Scale Dragonfish Upgrade?
Considering whether or not to upgrade my TrueNAS box. Running on 24.04.0 and it has been rock solid since fiddling with some swap settings a few months back. Should I make the jump to 24.04.2.3? Any “gotchas” to be aware of? The one part that I am most concerned about is ensuring that I don’t bork my MinIO container. 24.04.0 has been so stable that I’m a bit scared to “fix it” if it “ain’t broke.”
Thoughts?
Thanks :slight_smile:
Suck it and see.
You can rollback to the previous boot environment if you must.
Haha, sounds good.
Do the k3s containers have any nuances during minor version updates like this to be aware of? I didn’t see anything alarming in the release notes, so hopefully not?
Went for it. No issues. Easy peasy. :slight_smile:
