Plex Error - 13.2 Release Not Found
I am new to TrueNAS and I was trying to install Plex however when I pressed save to install it an error popped up stating release 13.2 was not found. I am unsure if I am able to fix this.
I’m not sure if there is some other way to get Plex as a plugin but I sort of need it simple or easy to understand how to do.
What version of TrueNAS are you on? If TrueNAS Core, please add the CORE tag to your first post and post the version number.
TrueNAS Scale is where the development is going on. Core is a dying product. Is this a brand new install? You might be better starting over and going to TrueNAS Scale, the latest version.
Hi, its Core and its a new install. I haven’t installed much on it yet so I will switch to Scale.
Thank you for your help
If you can hold of for a few day, the newest update of Scale should be coming out.
