Scale with TRUENAS-X10-HA
Hello, we are retiring our TRUENAS-X10-HA at work and I was thinking of using it at home as a truenas scale box. I believe they told me this was not supported with Scale when I asked ixsystems but I was wondering if I could remove one controller and run it as a single and install scale on it keeping the other controller for a backup if the other controller fails on me.
hardware info:
Intel(R) Xeon(R) CPU D-1531 @ 2.20GHz
Platform: TRUENAS-X10-HA
Version:
TrueNAS-13.0-U6.7
Yes, you can run single-controller, but SCALE/Enterprise does work on the X-series HA just fine as well, provided you have a valid license key. You can contact our support team if you need to discuss that.
Thank you I just want to run Scale on it for testing purposes.
