Hello I am having many problems with my truenas core system. I was hoping someone could help me. My first problem is I get stuck on lines of code. To the point were I have to shut the system down by turning off the power switch.
My second problem is that 4 of my hdd have information I want from them but I can’t get. I exported the pool because that I thought I should do that, but now it won’t let me import it. If it finds it when searching for pools. If it does then I click import and it then says it has a I/O error.
My third problem is not all my drives show up. I have 10 hdd and 1 m.2 SSD (boot drive) my case has 12 HHD slots and 8 of them are hooked up to a pcie to sata controller. Normally all 8 show up as connected to the controller but sometimes they don’t show up in true as software. Also the two HDD that are not through the controller is acting weird. When I plug them into the system and not the hdd bays the software only finds 5 disk (same as in other bays) but in two bays the software sometimes finds all 11 drives I am supposed to have.
