I’m new to TrueNAS.
I’ve installed Nextcloud from the apps.
I also installed Syncthing that points to the user data folder of Nextcloud so I be able to sync files while also be able to access them through Nextcloud.
For Nextcloud to be able to detect changes made by Syncthing, I need to run:
/bin/docker exec ix-nextcloud-nextcloud-1 php /var/www/html/occ files:scan --all
When I run it from the TrueNAS Shell - it works perfectly.
But if I copy-paste this command to the cron job command it doesn’t work. The cron job itself runs successfully but there is no changes within the Nextcloud.
The cron job I created:
Command: “/bin/docker exec ix-nextcloud-nextcloud-1 php /var/www/html/occ files:scan --all”.
Run as user: www-data - UID 33 (the user that Nextcloud use).
Schedule: ***** (every minute).
The ‘Hide Standard Output’ checkbox is checked.
The ‘Hide Standard Error’ checkbox isn’t checked.
The ‘Enabled’ checkbox is checked.
