TrueNAS UPS reaches low battery shutdown
Hi!
I’ve connected a SPS-PRO UPS via USB to TrueNAS using nutdrv_qx driver as detected by using the shell command nut-scanner -U
When entering the shell command upsc user@localhost it gives me some info but battery.charge/battery.charge.low fields are missing. Does this imply that the Shutdown Mode “UPS reaches low battery” will not work?
