TrueNAS keeps randomly crashing
Hi Forum,
I have a TrueNAS system with 6 SATA HDD as raidz2 pool and one nvme SSD as boot drive.
The system is randomly hanging, not reachable via network and also console is blank and does not respond. My first guess was that it is related to the onboard SATA ports, so I installed a NVME to SATA board and connected all 6 SATA drives to it.
But it does not seem to be the probem.
I had this since the first install (25.04) throughout the current version. It’s unpredictable, some times the system is up for 1 or two weeks and sometimes a few days only.
“last reboot” shows a lot of boots as “still running”, I guess there are the crashes:
# last reboot
reboot   system boot  6.12.33-producti Mon Jan 12 08:22   still running
reboot   system boot  6.12.33-producti Fri Jan  9 14:04   still running
reboot   system boot  6.12.33-producti Wed Jan  7 05:10   still running
reboot   system boot  6.12.33-producti Sun Jan  4 05:18   still running
reboot   system boot  6.12.33-producti Fri Jan  2 04:18   still running
reboot   system boot  6.12.33-producti Mon Dec 22 18:37   still running
reboot   system boot  6.12.33-producti Tue Dec  9 11:05   still running
reboot   system boot  6.12.33-producti Wed Nov 26 16:03   still running
reboot   system boot  6.12.33-producti Sat Nov 22 13:37   still running
reboot   system boot  6.12.33-producti Fri Nov 21 11:30   still running
reboot   system boot  6.12.33-producti Fri Nov 21 08:29   still running
How can I find out, what’s the reson for the crashes?
Many thanks!
Welcome to the forums.
Can you please share the hardware specifications of the system you’re running TrueNAS on? Without these specifications, it’s not possible to start diagnosing possible problems with your system.
Also, if possible, can you please share your dmesg output, since it might contain some valuable information prior to crash.
I would strongly consider to test stability of the system with a memtest, rather than chasing the rabbit down the hole :smile: This exclude fast a lot of bad things
Here’s the config:
Motherboard: N100 NAS Motherboard, NAS Motherboard CPU Combination, Mini ITX Motherboard with intl N100, Mini ITX Board for NAS Server DIY with CPU Fan, No RAM, No Memory: Amazon.de: Computer & Accessories
RAM: Samsung 32GB Ram DDR5 RAM 4800MHz
Boot SSD Crucial P3 Plus 2TB NVMe (PCIe)
NVMe to SATA Adapter: Namvo M2 NGFF NVME M-Key PCI Express to SATA 3.0 6Gbps 6 Ports Adapter Converter Hard Drive Extension Card : Amazon.de: Computer & Accessories
Harddisks: 6x 4TB WD Red (WD40EFPX/WD40EFRX)
and dmesg output (part 1):
[    0.000000] Linux version 6.12.33-production+truenas (root@tnsbuilds02) (gcc (Debian 12.2.0-14+deb12u1) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC Wed Dec 17 21:17:21 UTC 2025
[    0.000000] Command line: BOOT_IMAGE=/ROOT/25.10.1@/boot/vmlinuz-6.12.33-production+truenas root=ZFS=boot-pool/ROOT/25.10.1 ro libata.allow_tpm=1 amd_iommu=on iommu=pt kvm_amd.npt=1 kvm_amd.avic=1 intel_iommu=on zfsforce=1 nvme_core.multipath=N
[    0.000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009efff] reserved
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000004035bfff] usable
[    0.000000] BIOS-e820: [mem 0x000000004035c000-0x000000004035cfff] reserved
[    0.000000] BIOS-e820: [mem 0x000000004035d000-0x0000000040392fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000040393000-0x0000000040393fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000040394000-0x0000000071e5bfff] usable
[    0.000000] BIOS-e820: [mem 0x0000000071e5c000-0x0000000074f5bfff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000074f5c000-0x000000007503dfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000007503e000-0x00000000750fdfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000750fe000-0x0000000075ffefff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000075fff000-0x0000000075ffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000076000000-0x0000000079ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007aa00000-0x000000007abfffff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007b000000-0x00000000803fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000087fbfffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] APIC: Static calls initialized
[    0.000000] e820: update [mem 0x6419a018-0x641ae057] usable ==> usable
[    0.000000] extended physical RAM map:
[    0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000009dfff] usable
[    0.000000] reserve setup_data: [mem 0x000000000009e000-0x000000000009efff] reserved
[    0.000000] reserve setup_data: [mem 0x000000000009f000-0x000000000009ffff] usable
[    0.000000] reserve setup_data: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000000100000-0x000000004035bfff] usable
[    0.000000] reserve setup_data: [mem 0x000000004035c000-0x000000004035cfff] reserved
[    0.000000] reserve setup_data: [mem 0x000000004035d000-0x0000000040392fff] usable
[    0.000000] reserve setup_data: [mem 0x0000000040393000-0x0000000040393fff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000040394000-0x000000006419a017] usable
[    0.000000] reserve setup_data: [mem 0x000000006419a018-0x00000000641ae057] usable
[    0.000000] reserve setup_data: [mem 0x00000000641ae058-0x0000000071e5bfff] usable
[    0.000000] reserve setup_data: [mem 0x0000000071e5c000-0x0000000074f5bfff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000074f5c000-0x000000007503dfff] ACPI data
[    0.000000] reserve setup_data: [mem 0x000000007503e000-0x00000000750fdfff] ACPI NVS
[    0.000000] reserve setup_data: [mem 0x00000000750fe000-0x0000000075ffefff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000075fff000-0x0000000075ffffff] usable
[    0.000000] reserve setup_data: [mem 0x0000000076000000-0x0000000079ffffff] reserved
[    0.000000] reserve setup_data: [mem 0x000000007aa00000-0x000000007abfffff] reserved
[    0.000000] reserve setup_data: [mem 0x000000007b000000-0x00000000803fffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000087fbfffff] usable
[    0.000000] efi: EFI v2.8 by American Megatrends
[    0.000000] efi: ACPI=0x750da000 ACPI 2.0=0x750da014 TPMFinalLog=0x750a9000 SMBIOS=0x75cc4000 SMBIOS 3.0=0x75cc3000 MEMATTR=0x641c0698 ESRT=0x6e6f9b98 MOKvar=0x75cee000 INITRD=0x641bd118 TPMEventLog=0x74f86018
[    0.000000] efi: Remove mem75: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
[    0.000000] e820: remove [mem 0xc0000000-0xcfffffff] reserved
[    0.000000] efi: Not removing mem76: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e820 map
[    0.000000] efi: Not removing mem77: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem78: MMIO range=[0xfed00000-0xfed00fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem80: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[    0.000000] efi: Remove mem81: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
[    0.000000] e820: remove [mem 0xff000000-0xffffffff] reserved
[    0.000000] secureboot: Secure boot disabled
[    0.000000] SMBIOS 3.5.0 present.
[    0.000000] DMI: Default string Default string/Default string, BIOS 5.27 12/21/2023
[    0.000000] DMI: Memory slots populated: 1/2
[    0.000000] tsc: Detected 800.000 MHz processor
[    0.000000] tsc: Detected 806.400 MHz TSC
[    0.000132] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000134] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000144] last_pfn = 0x87fc00 max_arch_pfn = 0x400000000
[    0.000147] MTRR map: 6 entries (3 fixed + 3 variable; max 23), built from 10 variable MTRRs
[    0.000149] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000253] last_pfn = 0x76000 max_arch_pfn = 0x400000000
[    0.009145] esrt: Reserving ESRT space from 0x000000006e6f9b98 to 0x000000006e6f9c70.
[    0.009150] e820: update [mem 0x6e6f9000-0x6e6f9fff] usable ==> reserved
[    0.009168] Using GB pages for direct mapping
[    0.009718] RAMDISK: [mem 0x58a17000-0x5dab2fff]
[    0.009722] ACPI: Early table checksum verification disabled
[    0.009725] ACPI: RSDP 0x00000000750DA014 000024 (v02 ALASKA)
[    0.009728] ACPI: XSDT 0x00000000750D9728 000104 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.009733] ACPI: FACP 0x000000007503B000 000114 (v06 ALASKA A M I    01072009 AMI  01000013)
[    0.009736] ACPI: DSDT 0x0000000074FC5000 07548A (v02 ALASKA A M I    01072009 INTL 20200717)
[    0.009738] ACPI: FACS 0x00000000750FD000 000040
[    0.009740] ACPI: FIDT 0x0000000074FC4000 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.009742] ACPI: SSDT 0x000000007503D000 00038C (v02 PmaxDv Pmax_Dev 00000001 INTL 20200717)
[    0.009744] ACPI: SSDT 0x0000000074FBE000 005D0B (v02 CpuRef CpuSsdt  00003000 INTL 20200717)
[    0.009746] ACPI: SSDT 0x0000000074FBB000 002935 (v02 SaSsdt SaSsdt   00003000 INTL 20200717)
[    0.009748] ACPI: SSDT 0x0000000074FB7000 0033D7 (v02 INTEL  IgfxSsdt 00003000 INTL 20200717)
[    0.009749] ACPI: SSDT 0x0000000074FA9000 00D487 (v02 INTEL  TcssSsdt 00001000 INTL 20200717)
[    0.009751] ACPI: HPET 0x000000007503C000 000038 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.009753] ACPI: APIC 0x0000000074FA8000 0001DC (v05 ALASKA A M I    01072009 AMI  01000013)
[    0.009755] ACPI: MCFG 0x0000000074FA7000 00003C (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.009756] ACPI: SSDT 0x0000000074FA5000 001F1A (v02 ALASKA Ther_Rvp 00001000 INTL 20200717)
[    0.009758] ACPI: UEFI 0x0000000075090000 000048 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.009760] ACPI: NHLT 0x0000000074FA4000 00002D (v00 ALASKA A M I    01072009 AMI  01000013)
[    0.009762] ACPI: LPIT 0x0000000074FA3000 0000CC (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.009763] ACPI: SSDT 0x0000000074F9F000 002A83 (v02 ALASKA PtidDevc 00001000 INTL 20200717)
[    0.009765] ACPI: SSDT 0x0000000074F9C000 002357 (v02 ALASKA TbtTypeC 00000000 INTL 20200717)
[    0.009767] ACPI: DBGP 0x0000000074F9B000 000034 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.009769] ACPI: DBG2 0x0000000074F9A000 00005C (v00 ALASKA A M I    01072009 AMI  01000013)
[    0.009771] ACPI: SSDT 0x0000000074F98000 001919 (v02 ALASKA UsbCTabl 00001000 INTL 20200717)
[    0.009773] ACPI: DMAR 0x0000000074F97000 000088 (v02 INTEL  EDK2     00000002      01000013)
[    0.009775] ACPI: FPDT 0x0000000074F96000 000044 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.009776] ACPI: SSDT 0x0000000074F95000 00073A (v02 INTEL  xh_adl_N 00000000 INTL 20200717)
[    0.009778] ACPI: SSDT 0x0000000074F91000 003AEA (v02 SocGpe SocGpe   00003000 INTL 20200717)
[    0.009780] ACPI: SSDT 0x0000000074F8D000 0039DA (v02 SocCmn SocCmn   00003000 INTL 20200717)
[    0.009782] ACPI: SSDT 0x0000000074F8C000 000144 (v02 Intel  ADebTabl 00001000 INTL 20200717)
[    0.009783] ACPI: TPM2 0x0000000074F8B000 00004C (v04 ALASKA A M I    00000001 AMI  00000000)
[    0.009785] ACPI: PHAT 0x0000000074F8A000 000611 (v01 ALASKA A M I    00000005 MSFT 0100000D)
[    0.009787] ACPI: WSMT 0x0000000074FA2000 000028 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.009788] ACPI: Reserving FACP table memory at [mem 0x7503b000-0x7503b113]
[    0.009790] ACPI: Reserving DSDT table memory at [mem 0x74fc5000-0x7503a489]
[    0.009790] ACPI: Reserving FACS table memory at [mem 0x750fd000-0x750fd03f]
[    0.009791] ACPI: Reserving FIDT table memory at [mem 0x74fc4000-0x74fc409b]
[    0.009792] ACPI: Reserving SSDT table memory at [mem 0x7503d000-0x7503d38b]
[    0.009792] ACPI: Reserving SSDT table memory at [mem 0x74fbe000-0x74fc3d0a]
