System crashed after 25.10.4
installed update about 5 min after system was up, it paniced and crashed.
Trying to reboot. Need to know where the debug files are in order to send.
Please post more info on the system so others can offer advice. What did you upgrade from ?
You should be able to boot to a previous boot environment and try booting 25.10.4 again. Is this repeatable or was it a one time issue?
updated from 25.10.3.1. Its an older supermicro super server.
The errors on the screen were complaining about my 10g nic.
I just need to know where I can get the dump file and send it in.
I see a crash folder in var but noting got written to it.
You can try using Report a Bug but it will, most likely, be closed and you will be redirected to the forums for assistance in trying to diagnose your problem.
Full details on your hardware and a detailed description of the issue here. You didn’t say if it was repeatable. Did you check the release notes for 25.10.4 for any known issues?
We really can’t offer any more help without details and can only go off what is posted.
It’s in the very top bar of the TrueNAS UI, the Smiley-face feedback button.
Sending a bug report using that lets you include the relevant debug files, if any exist.
Crashing like you describe is abnormal, my guess is that it’s due to some form of hardware issue, but there’s really nothing in your posts to go on.
Best of luck figuring it out.
This was a power issue that caused the crash nothing with the software update.
