hey guys,
i’m new to truenas and got already quite far however i’m now busy with portainer.
I managed to install portainer and all seems fine, however now i want to deploy jellyfin.
I know you can deploy it directly in truenas but i prefer portainer. i already got the whole stack running on my ubuntu however i want to move it to truenas.
I started with trying to deploy only jellyfin and i run in some issues.
So i have my compose file and when i try to deploy i get error that mkdir /mnt is a read-only file system, on ‘/mtn/Appdata/Docker/Jellyfin’.
The folder are just dataset and not SMB shares at this point in time. But that should not matter, portainer managed to install, also i think the path are ok.
Also i give root system full access, as that was described for portainer.
What am i missing? And why i cant deploy the stack in portainer.
services:
jellyfin:
image: link-not-allowed-in-this-post
container_name: jellyfin
environment:
- PUID=568
- PGID=568
- TZ=Europe/Amsterdam
volumes: - /mnt/AppData/Docker/Config/Jellyfin:/config
- /mtn/Appdata/Docker/Jellyfin:/data/tvshows
- /mtn/Appdata/Docker/Jellyfin:/data/movies
ports: - 8096:8096
- 8920:8920 #optional
- 7359:7359/udp #optional
- 1900:1900/udp #optional
restart: unless-stopped
