Rustfs "Access key" confgiuration box
The amount of confusion the “access key” configuration item on rustfs app has given me is insurmountable. What we’re setting here is not necessarily an access key and acts more as the admin user, and how you initially login to the UI/console.
i.e. rust itself assigns rustfsadmin/rustfsadmin to these values, and the UI login and console ask for “account”
Obviously not, since you’ve surmounted it. But agreed that it’s confusing–why not raise it as an issue against the app on Github?
Ha!
I didn’t even know there was a repo for this, that should definitely be listed in the ‘sources’ section of the apps. But very true, that’s the proper place to raise the issue…..now that I’ve blown off my steam
filed https :// github com/truenas/apps/issues/5357
