derive_device=qsv,format=qsv\” -low_power 1 -preset veryfast -mbbrc 1 -b:v 4302050 -maxrate 4302051 -rc_init_occupancy 8604100 -bufsize 17208200 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 ac3 -ac 6 -ab 384000 -y \“/cache/transcodes/f6a4a5b2dec11f2b5580f02b55e26606.ts\”"
[2025-11-12 22:29:07.021 +01:00] [ERR] [70] MediaBrowser.MediaEncoding.Transcoding.TranscodeManager: FFmpeg exited with code 187
[2025-11-12 22:29:07.118 +01:00] [ERR] [70] Jellyfin.Api.Middleware.ExceptionMiddleware: Error processing request. URL “GET” “/dlna/videos/1fba98de-7104-192b-acb6-2e75389f8b29/stream.ts”.
Before the reinstall of the 31st I deleted the setup and thought to have also deleted the Jellyfin configuration in the iX-Volume.
I subsequently installed Jellyfin again from scratch, setting /media/tv as the Jellyfin container series path and rescanned the directories.
However I noticed that the series path in the above log file starts with: /tv
It appears that for somehow the old Jellyfin configuration was not deleted, but not clear why I could play the seres from the Jellyfin GUI.
I just deleted Jellyfin again, deleting the configuration, rebooted and verified the iX-Volume deletion.
Now reinstalling Jellyfin, setting the correct Jellyfin container path, rescanning and enabling DLNA all works fine again.
All files are in the “New series” and “New movies” folders now and are playable.
