Hello Guys.
Im trying to create a new pool with my hard drives (Dell ST4000NM0063 RTFJN). The disks are connected via a “HP DiskShelf m6720”
When TrueNAS wipes the disks and fails with the following Error:
[EFAULT] [Errno 5] Input/output error
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 509, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 554, in run_body
rv = await self.method(*args)
File “/usr/lib/python3/dist-packages/middlewared/service/crud_service.py”, line 261, in nf
rv = await func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 49, in nf
res = await f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 179, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool/pool.py", line 725, in do_update
await self.middleware.call(‘pool.format_disks’, job, disks, 0, 80)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1629, in call
return await self.call(
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1460, in call
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool/format_disks.py", line 27, in format_disks
await asyncio_map(format_disk, disks.items(), limit=16)
File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio.py", line 19, in asyncio_map
return await asyncio.gather(*futures)
File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio.py", line 16, in func
return await real_func(arg)
File “/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py”, line 22, in format_disk
await self.middleware.call(‘disk.format’, disk)
return await self._call(
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1471, in call
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1364, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/disk/format.py", line 23, in format
self.middleware.call_sync(‘disk.wipe’, disk, ‘QUICK’, False).wait_sync(raise_error=True)
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 481, in wait_sync
raise CallError(self.error)
middlewared.service_exception.CallError: [EFAULT] [Errno 5] Input/output error
What do i have to do to use these disks? Any help would be amazing. Thanks in advance