[    0.009793] ACPI: Reserving SSDT table memory at [mem 0x74fbb000-0x74fbd934]
[    0.009793] ACPI: Reserving SSDT table memory at [mem 0x74fb7000-0x74fba3d6]
[    0.009794] ACPI: Reserving SSDT table memory at [mem 0x74fa9000-0x74fb6486]
[    0.009795] ACPI: Reserving HPET table memory at [mem 0x7503c000-0x7503c037]
[    0.009795] ACPI: Reserving APIC table memory at [mem 0x74fa8000-0x74fa81db]
[    0.009796] ACPI: Reserving MCFG table memory at [mem 0x74fa7000-0x74fa703b]
[    0.009796] ACPI: Reserving SSDT table memory at [mem 0x74fa5000-0x74fa6f19]
[    0.009797] ACPI: Reserving UEFI table memory at [mem 0x75090000-0x75090047]
[    0.009797] ACPI: Reserving NHLT table memory at [mem 0x74fa4000-0x74fa402c]
[    0.009798] ACPI: Reserving LPIT table memory at [mem 0x74fa3000-0x74fa30cb]
[    0.009798] ACPI: Reserving SSDT table memory at [mem 0x74f9f000-0x74fa1a82]
[    0.009799] ACPI: Reserving SSDT table memory at [mem 0x74f9c000-0x74f9e356]
[    0.009800] ACPI: Reserving DBGP table memory at [mem 0x74f9b000-0x74f9b033]
[    0.009800] ACPI: Reserving DBG2 table memory at [mem 0x74f9a000-0x74f9a05b]
[    0.009801] ACPI: Reserving SSDT table memory at [mem 0x74f98000-0x74f99918]
[    0.009801] ACPI: Reserving DMAR table memory at [mem 0x74f97000-0x74f97087]
[    0.009802] ACPI: Reserving FPDT table memory at [mem 0x74f96000-0x74f96043]
[    0.009802] ACPI: Reserving SSDT table memory at [mem 0x74f95000-0x74f95739]
[    0.009803] ACPI: Reserving SSDT table memory at [mem 0x74f91000-0x74f94ae9]
[    0.009804] ACPI: Reserving SSDT table memory at [mem 0x74f8d000-0x74f909d9]
[    0.009804] ACPI: Reserving SSDT table memory at [mem 0x74f8c000-0x74f8c143]
[    0.009805] ACPI: Reserving TPM2 table memory at [mem 0x74f8b000-0x74f8b04b]
[    0.009805] ACPI: Reserving PHAT table memory at [mem 0x74f8a000-0x74f8a610]
[    0.009806] ACPI: Reserving WSMT table memory at [mem 0x74fa2000-0x74fa2027]
[    0.009957] No NUMA configuration found
[    0.009958] Faking a node at [mem 0x0000000000000000-0x000000087fbfffff]
[    0.009967] NODE_DATA(0) allocated [mem 0x87fbd4b40-0x87fbfffff]
[    0.010124] cma: Reserved 256 MiB at 0x0000000100000000 on node -1
[    0.010161] Zone ranges:
[    0.010162]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.010163]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.010164]   Normal   [mem 0x0000000100000000-0x000000087fbfffff]
[    0.010165]   Device   empty
[    0.010166] Movable zone start for each node
[    0.010167] Early memory node ranges
[    0.010168]   node   0: [mem 0x0000000000001000-0x000000000009dfff]
[    0.010169]   node   0: [mem 0x000000000009f000-0x000000000009ffff]
[    0.010170]   node   0: [mem 0x0000000000100000-0x000000004035bfff]
[    0.010171]   node   0: [mem 0x000000004035d000-0x0000000040392fff]
[    0.010171]   node   0: [mem 0x0000000040394000-0x0000000071e5bfff]
[    0.010172]   node   0: [mem 0x0000000075fff000-0x0000000075ffffff]
[    0.010172]   node   0: [mem 0x0000000100000000-0x000000087fbfffff]
[    0.010175] Initmem setup node 0 [mem 0x0000000000001000-0x000000087fbfffff]
[    0.010179] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.010181] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.010200] On node 0, zone DMA: 96 pages in unavailable ranges
[    0.011605] On node 0, zone DMA32: 1 pages in unavailable ranges
[    0.012786] On node 0, zone DMA32: 1 pages in unavailable ranges
[    0.012925] On node 0, zone DMA32: 16803 pages in unavailable ranges
[    0.013220] On node 0, zone Normal: 8192 pages in unavailable ranges
[    0.013231] On node 0, zone Normal: 1024 pages in unavailable ranges
[    0.013252] Reserving Intel graphics memory at [mem 0x7c800000-0x803fffff]
[    0.013602] ACPI: PM-Timer IO Port: 0x1808
[    0.013611] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.013613] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.013613] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.013614] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.013614] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.013615] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.013615] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.013616] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.013617] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.013617] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.013618] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.013618] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.013619] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.013619] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.013620] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.013620] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.013621] ACPI: LAPIC_NMI (acpi_id[0x11] high edge lint[0x1])
[    0.013621] ACPI: LAPIC_NMI (acpi_id[0x12] high edge lint[0x1])
[    0.013622] ACPI: LAPIC_NMI (acpi_id[0x13] high edge lint[0x1])
[    0.013622] ACPI: LAPIC_NMI (acpi_id[0x14] high edge lint[0x1])
[    0.013623] ACPI: LAPIC_NMI (acpi_id[0x15] high edge lint[0x1])
[    0.013623] ACPI: LAPIC_NMI (acpi_id[0x16] high edge lint[0x1])
[    0.013624] ACPI: LAPIC_NMI (acpi_id[0x17] high edge lint[0x1])
[    0.013624] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.013663] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.013665] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.013667] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.013670] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.013671] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.013675] TSC deadline timer available
[    0.013678] CPU topo: Max. logical packages:   1
[    0.013679] CPU topo: Max. logical dies:       1
[    0.013679] CPU topo: Max. dies per package:   1
[    0.013683] CPU topo: Max. threads per core:   1
[    0.013684] CPU topo: Num. cores per package:     4
[    0.013684] CPU topo: Num. threads per package:   4
[    0.013684] CPU topo: Allowing 4 present CPUs plus 0 hotplug CPUs
[    0.013702] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.013704] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[    0.013705] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.013706] PM: hibernation: Registered nosave memory: [mem 0x4035c000-0x4035cfff]
[    0.013708] PM: hibernation: Registered nosave memory: [mem 0x40393000-0x40393fff]
[    0.013709] PM: hibernation: Registered nosave memory: [mem 0x6e6f9000-0x6e6f9fff]
[    0.013710] PM: hibernation: Registered nosave memory: [mem 0x71e5c000-0x75ffefff]
[    0.013711] PM: hibernation: Registered nosave memory: [mem 0x76000000-0xffffffff]
[    0.013713] [mem 0x80400000-0xfdffffff] available for PCI devices
[    0.013715] Booting paravirtualized kernel on bare hardware
[    0.013717] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.018085] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[    0.018348] percpu: Embedded 66 pages/cpu s233472 r8192 d28672 u524288
[    0.018355] pcpu-alloc: s233472 r8192 d28672 u524288 alloc=1*2097152
[    0.018358] pcpu-alloc: [0] 0 1 2 3
[    0.018373] Kernel command line: BOOT_IMAGE=/ROOT/25.10.1@/boot/vmlinuz-6.12.33-production+truenas root=ZFS=boot-pool/ROOT/25.10.1 ro libata.allow_tpm=1 amd_iommu=on iommu=pt kvm_amd.npt=1 kvm_amd.avic=1 intel_iommu=on zfsforce=1 nvme_core.multipath=N
[    0.018423] AMD-Vi: Unknown option - 'on'
[    0.018465] DMAR: IOMMU enabled
[    0.018489] Unknown kernel command line parameters "BOOT_IMAGE=/ROOT/25.10.1@/boot/vmlinuz-6.12.33-production+truenas zfsforce=1", will be passed to user space.
[    0.018501] random: crng init done
[    0.021363] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.022816] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.022867] Fallback order for Node 0: 0
[    0.022870] Built 1 zonelists, mobility grouping on.  Total pages: 8329721
[    0.022871] Policy zone: Normal
[    0.022873] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.022881] software IO TLB: area num 4.
[    0.043348] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.043373] ftrace: allocating 45371 entries in 178 pages
[    0.046386] ftrace: allocated 178 pages with 4 groups
[    0.046782] Dynamic Preempt: voluntary
[    0.046814] rcu: Preemptible hierarchical RCU implementation.
[    0.046814] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
[    0.046815] 	Trampoline variant of Tasks RCU enabled.
[    0.046816] 	Rude variant of Tasks RCU enabled.
[    0.046816] 	Tracing variant of Tasks RCU enabled.
[    0.046817] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.046817] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.046824] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.046825] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.046827] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.049485] NR_IRQS: 524544, nr_irqs: 1024, preallocated irqs: 16
[    0.049784] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.050007] Console: colour dummy device 80x25
[    0.050010] printk: legacy console [tty0] enabled
[    0.050066] ACPI: Core revision 20240827
[    0.050451] hpet: HPET dysfunctional in PC10. Force disabled.
[    0.050534] APIC: Switch to symmetric I/O mode setup
[    0.050536] DMAR: Host address width 39
[    0.050537] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.050544] DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 29a00f0505e
[    0.050546] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.050551] DMAR: dmar1: reg_base_addr fed91000 ver 5:0 cap d2008c40660462 ecap f050da
[    0.050553] DMAR: RMRR base: 0x0000007c000000 end: 0x000000803fffff
[    0.050555] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.050557] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.050558] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.052268] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.052271] x2apic enabled
[    0.052324] APIC: Switched APIC routing to: cluster x2apic
[    0.056937] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0xb9fb05486c, max_idle_ns: 440795231721 ns
[    0.056946] Calibrating delay loop (skipped), value calculated using timer frequency.. 1612.80 BogoMIPS (lpj=3225600)
[    0.056979] CPU0: Thermal monitoring enabled (TM1)
[    0.056981] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[    0.057058] CET detected: Indirect Branch Tracking enabled
[    0.057060] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[    0.057061] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[    0.057065] process: using mwait in idle threads
[    0.057067] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.057069] Spectre V2 : Mitigation: Enhanced / Automatic IBRS
[    0.057072] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.057074] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.057075] Register File Data Sampling: Mitigation: Clear Register File
[    0.057083] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.057084] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.057085] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.057086] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[    0.057087] x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
[    0.057088] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.057090] x86/fpu: xstate_offset[9]:  832, xstate_sizes[9]:    8
[    0.057091] x86/fpu: xstate_offset[11]:  840, xstate_sizes[11]:   16
[    0.057093] x86/fpu: Enabled xstate features 0xa07, context size is 856 bytes, using 'compacted' format.
