SAS drive temperatures not shown in UI
Is there any way (or if not I guess plans?) to add SAS disk temperatures to the UI?
All my disks are SAS on LSI HBAs and while the temperatures show up via smartctl they are not present in the UI
Is the temp missing from the reporting tab, disk temperature metrics? I have a mix of m.2, SATA spinners, SAS spinners and SAS SSD’s and they all show temps. Running 24.10 RC2.
Yep that’s where they are missing from
disk IO all shows up
am on 24.04 scale
Did you ever solve this, I have this issue intermittently currently on version 24.10. Were you running any tests at the time? I am running an extended long SMART test on 2 of the drives, I was wondering if it is related to that. I can however query the drive temperature using smartctl commands via SSH.
I would report it as a bug either in the GUI (feedback smiley, upper right on dashboard) or Report A Bug on upper right of this forum.
@FakeNAS no, not running any tests the temperatures never show up. Are you disks also SAS?
and @SmallBarky I tried to do that but it requires a JIRA account so and then just sat on submitting forever when I created one so I gave up
Not using SAS, Using SATA WD HC580 over here. The issues I have with the drive temperature not showing have not repeated since long S.M.A.R.T test finished, will keep monitoring it.
Has anyone resolved this? I moved from Truenas Core to Scale, and now I have only 4 drives (of 17) reporting temperatures … SMART is on on all of them. I can get temp data from the shell … but I am afraid of not getting alerts.
Have You solved issue with temperature of SAS drivers ?
