12100 is i3, and I did wrote “from xx500 upwards” since, obviously, Intel could not make it so simple as to allow ECC on all i5 parts…
Thanks for the info, I though I checked them beforehand but I might have mixed that between all the cpu I reviewed ![]()
So yeah on Intel side I will stay with 12500/12600 as those support ecc memory.
Thanks also for the input on the Asus w680 motherboard
Suggestion:
For 500€ this is an absolute bargain. Dual Xeons, Dual 10G Intel Ethernet, 12 drive bays, 64G RAM, IPMI hardware with separate Management LAN, Dual power supplies. Will run TrueNAS absolutely great. I love these machines. Extremely reliable over many years.
Drawbacks:
- The mainboard is too old to be able to boot from NVME. You MUST use an SATA/SAS boot drive (which is absolutely ok for TrueNAS)
- This machine is a true server designed for 24/7 in a datacenter. You don’t want to have it in your bedroom. Best to put it into a closet or basement. ok to put it in a corner of an office.
…but really doesn’t meet the stated requirements of low power draw and quiet operation.
btw my original post makes it seem like I wouldn’t recommend it due to pointing out only flaws - once I did get things running its been rock solid, I think I’m at >200 days uptime. I would recommend it, but would rather state the issues I experienced.
Another vote for that Asus workstation board. It has been flawless with 2 different chips here, and I maxed out the ram with 128gb even though all documents say 64. Their support will tell you 128 is possible now and it’s true.
“K” is needed, if you want to underclock your CPU any time in the future.
(I know, it sounds strange, but that is the case…)