[    0.060942] Freeing SMP alternatives memory: 40K
[    0.060942] pid_max: default: 32768 minimum: 301
[    0.060942] LSM: initializing lsm=lockdown,capability,landlock,yama,apparmor,tomoyo,bpf,ipe,ima,evm
[    0.060942] landlock: Up and running.
[    0.060942] Yama: becoming mindful.
[    0.060942] AppArmor: AppArmor initialized
[    0.060942] TOMOYO Linux initialized
[    0.060942] LSM support for eBPF active
[    0.060942] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.060942] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.060942] smpboot: CPU0: Intel(R) N100 (family: 0x6, model: 0xbe, stepping: 0x0)
[    0.060942] Performance Events: XSAVE Architectural LBR, PEBS fmt4+-baseline, PEBS-via-PT,  AnyThread deprecated, Gracemont events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.060942] ... version:                5
[    0.060942] ... bit width:              48
[    0.060942] ... generic registers:      6
[    0.060942] ... value mask:             0000ffffffffffff
[    0.060942] ... max period:             00007fffffffffff
[    0.060942] ... fixed-purpose events:   3
[    0.060942] ... event mask:             000000070000003f
[    0.060942] signal: max sigframe size: 3632
[    0.060942] Estimated ratio of average max frequency by base frequency (times 1024): 3712
[    0.060942] rcu: Hierarchical SRCU implementation.
[    0.060942] rcu: 	Max phase no-delay instances is 1000.
[    0.060942] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.060942] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.060942] smp: Bringing up secondary CPUs ...
[    0.060942] smpboot: x86: Booting SMP configuration:
[    0.060942] .... node  #0, CPUs:      #1 #2 #3
[    0.060973] smp: Brought up 1 node, 4 CPUs
[    0.060973] smpboot: Total of 4 processors activated (6451.20 BogoMIPS)
[    0.139209] node 0 deferred pages initialised in 76ms
[    0.139264] Memory: 32277728K/33318884K available (16384K kernel code, 2484K rwdata, 11592K rodata, 4232K init, 5012K bss, 767400K reserved, 262144K cma-reserved)
[    0.139264] devtmpfs: initialized
[    0.139264] x86/mm: Memory block size: 128MB
[    0.142027] ACPI: PM: Registering ACPI NVS region [mem 0x7503e000-0x750fdfff] (786432 bytes)
[    0.142027] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.142027] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.142027] pinctrl core: initialized pinctrl subsystem
[    0.142448] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.142606] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.142606] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.142606] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.142606] audit: initializing netlink subsys (disabled)
[    0.142606] audit: type=2000 audit(1768209363.000:1): state=initialized audit_enabled=0 res=1
[    0.142606] thermal_sys: Registered thermal governor 'fair_share'
[    0.142606] thermal_sys: Registered thermal governor 'bang_bang'
[    0.142606] thermal_sys: Registered thermal governor 'step_wise'
[    0.142606] thermal_sys: Registered thermal governor 'user_space'
[    0.142606] thermal_sys: Registered thermal governor 'power_allocator'
[    0.142606] cpuidle: using governor ladder
[    0.142606] cpuidle: using governor menu
[    0.142606] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.142606] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.142606] PCI: ECAM [mem 0xc0000000-0xcfffffff] (base 0xc0000000) for domain 0000 [bus 00-ff]
[    0.142606] PCI: Using configuration type 1 for base access
[    0.142606] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.142606] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.142606] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.142606] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.142606] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.142606] ACPI: Added _OSI(Module Device)
[    0.142606] ACPI: Added _OSI(Processor Device)
[    0.142606] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.142606] ACPI: Added _OSI(Processor Aggregator Device)
[    0.248439] ACPI: 14 ACPI AML tables successfully acquired and loaded
[    0.264297] ACPI: Dynamic OEM Table Load:
[    0.264306] ACPI: SSDT 0xFFFF8E3390C10C00 000394 (v02 PmRef  Cpu0Cst  00003001 INTL 20200717)
[    0.265228] ACPI: Dynamic OEM Table Load:
[    0.265233] ACPI: SSDT 0xFFFF8E366C3DBE00 0001A3 (v02 PmRef  Cpu0Ist  00003000 INTL 20200717)
[    0.266107] ACPI: Dynamic OEM Table Load:
[    0.266112] ACPI: SSDT 0xFFFF8E366C3DB600 0001AB (v02 PmRef  Cpu0Psd  00003000 INTL 20200717)
[    0.266987] ACPI: Dynamic OEM Table Load:
[    0.266992] ACPI: SSDT 0xFFFF8E3390C6D800 0004B5 (v02 PmRef  Cpu0Hwp  00003000 INTL 20200717)
[    0.268207] ACPI: Dynamic OEM Table Load:
[    0.268215] ACPI: SSDT 0xFFFF8E366C32C000 001BAF (v02 PmRef  ApIst    00003000 INTL 20200717)
[    0.269631] ACPI: Dynamic OEM Table Load:
[    0.269637] ACPI: SSDT 0xFFFF8E3390C72000 001038 (v02 PmRef  ApHwp    00003000 INTL 20200717)
[    0.270900] ACPI: Dynamic OEM Table Load:
[    0.270906] ACPI: SSDT 0xFFFF8E3390C74000 001349 (v02 PmRef  ApPsd    00003000 INTL 20200717)
[    0.272227] ACPI: Dynamic OEM Table Load:
[    0.272232] ACPI: SSDT 0xFFFF8E3390183000 000FBB (v02 PmRef  ApCst    00003000 INTL 20200717)
[    0.275339] ACPI: Interpreter enabled
[    0.275409] ACPI: PM: (supports S0 S5)
[    0.275411] ACPI: Using IOAPIC for interrupt routing
[    0.275465] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.275467] PCI: Ignoring E820 reservations for host bridge windows
[    0.276664] ACPI: Enabled 7 GPEs in block 00 to 7F
[    0.305567] ACPI: \_SB_.PC00.CNVW.WRST: New power resource
[    0.314113] ACPI: \_SB_.PC00.TBT0: New power resource
[    0.314493] ACPI: \_SB_.PC00.TBT1: New power resource
[    0.364719] ACPI: \_TZ_.FN00: New power resource
[    0.364771] ACPI: \_TZ_.FN01: New power resource
[    0.364819] ACPI: \_TZ_.FN02: New power resource
[    0.364867] ACPI: \_TZ_.FN03: New power resource
[    0.364914] ACPI: \_TZ_.FN04: New power resource
[    0.365360] ACPI: \PIN_: New power resource
[    0.365616] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-fe])
[    0.365623] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[    0.365825] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME AER]
[    0.366197] acpi PNP0A08:00: _OSC: OS now controls [PCIeCapability LTR]
[    0.366199] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.370787] PCI host bridge to bus 0000:00
[    0.370791] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.370793] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.370795] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.370796] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff window]
[    0.370797] pci_bus 0000:00: root bus resource [mem 0x80400000-0xbfffffff window]
[    0.370799] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[    0.370800] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.370834] pci 0000:00:00.0: [8086:461c] type 00 class 0x060000 conventional PCI endpoint
[    0.370975] pci 0000:00:02.0: [8086:46d1] type 00 class 0x030000 PCIe Root Complex Integrated Endpoint
[    0.370985] pci 0000:00:02.0: BAR 0 [mem 0x6000000000-0x6000ffffff 64bit]
[    0.370990] pci 0000:00:02.0: BAR 2 [mem 0x4000000000-0x400fffffff 64bit pref]
[    0.370994] pci 0000:00:02.0: BAR 4 [io  0x4000-0x403f]
[    0.371011] pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
[    0.371013] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.371040] pci 0000:00:02.0: VF BAR 0 [mem 0x00000000-0x00ffffff 64bit]
[    0.371042] pci 0000:00:02.0: VF BAR 0 [mem 0x00000000-0x06ffffff 64bit]: contains BAR 0 for 7 VFs
[    0.371047] pci 0000:00:02.0: VF BAR 2 [mem 0x00000000-0x1fffffff 64bit pref]
[    0.371048] pci 0000:00:02.0: VF BAR 2 [mem 0x00000000-0xdfffffff 64bit pref]: contains BAR 2 for 7 VFs
[    0.371215] pci 0000:00:0d.0: [8086:464e] type 00 class 0x0c0330 conventional PCI endpoint
[    0.371226] pci 0000:00:0d.0: BAR 0 [mem 0x6001110000-0x600111ffff 64bit]
[    0.371269] pci 0000:00:0d.0: PME# supported from D3hot D3cold
[    0.373272] pci 0000:00:14.0: [8086:54ed] type 00 class 0x0c0330 conventional PCI endpoint
[    0.373295] pci 0000:00:14.0: BAR 0 [mem 0x6001100000-0x600110ffff 64bit]
[    0.373382] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.375354] pci 0000:00:14.2: [8086:54ef] type 00 class 0x050000 conventional PCI endpoint
[    0.375376] pci 0000:00:14.2: BAR 0 [mem 0x6001124000-0x6001127fff 64bit]
[    0.375389] pci 0000:00:14.2: BAR 2 [mem 0x600112a000-0x600112afff 64bit]
[    0.375521] pci 0000:00:16.0: [8086:54e0] type 00 class 0x078000 conventional PCI endpoint
[    0.375545] pci 0000:00:16.0: BAR 0 [mem 0x6001129000-0x6001129fff 64bit]
[    0.375632] pci 0000:00:16.0: PME# supported from D3hot
[    0.376133] pci 0000:00:17.0: [8086:54d3] type 00 class 0x010601 conventional PCI endpoint
[    0.376150] pci 0000:00:17.0: BAR 0 [mem 0x81300000-0x81301fff]
[    0.376160] pci 0000:00:17.0: BAR 1 [mem 0x81303000-0x813030ff]
[    0.376169] pci 0000:00:17.0: BAR 2 [io  0x4090-0x4097]
[    0.376178] pci 0000:00:17.0: BAR 3 [io  0x4080-0x4083]
[    0.376187] pci 0000:00:17.0: BAR 4 [io  0x4060-0x407f]
[    0.376197] pci 0000:00:17.0: BAR 5 [mem 0x81302000-0x813027ff]
[    0.376246] pci 0000:00:17.0: PME# supported from D3hot
[    0.376513] pci 0000:00:1c.0: [8086:54b8] type 01 class 0x060400 PCIe Root Port
[    0.376541] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.376548] pci 0000:00:1c.0:   bridge window [mem 0x80d00000-0x80ffffff]
[    0.376630] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.376664] pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
[    0.377133] pci 0000:00:1c.1: [8086:54b9] type 01 class 0x060400 PCIe Root Port
[    0.377162] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.377168] pci 0000:00:1c.1:   bridge window [mem 0x80a00000-0x80cfffff]
