Offtopic: Papier-mâché Halloween madness
Here is a illustration of why this shark is not as resistant to water and damage as some of my past creations - it contains a lot less steel and fiberglass tape / joint reinforcements than past creations.
Here is the Moray eel under construction - the body in white phase after the 4" expandable pipe was draped over a pig-tail like inner skeleton consisting of 1/2" conduit that was hand-bent. Keeping it all light allowed the entirety of the moray eel to be moored by only one point.
The croc was built with relatively little steel (except for jaws) and the base was multiple layers of thick cardboard taped to each other and then glued in place. Very solid, with a built-in larger pipe (0.75" OD) to allow the later attachment of arms to the this body.
You can see a little of the conduit in this shot, taken just before the final paint job began.
Here is a action shot of the shark under construction. I struggled multiple times as the lack of a strong skeleton made my life miserable. Moral of the story - always build a strong skeleton first, cladding it later will take a lot less time than trying to retrofit reinforcements into weak structures.
Great stuff! Thx for sharing the inside story and for the annual shot of creativity inspiration you give us!!!
What’s the “4” expandable pipe” in the Moray eel? Dryer exhaust, maybe?
Exactly right. It’s slinky coil with a metal wire to give the plastic some form. It used to be part of my home-made passive Radon-evacuation system before switching it to a more permanent PVC pipe solution.
Please never, ever use slinky coil hose with a clothes dryer vent.
Hard pipe it with smooth-walled solid galvanized steel vent pipe instead. I have seen slinky coil bend, create a P-trap, and hold over 2 gallons of water, thus blocking the dryer vent 100% - my friends were lucky it was an electric dryer. I am also not a fan of how slinky coil will easily trap lint, potentially blocking the flue / vent pipe also.
Smooth-walled pipe will not accumulate lint as easily, nor will it burn as easily if a fire happens, hopefully containing it inside the pipe. Slinky coil will simply burn / melt, whether it is aluminized or not.
This is also a good time to remind everyone to occasionally clear their vent pipes of lint and other stuff in there. You may even find a birds nest at the end if the terminal no longer closes properly.
100% agreed on the slinky coil warning. I didn’t allow our renovation contractor to use flexible on our bathroom exhaust fan installation either…
It’s that time again. Theme this year is Cyrus the unsinkable sea serpent, a bill peet story from 1975.
Given how much kids enjoy walking through / under glowing things, this sea serpent coils are perfect for creating negative space loops to walk through. Rough work is mostly done except for the spine / fin on back. Plus, all the fine work to make the face as happy and fun as it needs to be.
Then, time to prime, paint, and finish paint. All in time for next Saturday, hopefully.
Well, where are the photos? They were awesome last year!
Teaser preview.
I apologize.
I was somewhat exhausted after 21 days of non stop construction due to a flesh wound keeping me on the side lines until 10/10.
Sunday, all I managed to do was to spend the day putting everything away and swapping on winter tires for two cars. Believe it or not, this place turns into a bit of a pigsty during Halloween season.
Let me try to get you stuff today.
My Cyrus is considerably smaller than the one from the book but was one of the bigger builds here. Let me start with the finished product and then if there is interest in the build, I can add.
Every build is dedicated. This one to my uncle John and our neighbor Patricia, who always made us feel welcome and loved. Both passed away this year.
In case the handwriting is too hard to follow it’s:
Welcome to Cyrus, the unsinkable sea serpent!
When angry old men curse immigrants while sharks thirst for blood, be a Cyrus!
If you know the book, you know what I’m referring to.
Three objects greet the candy seekers along the path - the head up front, a major arch, a medium one.
Then there is the second loop. It’s about 20’ (6m) wide and quite curvy.
Loops 3+4 and the tail finish out the install
The loop over the path may buckle this weekend. Oh well.
I always liked Bill Peet, so well done.
Here in daylight
Then there are the sharks, one of which is a hammerhead zebra shark, the other a Williams-colors-inspired epaulet shark.
The soon-to-be-swallowed car is a very nice touch for scale!
:open_mouth:
Oh the snake was not enough: There had to be more!
:clap:
@Constantin
That looked fantastic! You always have a good show on Halloween. I’m not artistic like that but you definitely are.
You definitely are an artist. Just with code and hard drive failure modes instead of cardboard. :rofl:
One operational advantage is not finding yourself in the ER with 5 stitches into one finger due to a razor blade slip up.
I hope you haven’t done that. No need to make a trip to the ER when you have all that paper you could wrap around it, just the other day I took an X-Acto Knife and shoved it into my thumb. It hurt a little bit but I had some Painter Tape next to me, I just taped it up and a few hours (and oz of blood) later, it was all good again. :wink:
Works well enough unless you hit a knuckle. :grinning: Then, even the ER god says “yeah, we can’t glue that shut”.
Good news is that a razor cut can be clean, leaves no weird jagged edges that are impossible to join correctly, and if you’re really lucky, also misses the tendon. Thankfully, I got lucky this time.
So that’s how I got to spend one evening in the ER. Ten days later and my skin only protests when I pull on something really hard with that finger.
A similar flesh wound from a barely-deburred appliance frame required more stitches, a longer recovery, and a ring resizing due to the finger knuckle coming back together in a bigger nubble.
C’est la guerre.
