Hey everyone,
Looking for some help making sure I’ve generally got this right, and a sanity check here with my transition plan.
I currently have a 4-bay Synology NAS that I’m looking at replacing with a DIY NAS. The current Synology array has 4x 10TB drives with one parity drive, for a usable space of 26.2TB. 21.5TB is currently used, I’ve tried slimming the data down as small as I can to facilitate moving it, can do more if really necessary, but it’s getting harder to prune unnecessary files now.
My goal is to add 2 more 10TB drives for now, but those obviously can’t fit in the current Synology box, and getting a larger one of those just doesn’t really make sense compared to a DIY box when I already have 3/4 of the hardware laying around to just build a system.
I’m trying to figure out what the best way to setup TrueNAS on the new hardware to facilitate moving the data over from the current drives, and then take those current 4 drives, format them, and add them to the TrueNAS array. Is there a way I can do this with only 2 new drives, or do I really need to get 3x 10TB drives to start on the TrueNAS side? Because it seems like that’s really what I need to do. And how should I set up the initial array to make the transition to the final array as smooth as possible?
As a side note, in case it makes a difference, the end goal is to move the Synology NAS files over to the TrueNAS system, and also recreating a bunch of Jellyfin/Radarr/Sonarr/etc. containers from a separate Proxmox box once the NAS files are transferred. Trying to consolidate these two separate systems into a single box. Just a small homelab and media server setup.
New TrueNAS system is going to be using a standard B550 mobo I’ve got laying around, looking at a Ryzen 5500 and 32GB of DDR4, and a PCIE SATA expansion card to add 12 SATA ports. The current 4x10TB drives are SATA, and don’t want to deal with adding SAS to the mix if I don’t have to.
I can provide other specific specs or information that would help clarify if needed. Trying to figure out what I actually need, with minimal cost here since its just for the house.