[    0.377249] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[    0.377284] pci 0000:00:1c.1: PTM enabled (root), 4ns granularity
[    0.377726] pci 0000:00:1c.2: [8086:54ba] type 01 class 0x060400 PCIe Root Port
[    0.377754] pci 0000:00:1c.2: PCI bridge to [bus 03]
[    0.377760] pci 0000:00:1c.2:   bridge window [mem 0x80700000-0x809fffff]
[    0.377841] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    0.377875] pci 0000:00:1c.2: PTM enabled (root), 4ns granularity
[    0.378312] pci 0000:00:1c.3: [8086:54bb] type 01 class 0x060400 PCIe Root Port
[    0.378340] pci 0000:00:1c.3: PCI bridge to [bus 04]
[    0.378346] pci 0000:00:1c.3:   bridge window [mem 0x80400000-0x806fffff]
[    0.378427] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.378460] pci 0000:00:1c.3: PTM enabled (root), 4ns granularity
[    0.378910] pci 0000:00:1c.6: [8086:54be] type 01 class 0x060400 PCIe Root Port
[    0.378938] pci 0000:00:1c.6: PCI bridge to [bus 05]
[    0.378942] pci 0000:00:1c.6:   bridge window [io  0x3000-0x3fff]
[    0.378945] pci 0000:00:1c.6:   bridge window [mem 0x81200000-0x812fffff]
[    0.379026] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[    0.379059] pci 0000:00:1c.6: PTM enabled (root), 4ns granularity
[    0.379511] pci 0000:00:1d.0: [8086:54b1] type 01 class 0x060400 PCIe Root Port
[    0.379539] pci 0000:00:1d.0: PCI bridge to [bus 06]
[    0.379545] pci 0000:00:1d.0:   bridge window [mem 0x81100000-0x811fffff]
[    0.379625] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.379659] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[    0.380100] pci 0000:00:1d.2: [8086:54b2] type 01 class 0x060400 PCIe Root Port
[    0.380128] pci 0000:00:1d.2: PCI bridge to [bus 07]
[    0.380133] pci 0000:00:1d.2:   bridge window [mem 0x81000000-0x810fffff]
[    0.380214] pci 0000:00:1d.2: PME# supported from D0 D3hot D3cold
[    0.380247] pci 0000:00:1d.2: PTM enabled (root), 4ns granularity
[    0.380706] pci 0000:00:1f.0: [8086:5481] type 00 class 0x060100 conventional PCI endpoint
[    0.381035] pci 0000:00:1f.3: [8086:54c8] type 00 class 0x040100 conventional PCI endpoint
[    0.381077] pci 0000:00:1f.3: BAR 0 [mem 0x6001120000-0x6001123fff 64bit]
[    0.381131] pci 0000:00:1f.3: BAR 4 [mem 0x6001000000-0x60010fffff 64bit]
[    0.381237] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.381329] pci 0000:00:1f.4: [8086:54a3] type 00 class 0x0c0500 conventional PCI endpoint
[    0.381352] pci 0000:00:1f.4: BAR 0 [mem 0x6001128000-0x60011280ff 64bit]
[    0.381374] pci 0000:00:1f.4: BAR 4 [io  0xefa0-0xefbf]
[    0.381589] pci 0000:00:1f.5: [8086:54a4] type 00 class 0x0c8000 conventional PCI endpoint
[    0.381608] pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]
[    0.381789] pci 0000:01:00.0: [8086:125c] type 00 class 0x020000 PCIe Endpoint
[    0.381808] pci 0000:01:00.0: BAR 0 [mem 0x80e00000-0x80efffff]
[    0.381833] pci 0000:01:00.0: BAR 3 [mem 0x80f00000-0x80f03fff]
[    0.381859] pci 0000:01:00.0: ROM [mem 0x80d00000-0x80dfffff pref]
[    0.381969] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    0.382170] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.382250] pci 0000:02:00.0: [8086:125c] type 00 class 0x020000 PCIe Endpoint
[    0.382269] pci 0000:02:00.0: BAR 0 [mem 0x80b00000-0x80bfffff]
[    0.382294] pci 0000:02:00.0: BAR 3 [mem 0x80c00000-0x80c03fff]
[    0.382319] pci 0000:02:00.0: ROM [mem 0x80a00000-0x80afffff pref]
[    0.382430] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    0.382624] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.382702] pci 0000:03:00.0: [8086:125c] type 00 class 0x020000 PCIe Endpoint
[    0.382722] pci 0000:03:00.0: BAR 0 [mem 0x80800000-0x808fffff]
[    0.382747] pci 0000:03:00.0: BAR 3 [mem 0x80900000-0x80903fff]
[    0.382772] pci 0000:03:00.0: ROM [mem 0x80700000-0x807fffff pref]
[    0.382881] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[    0.383075] pci 0000:00:1c.2: PCI bridge to [bus 03]
[    0.383153] pci 0000:04:00.0: [8086:125c] type 00 class 0x020000 PCIe Endpoint
[    0.383173] pci 0000:04:00.0: BAR 0 [mem 0x80500000-0x805fffff]
[    0.383198] pci 0000:04:00.0: BAR 3 [mem 0x80600000-0x80603fff]
[    0.383223] pci 0000:04:00.0: ROM [mem 0x80400000-0x804fffff pref]
[    0.383333] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
[    0.383525] pci 0000:00:1c.3: PCI bridge to [bus 04]
[    0.383593] pci 0000:05:00.0: [197b:0585] type 00 class 0x010601 PCIe Legacy Endpoint
[    0.383614] pci 0000:05:00.0: BAR 0 [io  0x3200-0x327f]
[    0.383625] pci 0000:05:00.0: BAR 1 [io  0x3180-0x31ff]
[    0.383637] pci 0000:05:00.0: BAR 2 [io  0x3100-0x317f]
[    0.383648] pci 0000:05:00.0: BAR 3 [io  0x3080-0x30ff]
[    0.383659] pci 0000:05:00.0: BAR 4 [io  0x3000-0x307f]
[    0.383670] pci 0000:05:00.0: BAR 5 [mem 0x81210000-0x81211fff]
[    0.383682] pci 0000:05:00.0: ROM [mem 0x81200000-0x8120ffff pref]
[    0.383782] pci 0000:05:00.0: PME# supported from D3hot
[    0.383871] pci 0000:05:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0000:00:1c.6 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[    0.383971] pci 0000:00:1c.6: PCI bridge to [bus 05]
[    0.384035] pci 0000:06:00.0: [c0a9:5426] type 00 class 0x010802 PCIe Endpoint
[    0.384061] pci 0000:06:00.0: BAR 0 [mem 0x81100000-0x81103fff 64bit]
[    0.384328] pci 0000:06:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0000:00:1d.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
[    0.384452] pci 0000:00:1d.0: PCI bridge to [bus 06]
[    0.384521] pci 0000:07:00.0: [1b21:1166] type 00 class 0x010601 PCIe Endpoint
[    0.384542] pci 0000:07:00.0: BAR 0 [mem 0x81082000-0x81083fff]
[    0.384595] pci 0000:07:00.0: BAR 5 [mem 0x81080000-0x81081fff]
[    0.384607] pci 0000:07:00.0: ROM [mem 0x81000000-0x8107ffff pref]
[    0.384616] pci 0000:07:00.0: enabling Extended Tags
[    0.384686] pci 0000:07:00.0: PME# supported from D0 D3hot D3cold
[    0.384733] pci 0000:07:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0000:00:1d.2 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[    0.384805] pci 0000:00:1d.2: PCI bridge to [bus 07]
[    0.391244] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    0.391360] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[    0.391474] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.391586] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    0.391698] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.391810] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.391922] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.392034] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    0.409015] iommu: Default domain type: Passthrough (set via kernel command line)
[    0.409034] pps_core: LinuxPPS API ver. 1 registered
[    0.409035] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.409038] PTP clock support registered
[    0.409046] EDAC MC: Ver: 3.0.0
[    0.409154] efivars: Registered efivars operations
[    0.409165] NetLabel: Initializing
[    0.409167] NetLabel:  domain hash size = 128
[    0.409168] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.409185] NetLabel:  unlabeled traffic allowed by default
[    0.409186] PCI: Using ACPI for IRQ routing
[    0.431966] PCI: pci_cache_line_size set to 64 bytes
[    0.432025] pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]: can't claim; no compatible bridge window
[    0.432077] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    0.432079] e820: reserve RAM buffer [mem 0x4035c000-0x43ffffff]
[    0.432080] e820: reserve RAM buffer [mem 0x40393000-0x43ffffff]
[    0.432081] e820: reserve RAM buffer [mem 0x6419a018-0x67ffffff]
[    0.432082] e820: reserve RAM buffer [mem 0x6e6f9000-0x6fffffff]
[    0.432082] e820: reserve RAM buffer [mem 0x71e5c000-0x73ffffff]
[    0.432083] e820: reserve RAM buffer [mem 0x76000000-0x77ffffff]
[    0.432084] e820: reserve RAM buffer [mem 0x87fc00000-0x87fffffff]
[    0.432119] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.432119] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.432119] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.432119] vgaarb: loaded
[    0.432119] clocksource: Switched to clocksource tsc-early
[    0.432119] VFS: Disk quotas dquot_6.6.0
[    0.432119] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.432119] AppArmor: AppArmor Filesystem Enabled
[    0.432119] pnp: PnP ACPI init
[    0.432119] system 00:00: [io  0x0a00-0x0a1f] has been reserved
[    0.432119] system 00:00: [io  0x0a20-0x0a2f] has been reserved
[    0.432119] system 00:00: [io  0x0a30-0x0a3f] has been reserved
[    0.432119] pnp 00:01: [dma 0 disabled]
[    0.432119] system 00:02: [io  0x0680-0x069f] has been reserved
[    0.432119] system 00:02: [io  0x164e-0x164f] has been reserved
[    0.432515] pnp 00:03: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[    0.432543] system 00:03: [mem 0xfedc0000-0xfedc7fff] has been reserved
[    0.432545] system 00:03: [mem 0xfeda0000-0xfeda0fff] has been reserved
[    0.432546] system 00:03: [mem 0xfeda1000-0xfeda1fff] has been reserved
[    0.432547] system 00:03: [mem 0xfed20000-0xfed7ffff] could not be reserved
[    0.432549] system 00:03: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.432550] system 00:03: [mem 0xfed45000-0xfed8ffff] could not be reserved
[    0.432551] system 00:03: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.436040] system 00:04: [io  0x2000-0x20fe] has been reserved
[    0.436527] system 00:05: [mem 0xfe03e008-0xfe03efff] has been reserved
[    0.436529] system 00:05: [mem 0xfe03f000-0xfe03ffff] has been reserved
[    0.436986] pnp: PnP ACPI: found 6 devices
[    0.442438] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.442485] NET: Registered PF_INET protocol family
