TrueNAS Scale input/output error when creating pool
I recently built a NAS with the latest version of truenas scale. I have 3 2TB drives from an old NAS I had, and 2 seagate factory recertified 12TB drives I purchased for this build. I have been able to create a pool with the 3 2TB drives no problem, but when I try to create a pool with my 2 new 12TB drives I get an error I have listed below. I also get a similar error when trying to wipe them individually. Thanks for any advice!
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 515, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 560, in run_body
rv = await self.method(*args)
File “/usr/lib/python3/dist-packages/middlewared/service/crud_service.py”, line 287, in nf
rv = await func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 48, in nf
res = await f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 174, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool
/pool.py", line 582, in do_create
await self.middleware.call(‘pool.format_disks’, job, disks, 0, 30)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 977, in call
return await self.call(
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 692, in call
/format_disks.py", line 27, in format_disks
await asyncio_map(format_disk, disks.items(), limit=16)
File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio
.py", line 19, in asyncio_map
return await asyncio.gather(*futures)
.py", line 16, in func
return await real_func(arg)
File “/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py”, line 22, in format_disk
await self.middleware.call(‘disk.format’, disk, config.get(‘size’))
return await self._call(
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 703, in call
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 596, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/disk
/format.py", line 33, in format
self.middleware.call_sync(‘disk.wipe’, disk, ‘QUICK’, False).wait_sync(raise_error=True)
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 487, in wait_sync
raise CallError(self.error)
middlewared.service_exception.CallError: [EFAULT] [Errno 5] Input/output error
We need the actual version of TrueNAS to start with…
Your hardware specs are useful as well.
Truenas scale 25.04.0. The drives with the issue are Seagate Exos X18 ST12000NM000J. Lian li 750 sfx power supply, Jonsbo n2 case, a single stick of 16gb ddr5. The motherboard is from Alibaba, and I’m not really sure what to call it, but it has a soldered on Intel n150 processor.
Having the same issue, watching for assistance.
I know it’s been a minute… but come to find out both drives were bad. I RMA’d both and i just created the pool ezpz.
