TrueNAS Scale 24.04/24.10 Flapping Network
Hi all,
Not sure where to ask or get help on this, but I have an old server running TrueNAS Scale 24.04 and the network interfaces seem to be flapping after a few minutes of stability. I have changed the cable, changed the port on the switch, and tried a different switch, tried a different port on the server, tried bridging ports. All to no avail.
This was fairly stable earlier on a Cisco C1000 switch, it has since moved to a dumb netgear switch, but this was after a hard power down and some moving.
I have looked at the logs and can see things dropping then a few seconds later starting back up, these are some of the common lines in the logs I have seen.
Sep 29 19:33:12 jlab02 kernel: RPC: Registered named UNIX socket transport module.
Sep 29 19:33:12 jlab02 kernel: RPC: Registered udp transport module.
Sep 29 19:33:12 jlab02 kernel: RPC: Registered tcp transport module.
Sep 29 19:33:12 jlab02 kernel: RPC: Registered tcp-with-tls transport module.
Sep 29 19:33:12 jlab02 kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Sep 29 19:33:13 jlab02 kernel: e1000e 0000:07:00.0 enp7s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
Sep 29 19:33:14 jlab02 kernel: sas: Enter sas_scsi_recover_host busy: 2 failed: 2
Sep 29 19:33:14 jlab02 kernel: sas: — Exit sas_scsi_recover_host: busy: 0 failed: 2 tries: 1
Sep 29 19:33:18 jlab02 kernel: kauditd_printk_skb: 6 callbacks suppressed
Sep 29 19:33:18 jlab02 kernel: audit: type=1400 audit(1727663598.360:18): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“docker-default” pid=5000 comm=“apparmor_parser”
Sep 29 19:33:19 jlab02 kernel: bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Sep 29 19:33:19 jlab02 kernel: Bridge firewalling registered
Sep 29 19:33:19 jlab02 kernel: Initializing XFRM netlink socket
PS. I haven’t used these forms much lmk if I can provide more info, not sure how to go about continuing to troubleshoot this.
Do you have another card to try out ?
Other than that cabling or the one in there may be breaking down.
Or the new router has a bad port.
I don’t have much experience with networking but at times hardware brakes down and we don’t think of that can ever happen
The only success I had was on a managed C1000 switch earlier, I can go back to that, but I was hoping to not have to
Closing the loop on this, it appears to be a hardware issue sorry all.