[    0.442771] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.455318] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.455369] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.455383] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.455606] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.455760] TCP: Hash tables configured (established 262144 bind 65536)
[    0.455904] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
[    0.455955] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.456006] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.456097] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.456105] NET: Registered PF_XDP protocol family
[    0.456115] pci_bus 0000:00: max bus depth: 1 pci_try_num: 2
[    0.456128] pci 0000:00:02.0: VF BAR 2 [mem 0x4020000000-0x40ffffffff 64bit pref]: assigned
[    0.456133] pci 0000:00:02.0: VF BAR 0 [mem 0x4010000000-0x4016ffffff 64bit]: assigned
[    0.456137] pci 0000:00:1f.5: BAR 0 [mem 0x81304000-0x81304fff]: assigned
[    0.456147] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.456151] pci 0000:00:1c.0:   bridge window [mem 0x80d00000-0x80ffffff]
[    0.456159] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.456162] pci 0000:00:1c.1:   bridge window [mem 0x80a00000-0x80cfffff]
[    0.456169] pci 0000:00:1c.2: PCI bridge to [bus 03]
[    0.456173] pci 0000:00:1c.2:   bridge window [mem 0x80700000-0x809fffff]
[    0.456180] pci 0000:00:1c.3: PCI bridge to [bus 04]
[    0.456184] pci 0000:00:1c.3:   bridge window [mem 0x80400000-0x806fffff]
[    0.456191] pci 0000:00:1c.6: PCI bridge to [bus 05]
[    0.456193] pci 0000:00:1c.6:   bridge window [io  0x3000-0x3fff]
[    0.456197] pci 0000:00:1c.6:   bridge window [mem 0x81200000-0x812fffff]
[    0.456203] pci 0000:00:1d.0: PCI bridge to [bus 06]
[    0.456207] pci 0000:00:1d.0:   bridge window [mem 0x81100000-0x811fffff]
[    0.456214] pci 0000:00:1d.2: PCI bridge to [bus 07]
[    0.456218] pci 0000:00:1d.2:   bridge window [mem 0x81000000-0x810fffff]
[    0.456225] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.456226] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.456228] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.456229] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000fffff window]
[    0.456230] pci_bus 0000:00: resource 8 [mem 0x80400000-0xbfffffff window]
[    0.456231] pci_bus 0000:00: resource 9 [mem 0x4000000000-0x7fffffffff window]
[    0.456232] pci_bus 0000:01: resource 1 [mem 0x80d00000-0x80ffffff]
[    0.456234] pci_bus 0000:02: resource 1 [mem 0x80a00000-0x80cfffff]
[    0.456235] pci_bus 0000:03: resource 1 [mem 0x80700000-0x809fffff]
[    0.456236] pci_bus 0000:04: resource 1 [mem 0x80400000-0x806fffff]
[    0.456238] pci_bus 0000:05: resource 0 [io  0x3000-0x3fff]
[    0.456239] pci_bus 0000:05: resource 1 [mem 0x81200000-0x812fffff]
[    0.456240] pci_bus 0000:06: resource 1 [mem 0x81100000-0x811fffff]
[    0.456241] pci_bus 0000:07: resource 1 [mem 0x81000000-0x810fffff]
[    0.456801] PCI: CLS 64 bytes, default 64
[    0.456842] DMAR: No ATSR found
[    0.456843] DMAR: No SATC found
[    0.456844] DMAR: IOMMU feature fl1gp_support inconsistent
[    0.456845] DMAR: IOMMU feature pgsel_inv inconsistent
[    0.456846] DMAR: IOMMU feature nwfs inconsistent
[    0.456847] DMAR: IOMMU feature dit inconsistent
[    0.456847] DMAR: IOMMU feature sc_support inconsistent
[    0.456848] DMAR: IOMMU feature dev_iotlb_support inconsistent
[    0.456849] DMAR: dmar0: Using Queued invalidation
[    0.456852] DMAR: dmar1: Using Queued invalidation
[    0.456879] Trying to unpack rootfs image as initramfs...
[    0.457101] pci 0000:00:02.0: Adding to iommu group 0
[    0.457133] pci 0000:00:00.0: Adding to iommu group 1
[    0.457147] pci 0000:00:0d.0: Adding to iommu group 2
[    0.457161] pci 0000:00:14.0: Adding to iommu group 3
[    0.457169] pci 0000:00:14.2: Adding to iommu group 3
[    0.457180] pci 0000:00:16.0: Adding to iommu group 4
[    0.457188] pci 0000:00:17.0: Adding to iommu group 5
[    0.457202] pci 0000:00:1c.0: Adding to iommu group 6
[    0.457216] pci 0000:00:1c.1: Adding to iommu group 7
[    0.457228] pci 0000:00:1c.2: Adding to iommu group 8
[    0.457243] pci 0000:00:1c.3: Adding to iommu group 9
[    0.457254] pci 0000:00:1c.6: Adding to iommu group 10
[    0.457269] pci 0000:00:1d.0: Adding to iommu group 11
[    0.457282] pci 0000:00:1d.2: Adding to iommu group 12
[    0.457302] pci 0000:00:1f.0: Adding to iommu group 13
[    0.457311] pci 0000:00:1f.3: Adding to iommu group 13
[    0.457320] pci 0000:00:1f.4: Adding to iommu group 13
[    0.457329] pci 0000:00:1f.5: Adding to iommu group 13
[    0.457342] pci 0000:01:00.0: Adding to iommu group 14
[    0.457357] pci 0000:02:00.0: Adding to iommu group 15
[    0.457369] pci 0000:03:00.0: Adding to iommu group 16
[    0.457383] pci 0000:04:00.0: Adding to iommu group 17
[    0.457396] pci 0000:05:00.0: Adding to iommu group 18
[    0.457410] pci 0000:06:00.0: Adding to iommu group 19
[    0.457421] pci 0000:07:00.0: Adding to iommu group 20
[    0.457564] DMAR: Intel(R) Virtualization Technology for Directed I/O
[    0.457566] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.457567] software IO TLB: mapped [mem 0x000000006019a000-0x000000006419a000] (64MB)
[    0.457826] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0xb9fb05486c, max_idle_ns: 440795231721 ns
[    0.457848] clocksource: Switched to clocksource tsc
[    0.457881] platform rtc_cmos: registered platform RTC device (no PNP device found)
[    0.459356] Initialise system trusted keyrings
[    0.459373] Key type blacklist registered
[    0.459424] workingset: timestamp_bits=36 max_order=23 bucket_order=0
[    0.459432] zbud: loaded
[    0.459514] fuse: init (API version 7.41)
[    0.459651] integrity: Platform Keyring initialized
[    0.459660] integrity: Machine keyring initialized
[    0.474008] Key type asymmetric registered
[    0.474015] Asymmetric key parser 'x509' registered
[    0.945440] Freeing initrd memory: 82544K
[    0.949345] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.949373] io scheduler mq-deadline registered
[    0.950586] ledtrig-cpu: registered to indicate activity on CPUs
[    0.952161] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.953423] thermal LNXTHERM:00: registered as thermal_zone0
[    0.953426] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[    0.953519] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.954234] 00:01: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.960132] hpet_acpi_add: no address or irqs in _CRS
[    0.960159] Linux agpgart interface v0.103
[    0.991860] i8042: PNP: No PS/2 controller found.
[    0.991927] mousedev: PS/2 mouse device common for all mice
[    0.991948] rtc_cmos rtc_cmos: RTC can wake from S4
[    0.992734] rtc_cmos rtc_cmos: registered as rtc0
[    0.992910] rtc_cmos rtc_cmos: setting system clock to 2026-01-12T09:16:04 UTC (1768209364)
[    0.992936] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[    0.993026] intel_pstate: Intel P-state driver initializing
[    0.993238] intel_pstate: HWP enabled
[    0.994246] NET: Registered PF_INET6 protocol family
dmesg (part 2):
[    1.001027] Segment Routing with IPv6
[    1.001046] In-situ OAM (IOAM) with IPv6
[    1.001076] mip6: Mobile IPv6
[    1.001082] NET: Registered PF_PACKET protocol family
[    1.001116] mpls_gso: MPLS GSO support
[    1.002618] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    1.005059] microcode: Current revision: 0x0000001d
[    1.005063] microcode: Updated early from: 0x0000000e
[    1.007049] resctrl: L2 allocation detected
[    1.007065] IPI shorthand broadcast: enabled
[    1.009061] sched_clock: Marking stable (1000061224, 6976962)->(1033493050, -26454864)
[    1.009201] registered taskstats version 1
[    1.009333] Loading compiled-in X.509 certificates
[    1.028303] Loaded X.509 cert 'Build time autogenerated kernel key: c3384ccfe51b608e872d4e99dfc78fb9e4c0d67d'
[    1.028469] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[    1.028481] Loaded X.509 cert 'Debian Secure Boot Signer 2020: 00b55eb3b9'
[    1.029529] Demotion targets for Node 0: null
[    1.029576] Key type .fscrypt registered
[    1.029578] Key type fscrypt-provisioning registered
[    1.042837] Key type encrypted registered
[    1.042846] AppArmor: AppArmor sha256 policy hashing enabled
[    1.043107] ima: Allocated hash algorithm: sha256
[    1.099669] ima: No architecture policies found
[    1.099701] evm: Initialising EVM extended attributes:
[    1.099703] evm: security.selinux
[    1.099706] evm: security.SMACK64 (disabled)
[    1.099708] evm: security.SMACK64EXEC (disabled)
[    1.099710] evm: security.SMACK64TRANSMUTE (disabled)
[    1.099711] evm: security.SMACK64MMAP (disabled)
[    1.099713] evm: security.apparmor
[    1.099715] evm: security.ima
[    1.099716] evm: security.capability
[    1.099718] evm: HMAC attrs: 0x1
[    1.103879] RAS: Correctable Errors collector initialized.
[    1.125392] clk: Disabling unused clocks
[    1.125398] PM: genpd: Disabling unused power domains
[    1.126791] Freeing unused decrypted memory: 2028K
[    1.127516] Freeing unused kernel image (initmem) memory: 4232K
[    1.127536] Write protecting the kernel read-only data: 28672k
[    1.127822] Freeing unused kernel image (rodata/data gap) memory: 696K
[    1.161425] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.161431] Run /init as init process
[    1.161432]   with arguments:
[    1.161434]     /init
[    1.161434]   with environment:
[    1.161435]     HOME=/
[    1.161436]     TERM=linux
[    1.161436]     BOOT_IMAGE=/ROOT/25.10.1@/boot/vmlinuz-6.12.33-production+truenas
[    1.161437]     zfsforce=1
[    1.334074] ACPI: bus type USB registered
[    1.334106] usbcore: registered new interface driver usbfs
[    1.334115] usbcore: registered new interface driver hub
[    1.334127] usbcore: registered new device driver usb
[    1.334930] Intel(R) 2.5G Ethernet Linux Driver
[    1.334933] Copyright(c) 2018 Intel Corporation.
