I had trueNAS scale installed and working fine, till my power supply failed. I tried to reinstall TrueNAS after replacing the power supply and it would not install. After several tries I figured the failed power supply spiked my cpu, memory, or mobo. So I replaced everything to an Asus P6T mobo with 36G of Corsair DDR3 memory, Samsung SSD, and a Core i7 930MHz cpu.When I try to load any version of Scale it gives me the install screen, I press enter. Then it either goes to a blue screen and stops, Or it will continue past the blue screen and give me a series of “+” filling up the entire screen for hours. For giggles I tried to install Core. I got Core installed but plugins would not work. Everything else worked fine. Then I tried to update to Scale. The server shuts off and will not boot correctly after. I tried resetting the bios to the shipped spec and no change. I have tried everything I can think of over the last 2 months.
That is ancient hardware listed. The MB manual states 24GB max. MB uses triple channel memory.
I would fix your configuration and run a live linux distro and do CPU stress tests and run Memtest86 to test the RAM config.
Do the BOT tutorial if you need more forum posting rights, like links or images.
TrueNAS-Bot
Type this in a new reply and send to bring up the tutorial, if you haven’t done it already.
@TrueNAS-Bot start tutorial
Thanks for the help!
As I was unable to get TrueNAS Scale to install, I was finally able to install and configure TrueNAS Core 13.06. This will work fine for my needs. With no further issues I can keep this setup.
Thanks again and have a great day!
