“If it ain’t broken…”
If TOE works with FreeBSD 13 in CORE, there’s a very fair chance it will just keep working with FreeBSD 15 in FreeCORE.
Note that FreeCore is a single-person vibe-coded project that is not strictly built on FreeBSD either (at least from a brief glance at it). It’s layering for example large patchsets on top of my linux work in truenas samba with no SME involvement at all – not based on freebsd ports in this case. So there is a lot more risk to it in general than “it’s a continuation on freebsd”.
Yes, we tune for up to 800Gbps on our higher end systems, but don’t use the Chelsio specific stack including TOE. You may have to manually load the driver if thats an absolute requirement, but I’d suggest trying it out with the stock install first. The default networking stack is pretty well optimized out of box already, but if there’s any tweaks needed to the base we’re happy to get that feedback and look further ![]()
Thanks. I’ll give it a try in about two to three weeks. If TSO is supported, that should be enough for me to serve data at 10 Gbps, I believe (although TOE would likely halve CPU utilisation).
I checked Chelsio Support, and it appears that binary packages are only available for RHEL and SUSE. For other distributions, you need to compile the drivers and utilities yourself, so I don’t think this would be feasible on TrueNAS unless it’s already included in the distribution.
I haven’t tested any of the other Chelsio offloading capabilities, such as iSCSI or NVMe-oF, but you may find it worth exploring, given that most of their offloading features are NAS-oriented.