[    1.334964] igc 0000:01:00.0: enabling device (0000 -> 0002)
[    1.336617] igc 0000:01:00.0: PTM enabled, 4ns granularity
[    1.339449] i801_smbus 0000:00:1f.4: enabling device (0000 -> 0003)
[    1.339504] SCSI subsystem initialized
[    1.339654] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    1.339706] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    1.347860] i2c i2c-0: Successfully instantiated SPD at 0x50
[    1.354499] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[    1.354506] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 1
[    1.355553] xhci_hcd 0000:00:0d.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
[    1.355800] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[    1.355803] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 2
[    1.355806] xhci_hcd 0000:00:0d.0: Host supports USB 3.2 Enhanced SuperSpeed
[    1.355916] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[    1.355919] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.355921] usb usb1: Product: xHCI Host Controller
[    1.355922] usb usb1: Manufacturer: Linux 6.12.33-production+truenas xhci-hcd
[    1.355923] usb usb1: SerialNumber: 0000:00:0d.0
[    1.356084] hub 1-0:1.0: USB hub found
[    1.356094] hub 1-0:1.0: 1 port detected
[    1.356346] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[    1.356349] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.356350] usb usb2: Product: xHCI Host Controller
[    1.356352] usb usb2: Manufacturer: Linux 6.12.33-production+truenas xhci-hcd
[    1.356352] usb usb2: SerialNumber: 0000:00:0d.0
[    1.356482] hub 2-0:1.0: USB hub found
[    1.356495] hub 2-0:1.0: 2 ports detected
[    1.356508] nvme 0000:06:00.0: platform quirk: setting simple suspend
[    1.357325] nvme nvme0: pci function 0000:06:00.0
[    1.357781] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.357785] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[    1.358866] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000100200009810
[    1.359240] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.359244] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[    1.359246] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    1.359274] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[    1.359276] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.359278] usb usb3: Product: xHCI Host Controller
[    1.359279] usb usb3: Manufacturer: Linux 6.12.33-production+truenas xhci-hcd
[    1.359280] usb usb3: SerialNumber: 0000:00:14.0
[    1.359423] hub 3-0:1.0: USB hub found
[    1.359441] hub 3-0:1.0: 12 ports detected
[    1.361183] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[    1.361187] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.361189] usb usb4: Product: xHCI Host Controller
[    1.361190] usb usb4: Manufacturer: Linux 6.12.33-production+truenas xhci-hcd
[    1.361192] usb usb4: SerialNumber: 0000:00:14.0
[    1.361353] hub 4-0:1.0: USB hub found
[    1.361367] hub 4-0:1.0: 4 ports detected
[    1.375288] libata version 3.00 loaded.
[    1.376560] nvme nvme0: allocated 64 MiB host memory buffer.
[    1.384204] igc 0000:01:00.0 (unnamed net_device) (uninitialized): PHC added
[    1.407346] igc 0000:01:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
[    1.407354] igc 0000:01:00.0 eth0: MAC: 00:d0:b4:03:c5:f2
[    1.407460] igc 0000:02:00.0: enabling device (0000 -> 0002)
[    1.407682] igc 0000:02:00.0: PTM enabled, 4ns granularity
[    1.415032] nvme nvme0: 4/0/0 default/read/poll queues
[    1.434239]  nvme0n1: p1 p2 p3
[    1.440073] ahci 0000:00:17.0: version 3.0
[    1.440376] ahci 0000:00:17.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[    1.440379] ahci 0000:00:17.0: 1/1 ports implemented (port mask 0x2)
[    1.440381] ahci 0000:00:17.0: flags: 64bit ncq sntf clo only pio slum part deso sadm sds
[    1.440742] scsi host0: ahci
[    1.440866] scsi host1: ahci
[    1.440905] ata1: DUMMY
[    1.440910] ata2: SATA max UDMA/133 abar m2048@0x81302000 port 0x81302180 irq 154 lpm-pol 0
[    1.441170] ahci 0000:05:00.0: SSS flag set, parallel bus scan disabled
[    1.441229] ahci 0000:05:00.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[    1.441231] ahci 0000:05:00.0: 5/5 ports implemented (port mask 0x1f)
[    1.441233] ahci 0000:05:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh
[    1.441908] scsi host2: ahci
[    1.446039] scsi host3: ahci
[    1.446160] scsi host4: ahci
[    1.446255] scsi host5: ahci
[    1.446335] scsi host6: ahci
[    1.446373] ata3: SATA max UDMA/133 abar m8192@0x81210000 port 0x81210100 irq 155 lpm-pol 0
[    1.446377] ata4: SATA max UDMA/133 abar m8192@0x81210000 port 0x81210180 irq 156 lpm-pol 0
[    1.446380] ata5: SATA max UDMA/133 abar m8192@0x81210000 port 0x81210200 irq 157 lpm-pol 0
[    1.446382] ata6: SATA max UDMA/133 abar m8192@0x81210000 port 0x81210280 irq 158 lpm-pol 0
[    1.446384] ata7: SATA max UDMA/133 abar m8192@0x81210000 port 0x81210300 irq 159 lpm-pol 0
[    1.446754] ahci 0000:07:00.0: SSS flag set, parallel bus scan disabled
[    1.453357] igc 0000:02:00.0 (unnamed net_device) (uninitialized): PHC added
[    1.457112] ahci 0000:07:00.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[    1.457115] ahci 0000:07:00.0: 30/32 ports implemented (port mask 0xffffff3f)
[    1.457117] ahci 0000:07:00.0: flags: 64bit ncq sntf stag pm led only pio sxs deso sadm sds apst
[    1.460264] scsi host7: ahci
[    1.460442] scsi host8: ahci
[    1.460602] scsi host9: ahci
[    1.460759] scsi host10: ahci
[    1.460832] scsi host11: ahci
[    1.460902] scsi host12: ahci
[    1.460981] scsi host13: ahci
[    1.461062] scsi host14: ahci
[    1.461254] scsi host15: ahci
[    1.461349] scsi host16: ahci
[    1.461491] scsi host17: ahci
[    1.461646] scsi host18: ahci
[    1.461804] scsi host19: ahci
[    1.461958] scsi host20: ahci
[    1.462104] scsi host21: ahci
[    1.462247] scsi host22: ahci
[    1.462372] scsi host23: ahci
[    1.462484] scsi host24: ahci
[    1.462591] scsi host25: ahci
[    1.462697] scsi host26: ahci
[    1.462803] scsi host27: ahci
[    1.462938] scsi host28: ahci
[    1.463239] scsi host29: ahci
[    1.463407] scsi host30: ahci
[    1.463584] scsi host31: ahci
[    1.463734] scsi host32: ahci
[    1.463885] scsi host33: ahci
[    1.464031] scsi host34: ahci
[    1.464179] scsi host35: ahci
[    1.464326] scsi host36: ahci
[    1.464469] scsi host37: ahci
[    1.464615] scsi host38: ahci
[    1.464673] ata8: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080100 irq 163 lpm-pol 0
[    1.464678] ata9: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080180 irq 163 lpm-pol 0
[    1.464682] ata10: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080200 irq 163 lpm-pol 0
[    1.464685] ata11: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080280 irq 163 lpm-pol 0
[    1.464688] ata12: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080300 irq 163 lpm-pol 0
[    1.464692] ata13: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080380 irq 163 lpm-pol 0
[    1.464693] ata14: DUMMY
[    1.464695] ata15: DUMMY
[    1.464698] ata16: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080500 irq 163 lpm-pol 0
[    1.464701] ata17: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080580 irq 163 lpm-pol 0
[    1.464704] ata18: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080600 irq 163 lpm-pol 0
[    1.464707] ata19: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080680 irq 163 lpm-pol 0
[    1.464710] ata20: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080700 irq 163 lpm-pol 0
[    1.464713] ata21: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080780 irq 163 lpm-pol 0
[    1.464716] ata22: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080800 irq 163 lpm-pol 0
[    1.464720] ata23: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080880 irq 163 lpm-pol 0
[    1.464723] ata24: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080900 irq 163 lpm-pol 0
[    1.464726] ata25: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080980 irq 163 lpm-pol 0
[    1.464729] ata26: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080a00 irq 163 lpm-pol 0
[    1.464732] ata27: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080a80 irq 163 lpm-pol 0
[    1.464735] ata28: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080b00 irq 163 lpm-pol 0
[    1.464738] ata29: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080b80 irq 163 lpm-pol 0
[    1.464741] ata30: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080c00 irq 163 lpm-pol 0
[    1.464744] ata31: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080c80 irq 163 lpm-pol 0
[    1.464748] ata32: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080d00 irq 163 lpm-pol 0
[    1.464751] ata33: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080d80 irq 163 lpm-pol 0
[    1.464754] ata34: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080e00 irq 163 lpm-pol 0
[    1.464757] ata35: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080e80 irq 163 lpm-pol 0
[    1.464760] ata36: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080f00 irq 163 lpm-pol 0
[    1.464763] ata37: SATA max UDMA/133 abar m8192@0x81080000 port 0x81080f80 irq 163 lpm-pol 0
[    1.464766] ata38: SATA max UDMA/133 abar m8192@0x81080000 port 0x81081000 irq 163 lpm-pol 0
[    1.464769] ata39: SATA max UDMA/133 abar m8192@0x81080000 port 0x81081080 irq 163 lpm-pol 0
[    1.476332] igc 0000:02:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
[    1.476338] igc 0000:02:00.0 eth1: MAC: 00:d0:b4:03:c5:f3
[    1.476434] igc 0000:03:00.0: enabling device (0000 -> 0002)
[    1.476637] igc 0000:03:00.0: PTM enabled, 4ns granularity
[    1.523719] igc 0000:03:00.0 (unnamed net_device) (uninitialized): PHC added
[    1.549547] igc 0000:03:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
[    1.549559] igc 0000:03:00.0 eth2: MAC: 00:d0:b4:03:c5:f4
[    1.549676] igc 0000:04:00.0: enabling device (0000 -> 0002)
[    1.549921] igc 0000:04:00.0: PTM enabled, 4ns granularity
[    1.595752] igc 0000:04:00.0 (unnamed net_device) (uninitialized): PHC added
[    1.621823] igc 0000:04:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
[    1.621836] igc 0000:04:00.0 eth3: MAC: 00:d0:b4:03:c5:f5
[    1.754932] ata2: SATA link down (SStatus 0 SControl 300)
[    1.760054] ata3: SATA link down (SStatus 0 SControl 300)
[    1.775591] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.776497] ata8.00: ATA-10: WDC WD40EFRX-68N32N0, 82.00A82, max UDMA/133
[    1.777691] ata8.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    1.779174] ata8.00: configured for UDMA/133
[    2.067783] ata4: SATA link down (SStatus 0 SControl 300)
[    2.375684] ata5: SATA link down (SStatus 0 SControl 300)
[    2.683705] ata6: SATA link down (SStatus 0 SControl 300)
[    2.991675] ata7: SATA link down (SStatus 0 SControl 300)
[    2.992211] scsi 7:0:0:0: Direct-Access     ATA      WDC WD40EFRX-68N 0A82 PQ: 0 ANSI: 5
[    3.299467] ata9: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    3.300264] ata9.00: ATA-10: WDC WD40EFPX-68C6CN0, 81.00A81, max UDMA/133
[    3.302494] ata9.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    3.302516] ata9.00: Features: NCQ-prio
[    3.304713] ata9.00: configured for UDMA/133
[    3.305080] scsi 8:0:0:0: Direct-Access     ATA      WDC WD40EFPX-68C 0A81 PQ: 0 ANSI: 5
[    3.611654] ata10: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    3.612537] ata10.00: ATA-9: WDC WD40EFRX-68WT0N0, 80.00A80, max UDMA/133
[    3.613118] ata10.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 32), AA
[    3.613981] ata10.00: configured for UDMA/133
[    3.614355] scsi 9:0:0:0: Direct-Access     ATA      WDC WD40EFRX-68W 0A80 PQ: 0 ANSI: 5
[    3.923727] ata11: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    3.924472] ata11.00: ATA-10: WDC WD40EFPX-68C6CN0, 81.00A81, max UDMA/133
[    3.926660] ata11.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    3.926680] ata11.00: Features: NCQ-prio
[    3.928506] ata11.00: configured for UDMA/133
[    3.928859] scsi 10:0:0:0: Direct-Access     ATA      WDC WD40EFPX-68C 0A81 PQ: 0 ANSI: 5
