TrueNAS core plugins not working
When I try to set up a plugin such as Plex, I get release 13.2 not found error. How can I fix this?
Thank you in advance.
Plugins haven’t worked in CORE for a very long time, and CORE itself is all but dead. If you need to run Plex or some other application on CORE, you’ll need to upgrade CORE to 13.3 (which is a completely dead release train), create a jail with FreeBSD 13.5, and install Plex manually.
Otherwise, install SCALE and either install the Plex app, or install it on your own using Docker.
Thanks for your help!
I’d prefer to use scale, however when I try to do a fresh install it fails. If I install core and upgrade to Scale it fails. Not sure why. I had this system running before for over a year with scale till my power supply failed. I replaced to power supply and now Scale won’t load at all I’ve tried every release. with 2 different motherboards and new boot SSD, and memory.
Thank you for sharing! I agree in the post!
To me this really seems something wrong with the installation device, maybe you are flashing It somehow incorrectly. Try with balena etcher if you are using rufus or similar!
Other thread is here.
