I have ended in the situation that I wish to remove the system dataset from my hdd pool, specifically:
tank/.system
I have confirmed in advanced settings that system dataset is set to apps which is my ssd pool
my to reason destroy the dataset is that I had a bad backplane, that resulted in a bunch of corrupted files, including these:
pool: tank
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see:
scan: scrub repaired 0B in 22:24:58 with 5 errors on Sun Sep 27 01:19:39 2026
NAME STATE READ WRITE CKSUM
tank ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
52822cb6-0373-44f6-803f-56c2a72deed9 ONLINE 0 0 10
079ad8be-b3e0-4d18-be62-4b64efa1f576 ONLINE 0 0 10
18f35eb1-94d5-4c58-8dd3-01b74b5896fd ONLINE 0 0 10
b8f190c8-ff2e-4157-9947-cbdb662bcaf2 ONLINE 0 0 10
e991d73c-6ca5-4162-8b51-cedfb2384448 ONLINE 0 0 10
f77d7021-0f6a-4acb-81a4-830b55c1ed3f ONLINE 0 0 10
tank/.system/netdata-5a0a2a47cd884dbcbe527966286bfc29:/dbengine-tier1/datafile-1-0000000256.ndf
tank/.system/netdata-5a0a2a47cd884dbcbe527966286bfc29:/dbengine/datafile-1-0000002196.ndf
I have tried to locate the corrupted files without luck, but since I no longer need the old .system dataset I thought the best way forward was to simply remove it.
since it is hidden from the web interface I tried the terminal by I am denied from destroying it and even just unmounting it:
admin@truenas[~]$ zfs destroy tank/.system -rvp
destroy tank/.system/ctdb_shared_vol
cannot unmount '/mnt/tank/.system/ctdb_shared_vol': permission denied
destroy tank/.system/syslog-5a0a2a47cd884dbcbe527966286bfc29
cannot unmount '/mnt/tank/.system/syslog-5a0a2a47cd884dbcbe527966286bfc29': permission denied
destroy tank/.system/samba4
cannot unmount '/mnt/tank/.system/samba4': permission denied
destroy tank/.system/nfs
cannot unmount '/mnt/tank/.system/nfs': permission denied
destroy tank/.system/vm
cannot unmount '/mnt/tank/.system/vm': permission denied
destroy tank/.system/netdata-5a0a2a47cd884dbcbe527966286bfc29
cannot destroy 'tank/.system/netdata-5a0a2a47cd884dbcbe527966286bfc29': permission denied
destroy tank/.system/configs-5a0a2a47cd884dbcbe527966286bfc29
cannot unmount '/mnt/tank/.system/configs-5a0a2a47cd884dbcbe527966286bfc29': permission denied
destroy tank/.system/glusterd
cannot unmount '/mnt/tank/.system/glusterd': permission denied
destroy tank/.system/rrd-5a0a2a47cd884dbcbe527966286bfc29
cannot unmount '/mnt/tank/.system/rrd-5a0a2a47cd884dbcbe527966286bfc29': permission denied
destroy tank/.system/cores
cannot unmount '/mnt/tank/.system/cores': permission denied
destroy tank/.system/webui
cannot unmount '/mnt/tank/.system/webui': permission denied
destroy tank/.system/services
cannot unmount '/mnt/tank/.system/services': permission denied
cannot unmount '/mnt/tank/.system': permission denied
admin@truenas[~]$ zfs unmount tank/.system
I am unsure of what would be the best way forward from here