[    4.235175] ata12: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.289001] ata12.00: ATA-9: WDC WD40EFRX-68WT0N0, 82.00A82, max UDMA/133
[    4.289495] ata12.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 32), AA
[    4.290568] ata12.00: configured for UDMA/133
[    4.290879] scsi 11:0:0:0: Direct-Access     ATA      WDC WD40EFRX-68W 0A82 PQ: 0 ANSI: 5
[    4.599680] ata13: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.600493] ata13.00: ATA-10: WDC WD40EFPX-68C6CN0, 81.00A81, max UDMA/133
[    4.602578] ata13.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    4.602601] ata13.00: Features: NCQ-prio
[    4.604755] ata13.00: configured for UDMA/133
[    4.605160] scsi 12:0:0:0: Direct-Access     ATA      WDC WD40EFPX-68C 0A81 PQ: 0 ANSI: 5
[    4.915658] ata16: SATA link down (SStatus 0 SControl 300)
[    5.223705] ata17: SATA link down (SStatus 0 SControl 300)
[    5.531703] ata18: SATA link down (SStatus 0 SControl 300)
[    5.839624] ata19: SATA link down (SStatus 0 SControl 300)
[    6.147729] ata20: SATA link down (SStatus 0 SControl 300)
[    6.455181] ata21: SATA link down (SStatus 0 SControl 300)
[    6.763704] ata22: SATA link down (SStatus 0 SControl 300)
[    7.071570] ata23: SATA link down (SStatus 0 SControl 300)
[    7.379725] ata24: SATA link down (SStatus 0 SControl 300)
[    7.687699] ata25: SATA link down (SStatus 0 SControl 300)
[    7.995553] ata26: SATA link down (SStatus 0 SControl 300)
[    8.303681] ata27: SATA link down (SStatus 0 SControl 300)
[    8.611719] ata28: SATA link down (SStatus 0 SControl 300)
[    8.919728] ata29: SATA link down (SStatus 0 SControl 300)
[    9.227736] ata30: SATA link down (SStatus 0 SControl 300)
[    9.540049] ata31: SATA link down (SStatus 0 SControl 300)
[    9.847728] ata32: SATA link down (SStatus 0 SControl 300)
[   10.155660] ata33: SATA link down (SStatus 0 SControl 300)
[   10.463758] ata34: SATA link down (SStatus 0 SControl 300)
[   10.771708] ata35: SATA link down (SStatus 0 SControl 300)
[   11.079606] ata36: SATA link down (SStatus 0 SControl 300)
[   11.387752] ata37: SATA link down (SStatus 0 SControl 300)
[   11.695722] ata38: SATA link down (SStatus 0 SControl 300)
[   12.003769] ata39: SATA link down (SStatus 0 SControl 300)
[   12.009945] igc 0000:01:00.0 enp1s0: renamed from eth0
[   12.013812] igc 0000:02:00.0 enp2s0: renamed from eth1
[   12.014180] igc 0000:03:00.0 enp3s0: renamed from eth2
[   12.014426] igc 0000:04:00.0 enp4s0: renamed from eth3
[   12.024031] sd 10:0:0:0: [sdd] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[   12.024049] sd 10:0:0:0: [sdd] 4096-byte physical blocks
[   12.024074] sd 8:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[   12.024075] sd 7:0:0:0: [sdb] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[   12.024081] sd 7:0:0:0: [sdb] 4096-byte physical blocks
[   12.024087] sd 8:0:0:0: [sda] 4096-byte physical blocks
[   12.024106] sd 7:0:0:0: [sdb] Write Protect is off
[   12.024114] sd 7:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[   12.024117] sd 8:0:0:0: [sda] Write Protect is off
[   12.024125] sd 8:0:0:0: [sda] Mode Sense: 00 3a 00 00
[   12.024135] sd 7:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   12.024138] sd 10:0:0:0: [sdd] Write Protect is off
[   12.024149] sd 10:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[   12.024153] sd 8:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   12.024172] sd 11:0:0:0: [sde] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[   12.024181] sd 11:0:0:0: [sde] 4096-byte physical blocks
[   12.024182] sd 7:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
[   12.024202] sd 8:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[   12.024207] sd 9:0:0:0: [sdc] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[   12.024215] sd 9:0:0:0: [sdc] 4096-byte physical blocks
[   12.024235] sd 10:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   12.024264] sd 11:0:0:0: [sde] Write Protect is off
[   12.024269] sd 11:0:0:0: [sde] Mode Sense: 00 3a 00 00
[   12.024278] sd 9:0:0:0: [sdc] Write Protect is off
[   12.024283] sd 9:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[   12.024298] sd 10:0:0:0: [sdd] Preferred minimum I/O size 4096 bytes
[   12.024323] sd 12:0:0:0: [sdf] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[   12.024330] sd 11:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   12.024336] sd 12:0:0:0: [sdf] 4096-byte physical blocks
[   12.024348] sd 9:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   12.024360] sd 12:0:0:0: [sdf] Write Protect is off
[   12.024368] sd 12:0:0:0: [sdf] Mode Sense: 00 3a 00 00
[   12.024389] sd 12:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   12.024426] sd 12:0:0:0: [sdf] Preferred minimum I/O size 4096 bytes
[   12.024530] sd 9:0:0:0: [sdc] Preferred minimum I/O size 4096 bytes
[   12.024640] sd 11:0:0:0: [sde] Preferred minimum I/O size 4096 bytes
[   12.083115]  sda: sda1
[   12.083441] sd 8:0:0:0: [sda] Attached SCSI disk
[   12.084850]  sdb: sdb1
[   12.085098] sd 7:0:0:0: [sdb] Attached SCSI disk
[   12.087910]  sdd: sdd1
[   12.088073] sd 10:0:0:0: [sdd] Attached SCSI disk
[   12.095030]  sdc: sdc1
[   12.095207] sd 9:0:0:0: [sdc] Attached SCSI disk
[   12.099419]  sde: sde1
[   12.099578] sd 11:0:0:0: [sde] Attached SCSI disk
[   12.103391]  sdf: sdf1
[   12.103544] sd 12:0:0:0: [sdf] Attached SCSI disk
[   12.352657] spl: loading out-of-tree module taints kernel.
[   12.352685] spl: module verification failed: signature and/or required key missing - tainting kernel
[   12.378430] zfs: module license 'CDDL' taints kernel.
[   12.378440] Disabling lock debugging due to kernel taint
[   12.378463] zfs: module license taints kernel.
[   13.408713] ZFS: Loaded module v2.3.4-1, ZFS pool version 5000, ZFS filesystem version 5
[   14.430403] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[   14.523523] systemd[1]: Inserted module 'autofs4'
[   14.551516] systemd[1]: systemd 254.26-1~bpo12+1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[   14.551543] systemd[1]: Detected architecture x86-64.
[   14.552796] systemd[1]: Hostname set to <hades>.
[   14.737112] systemd[1]: Queued start job for default target truenas.target.
[   14.762691] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[   14.763276] systemd[1]: Created slice user.slice - User and Session Slice.
[   14.763447] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[   14.763560] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[   14.763878] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[   14.763953] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[   14.764014] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[   14.764092] systemd[1]: Reached target nss-lookup.target - Host and Network Name Lookups.
[   14.764146] systemd[1]: Reached target paths.target - Path Units.
[   14.764221] systemd[1]: Reached target slices.target - Slice Units.
[   14.764285] systemd[1]: Reached target swap.target - Swaps.
[   14.764338] systemd[1]: Reached target time-set.target - System Time Set.
[   14.764421] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[   14.764473] systemd[1]: Reached target zfs-import.target - ZFS pool import target.
[   14.764966] systemd[1]: Listening on dbus.socket - D-Bus System Message Bus Socket.
[   14.768473] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
[   14.770146] systemd[1]: Listening on systemd-coredump.socket - Process Core Dump Socket.
[   14.770255] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[   14.770435] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[   14.770585] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[   14.771101] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[   14.771227] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[   14.772100] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[   14.772900] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[   14.773928] systemd[1]: Mounting proc-fs-nfsd.mount - NFSD configuration filesystem...
[   14.775781] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[   14.777742] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[   14.779614] systemd[1]: Mounting tmp.mount - Temporary Directory (/tmp)...
[   14.779896] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[   14.782505] systemd[1]: Starting dbus.service - D-Bus System Message Bus...
[   14.782790] systemd[1]: ix-boot-core.service - Reboot to TrueNAS core was skipped because of an unmet condition check (ConditionEnvironment=_BOOT_TRUENAS_CORE=1).
[   14.784308] systemd[1]: Starting ix-wait-on-disks.service - Wait on Disk Enumeration...
[   14.786155] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[   14.788409] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[   14.790782] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[   14.793170] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[   14.794877] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[   14.798848] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[   14.800937] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[   14.803347] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[   14.805761] systemd[1]: Starting systemd-journald.service - Journal Service...
[   14.805921] systemd[1]: systemd-pcrmachine.service - TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
[   14.807792] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[   14.809759] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[   14.812421] systemd[1]: Starting zfs-volume-wait.service - Wait for ZFS Volume (zvol) links in /dev...
[   14.814962] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[   14.815868] loop: module loaded
[   14.816396] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[   14.816537] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[   14.816661] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[   14.816777] systemd[1]: Mounted tmp.mount - Temporary Directory (/tmp).
[   14.817091] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[   14.817574] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[   14.817861] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   14.817987] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[   14.818329] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[   14.818453] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[   14.819134] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   14.819257] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[   14.819689] systemd[1]: modprobe@loop.service: Deactivated successfully.
[   14.819810] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[   14.820138] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[   14.821841] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[   14.826380] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[   14.828904] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[   14.833790] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
[   14.835118] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[   14.840027] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
[   14.843848] systemd[1]: Started dbus.service - D-Bus System Message Bus.
[   14.846471] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[   14.846700] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[   14.847260] pstore: Using crash dump compression: deflate
[   14.867667] RPC: Registered named UNIX socket transport module.
[   14.867673] RPC: Registered udp transport module.
[   14.867675] RPC: Registered tcp transport module.
[   14.867676] RPC: Registered tcp-with-tls transport module.
[   14.867677] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   14.868000] ACPI: bus type drm_connector registered
[   14.871886] pstore: Registered efi_pstore as persistent store backend
[   14.875647] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   14.875862] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[   14.876437] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   14.876620] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   14.877122] systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed.
