Hi (and happy new year)!
Issue:
One of my SMB shares with nested datasets doesn’t report the total space and used space correctly in windows explorer.
Soluton in Core:
I solved this then by appending an SMB additional parameter zfs_core:zfs_space_enabled = true as per this post.
Moving from CORE U6 to SCALE 24.10 SMB aux parameters have been removed and I have removed them before upgrading.
Question:
A) Is there any equivalent workaround in Scale or is it a windows shortcoming with ZFS as shown here?
B) Given that all my SMB shares with non-nested datasets are reported correctly, are nested datasets outside the correct usage scope of SMB in truenas? The Docs seems to hint at this, if I understood the warning, but I’d like some extra confirmation. I had used them because I could set recursive snapshots of the parent dataset.
Thanks (for both the insight and bearing with me)!
