Pool is offline and one drive is missing
I have 4 drives. One drive was bad. Then I had a power outage.
Now the pool is offline and one drive is missing.
How do I restore the pool and replace the bad drive?
How is the pool set up? Raidz1? Raidz2? Simple Stripe? Stripe of mirrors? You have to give more information than you have given.
I don’t recall. I have 4 8tb drive, I believe1 had 1 parity drive
What does sudo zpool status show ?
root@truenas[~]# zpool status
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:08 with 0 errors on Wed Sep 18 03:45:08 2024
Sorry, make that sudo zpool status -v
Also
sudo zpool list
And
sudo zpool import
Thanks for all the help.
I was able to restart the drive. I removed the drive, swapped the drive power cables.
Turn on the machine. The pool is prefect no errors.
Prior, I had read errors on this one drive. It may be due to power issues.