[   14.877402] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[   14.878212] systemd-journald[695]: Collecting audit messages is disabled.
[   14.917017] systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully.
[   14.917301] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met.
[   14.953589] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
[   14.954174] systemd[1]: Finished zfs-volume-wait.service - Wait for ZFS Volume (zvol) links in /dev.
[   14.954465] systemd[1]: Reached target zfs-volumes.target - ZFS volumes are ready.
[   14.962232] systemd[1]: Started systemd-journald.service - Journal Service.
[   14.972692] systemd-journald[695]: Received client request to flush runtime journal.
[   14.978160] systemd-journald[695]: /var/log/journal/866a507dc93d4cfda29de4a2472ad292/system.journal: Journal file uses a different sequence number ID, rotating.
[   14.978168] systemd-journald[695]: Rotating system journal.
[   15.170345] sd 7:0:0:0: Attached scsi generic sg0 type 0
[   15.170401] sd 8:0:0:0: Attached scsi generic sg1 type 0
[   15.170440] sd 9:0:0:0: Attached scsi generic sg2 type 0
[   15.170472] sd 10:0:0:0: Attached scsi generic sg3 type 0
[   15.170505] sd 11:0:0:0: Attached scsi generic sg4 type 0
[   15.170535] sd 12:0:0:0: Attached scsi generic sg5 type 0
[   15.200828] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[   15.200867] ACPI: button: Sleep Button [SLPB]
[   15.200916] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[   15.200940] ACPI: button: Power Button [PWRB]
[   15.200977] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[   15.201123] ACPI: button: Power Button [PWRF]
[   15.258421] intel_pmc_core INT33A1:00:  initialized
[   15.280675] resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcffff], which spans more than pnp 00:03 [mem 0xfedc0000-0xfedc7fff]
[   15.280688] caller igen6_probe+0x160/0x870 [igen6_edac] mapping multiple BARs
[   15.280751] EDAC MC0: Giving out device to module igen6_edac controller Intel_client_SoC MC#0: DEV 0000:00:00.0 (INTERRUPT)
[   15.280770] EDAC igen6 MC0: HANDLING IBECC MEMORY ERROR
[   15.280771] EDAC igen6 MC0: ADDR 0x7fffffffe0
[   15.283168] EDAC igen6: v2.5.1
[   15.323862] input: PC Speaker as /devices/platform/pcspkr/input/input3
[   15.325990] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[   15.359484] iTCO_vendor_support: vendor-support=0
[   15.368012] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[   15.371409] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   15.448411] Error: Driver 'pcspkr' is already registered, aborting...
[   15.489204] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[   15.489211] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   15.489213] RAPL PMU: hw unit of domain package 2^-14 Joules
[   15.489214] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   15.507377] cryptd: max_cpu_qlen set to 1000
[   15.509246] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[   15.528012] AES CTR mode by8 optimization enabled
[   15.926425] i915 0000:00:02.0: [drm] Found ALDERLAKE_P/ADL-N (device ID 46d1) display version 13.00 stepping D0
[   15.926944] i915 0000:00:02.0: [drm] VT-d active for gfx access
[   15.926948] i915 0000:00:02.0: vgaarb: deactivate vga console
[   15.927014] i915 0000:00:02.0: [drm] Using Transparent Hugepages
[   15.927470] i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[   15.943392] i915 0000:00:02.0: [drm] GT0: GuC firmware i915/tgl_guc_70.bin version 70.36.0
[   15.943402] i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
[   15.947880] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/adlp_dmc.bin (v2.20)
[   15.948434] i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
[   15.948908] i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
[   15.948910] i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
[   15.949235] i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
[   15.985328] mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
[   15.985496] i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
[   15.985501] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
[   15.990508] [drm] Initialized i915 1.6.0 for 0000:00:02.0 on minor 0
[   15.991528] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[   15.992116] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4
[   16.016393] intel_rapl_msr: PL4 support detected.
[   16.016420] intel_rapl_common: Found RAPL domain package
[   16.016423] intel_rapl_common: Found RAPL domain core
[   16.016424] intel_rapl_common: Found RAPL domain uncore
[   16.039060] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[   16.039065] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   16.063021] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[   16.071044] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC897: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[   16.071049] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   16.071051] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   16.071052] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   16.071053] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   16.071054] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x18
[   16.273166] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input5
[   16.273516] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input6
[   16.273596] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input7
[   16.274149] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input8
[   58.922912] dca service started, version 1.12.1
[   58.925672] ioatdma: Intel(R) QuickData Technology Driver 5.00
[   58.929647] NTB Resource Split driver, version 1
[   58.931761] Software Queue-Pair Transport over NTB, version 4
[   58.955703] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[   61.354507] bond0: (slave enp1s0): Enslaving as an active interface with an up link
[   61.404712] bond0: (slave enp2s0): Enslaving as an active interface with an up link
[   61.832125] bond9: (slave enp3s0): Enslaving as an active interface with an up link
[   61.879683] bond9: (slave enp4s0): Enslaving as an active interface with an up link
[   63.330854] audit: type=1400 audit(1768209426.831:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=2476 comm="apparmor_parser"
[   63.331500] audit: type=1400 audit(1768209426.835:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=2478 comm="apparmor_parser"
[   63.331515] audit: type=1400 audit(1768209426.835:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=2478 comm="apparmor_parser"
[   63.337945] audit: type=1400 audit(1768209426.839:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default" pid=2477 comm="apparmor_parser"
[   63.337964] audit: type=1400 audit(1768209426.839:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default-cgns" pid=2477 comm="apparmor_parser"
[   63.337972] audit: type=1400 audit(1768209426.839:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default-with-mounting" pid=2477 comm="apparmor_parser"
[   63.337979] audit: type=1400 audit(1768209426.839:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default-with-nesting" pid=2477 comm="apparmor_parser"
[   63.338651] audit: type=1400 audit(1768209426.839:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lxc-start" pid=2480 comm="apparmor_parser"
[   63.341580] audit: type=1400 audit(1768209426.843:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=2481 comm="apparmor_parser"
[   63.341599] audit: type=1400 audit(1768209426.843:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=2481 comm="apparmor_parser"
[   63.756978] nvme nvme0: using unchecked data buffer
[   64.575428] igc 0000:01:00.0 enp1s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[   64.595433] igc 0000:02:00.0 enp2s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[   65.287390] igc 0000:04:00.0 enp4s0: NIC Link is Up 2500 Mbps Full Duplex, Flow Control: RX
[   65.287390] igc 0000:03:00.0 enp3s0: NIC Link is Up 2500 Mbps Full Duplex, Flow Control: RX
[   65.746136] NFSD: Using nfsdcld client tracking operations.
[   65.746141] NFSD: starting 90-second grace period (net f0000000)
[   73.424237] NFSD: all clients done reclaiming, ending NFSv4 grace period (net f0000000)
[ 1199.324441] systemd-journald[695]: /var/log/journal/866a507dc93d4cfda29de4a2472ad292/user-3001.journal: Journal file uses a different sequence number ID, rotating.
Given the random crashes, my first bet would be RAM-related. I’d buy the paid version of memtest and hammer the board / RAM through a couple of rounds to see if something comes up.
It’s something I’d do with every new motherboard / stick of RAM given how much unhappiness a bad RAM stick can spread. Hopefully, the RAM is ECC and the motherboard supports same?
Nope. N100 on a Chinese “NAS” Board.
Don’t forget that after a MemTest86+ (or the paid version), run it for 5 complete passes (1 is never enough, more is better, 10 is better than 5 if you get my meaning but I recommend 5 minimum), then to run Prime95 (or similar) for at least 4 hours to heat up that CPU and motherboard, ensuring it is still stable.
Great point. Your NAS may be suffering from some heat related issues as well. At some point I need to run this test… can it be run while TrueNAS is also operating? Or is it a program-on-a-USB-stick like memtest?
I do not think this is part of TrueNAS, and I kind of doubt it would be. I use “The Ultimate Boot CD” (UBCD) which has both the memtest86+ and Prime95 or mersenne for a CPU stress Test.
There are only so many tools we have that can stress test hardware, these are the most common.
I would also say, run these tests with the power supply fully loaded, meaning all the hard drives you plan to install, graphics cards, anything that pull power should be connected. This would be an attempt to test the stability of the power supply as well as it can cause errors to occur.
Yeah, the only reason I ask is that I’d love to do it while also executing a scrub… to maximize heat and power production and see what the fans and the PSU can do.
It appears that the program stress can be run from inside a VM. I might try that for fun the next time my NAS is idle. Then initiate a scrub also and watch temps w/some popcorn.
You can also toss the system into developer mode and add the program to the OS. That is always another option, just for testing purposes. The system would remain that way until you re-installed or upgraded TrueNAS. I’m not sure how well a VM would utilize the CPU resources.
If you do try a VM, please post your results as to how well it worked.
Uh, this is likely the problem:
Intel’s own documentation on Ark, say this for the N100:
Memory Specifications
Max Memory Size (dependent on memory type) 16 GB
While many people push the N100 and similar processors beyond the documented maximum amount of memory, which does work some of the time. There are times when specific memory DIMMs don’t work.
Even if the paid version of MemTest were to say the DIMM was good, I’d still be wary of it. Buying a 16GB DIMM might be expensive today. But, what do you want, cutting edge extra memory, and reduced reliability? Or lower memory size, and stability?
PS: My take on Intel’s note “(dependent on memory type)” is that if you use power hungry memory, you might need to use even less, like 8GBs. Not that you could support more than 16GBs.
Few folk investigate CPUs deeply, the sellers of these boards routinely advertise 32GB of RAM capacity, preferably made by Samsung. The Amazon link the OP posted is no different.
I reckon this is a bit of a prisoners dilemma for sellers
also - ie if they only advertise 16GB RAM capacity, buyers will pivot to sellers of motherboards that advertise 32GB RAM capacity, thinking those boards are somehow different.
Will do. I may even send you a link for a livestream so we can enjoy the CPU-sizzle together. (As if I knew how to livestream - ha!)
Or maybe just run: for i in $(seq $(getconf _NPROCESSORS_ONLN)); do yes > /dev/null & done
Concerning the 16/32GB topic: I’ve asked the board manufacturer and the reply was, that the N100 will work with 32GB.
I had already RAM issues with 16GB Corsair RAM and the manufacturer tolt me to use Samsung. I’ve had 16GB Samsung RAM and this also got me the random crashes.
I’ll try the memory and cpu stress test, thanks for the hint.
Maybe I’ve should have listened to my grandparents, who said “We have no money to buy cheap.” and paid a bit more for a better board…
Good advice, and if you take care of it, it will last longer. :slight_smile:
The last time I was in this boat, I was running opnsense virtualized on a Chinese n150 box. I chose promox and zfs. Then I chose opnsense on zfs as my main image.
The root problem was that promox was letting zfs do what it does and cache everything, eating resources. On the host OS and the guest. So within a few hours it turned into a resource race and lost connectivity, just acting totally hosed until a reboot set everything straight again. It was just hard to get them fight and fail at the same time so I could troubleshoot it.
I’m assuming you’re running bare metal on the hardware, not sticking it on top of promox right?
