Shell isnt accessible on 13.3
Hi everyone,
Yesterday after some disagrement with installation of new plugins (FreeBSD 13.2 was asked by plugin - “13.2-RELEASE not found”) I have decides to move manually to Truenas core 13.0 U6-2 for truenas core 13.3 (manually because that was not proposed by the system on update).
After the migration, all it’s ok but, on the web interface i don’t have access to the shell anymore. The logo not appear and adress 10.0.0.x/ui/shell not work and return 10.0.0.x/ui/dashboard.
Moreover, for the installation of new plugins, i have the same error “13.2-RELEASE not found”.
Do you have any solution to go back with a nas who can completely work.
Thx,
The shell has been removed in 13.3
Ok, thx a lot.
But whats the new solution for manage the system?
And do you have any solution for the FreeBsd issues?
SSH.
Plugins are dead, you either move to jails or to SCALE.
Install Putty or every other software
Plugins are eol, you can only install app directly on jails. There are a lot of community script that make this simple, otherwise think about migrate on Scale that now as rc2 supports docker container
Okay, thanks.
I just have a few last questions.
If i move to scale, what’s the more stable version ?
If i move to scale, nextcloud/transmition and other jail/plugins configuration are transmit to scale or do i have to reconfigure all of them from the start ?
Thanks a lot for your answers.
The truenas Community is really incredible !
If you can, wait some other time until a more stable version of rc2 will be released. Just for be 100% safe, but rc2 seems still usable on non mission critical system
Unlucky no. All manual work :melting_face:
You have to start from scratch.
Right now 24.04.2.2, but in a while a new version will come out with great improvements: I suggest waiting.
Unnecessary; Windows 10 and newer (and every other modern OS) includes a SSH client. In Windows, open a PowerShell window and ssh user@host.
24.04 is the current release. All the hype is about 24.10, but that’s still in prerelease status, and lots of us are hesitant to install a .0 release from iX.
What do you recommend I save? Are there any needs in truenas? and in the jails?
Truenas user settings, settings specific to nextcloud…
Because i need my jails but anything is no more stable and and i have many problems with no solutions
Yep, neither think about it. Thanks for the correction
IMHO wait a stable Scale release and for now “repair” your jails (should be the fastest way to back online).
What service you are running, only nextcloud? Do you have easy access to nextcloud data outside the jail?
