TrueNAS 25.04 SMB Access Problem
Hi, I am having problems with SMB after upgrading to 25.04. At a certain period of time access seems to freeze for a few seconds (5-20 seconds) then returns to normal, has anyone experienced this and is there a solution?
Thank you in advance.
Hardware specs please
Also - are you running dedupe?
Gigabyte B760M DS3H AX
12th Gen Intel(R) Core™ i5-12400
DDR5 16GB x 2
Ethernet 2.5Gbps
I’m not running deduplicate, only running syncthing Apps for BackUp to another TrueNAS Machine using LAN Cable.
Before the update to 25.04 everything was running normally and smoothly.
Solved using this solutions.
The problem with “default sharing parameters” is that the recycle bin cannot be enabled.
How is it possible to reactivate the recycle bin?
