TrueNAS Idle Power Savings - Zen 3 Ryzen CPU's ECC Ram, and Kill-A-Watt - An Adventure Begins
Then it must be a SCALE issue because I’m perfectly happy with my two C3758 under CORE.
That’s full load power, for a package which includes CPU, PCH and 10G NIC.
Let me say I doubt that your Xeon E3-1265L, its C23x chipset and 10G NIC together can idle at that level.
Nope, far from that. About 60% while replicating from one to the other.
Nothing but a scrub can bring a C3758 at 100% on all cores.
I don’t remember about 2024, but C3758 is still very attractive in 2026. :wink:
What’s a NAS about if not storage?
nice dream, unfortunately the $300 W880D4U has only 2x 1gbe.
W880D4U-2L2Q with 2x 25gb SFP28 is closer to $600 mark, if you can find it :wink:
W880D4U-2L2T with 2x10gbe rj45 is $568 at newegg
all dreams with today’s ram prices - I sold old 2x8GB ddr4s for more than I bought them new 4 years ago!
Op was asking for platform to run TrueNas AND couple of VMs and couple of docker containers. way outside of C3758 comfort zone, some lightweight docker would be fine but VM’s would be real stretch, doable but not optimal platform for it.
@Mark_the_Red has showed us one option for power efficient computing - and the various tiers of Ryzen G and GE chips allow the end user to tailor the CPU brawn to the use case.
For that reason alone, it is likely a superior approach to embedded systems where the whole motherboard has to be chucked if a need cannot be accommodated by the CPU.
With the benefit of hindsight, I should have selected the -2c- version of my current motherboard. It would have been better suited to the file server mission with a higher clock speed than the D-1537.
But, I thought I’d be able to run a windows VM and/or Zoneminder, neither of which worked well.
For any new system, I’d likely go with a bare motherboard and add a HBA and NIC, along with a removable CPU to allow me to customize the board to my needs rather than being locked into a particular motherboard for all three.
Whether that’s Ryzen or Intel based isn’t the question. It’s more a matter of what works for the use case and is flexible enough to accommodate changes as the use case may wander in the future.
