Unable to create storage pool
hi all, I have re-used the hardware from a purestorage flasharray x10r2
Disconnected controller 2, and just using 1 controller.
This was a existing setup, and I managed to install truenas SCALE on there.
Now I’m having trouble creating a POOL
I get an error when writing the pool
Anyone have an idea how i can fix this and start using the storage ?
Full error output:
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 509, in run
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 554, in __run_body
    rv = await self.method(*args)
  File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 261, in nf
    rv = await func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 49, in nf
    res = await f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 179, in nf
  File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/pool.py", line 577, in do_create
    await self.middleware.call('pool.format_disks', job, disks, 0, 30)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1629, in call
    return await self._call(
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1460, in _call
  File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py", line 27, in format_disks
    await asyncio_map(format_disk, disks.items(), limit=16)
  File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio_.py", line 19, in asyncio_map
    return await asyncio.gather(*futures)
  File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio_.py", line 16, in func
    return await real_func(arg)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py", line 22, in format_disk
    await self.middleware.call('disk.format', disk)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1471, in _call
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1364, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/plugins/disk_/format.py", line 23, in format
    self.middleware.call_sync('disk.wipe', disk, 'QUICK', False).wait_sync(raise_error=True)
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 481, in wait_sync
    raise CallError(self.error)
middlewared.service_exception.CallError: [EFAULT] [Errno 5] Input/output error
Reads like a hardware issue of some kind
Not that familiar with that system you’re using, how are the drives connected?
Also, 20 wide RAID-Z2, even if the storage devices are SSDs, is noticeably beyond recommendation of about 12.
This would be more rational:
2 x 10 disk RAID-Z2
