Trying to connect 2 NAS' to TrueNAS Connect
I am getting an error on both saying Integer is required.
You need to post details on your system(s), os version and, maybe screenshots.
It will not allow media to be added to a post. Both are U-NAS NAS devices. One is a two bay and the other is a 4 bay.
Browse some other threads and do the Tutorial by the Bot to get your forum trust level up and post images and links
TrueNAS-Bot
Type this in a new reply and send to bring up the tutorial, if you haven’t done it already.
@TrueNAS-Bot start tutorial
@Jeff_Curtis There’s a bug in RC.1 that requires dropping the truenas_connect table to re-register on a cert generation failure. Modify the DB, update to a 25.10.0 nightly, or wait till 25.10.0 release to be able to connect.
To be more clear… this bug only happens to users who tried to use TrueNAS Connect before we officially announced. The last bug we fixed before launch was a cert generation failure.
I might have pressed the button TrueNAS Connect before the official announcement. I am an early adopter, I see a new button in the UI, I want to know what it does :blush:
Anyway, dropping the table has fixed this issue on my system. Thanks, guys!
Now getting an error after switching to daily…
Error Name: EFAULT
Error Code: 14
Reason: [EFAULT] Failed to revoke account: 400, message=‘Bad Request’, url=‘https://account-service.tys1.truenasconnect.net/v1/accounts/572be5c5-e46b-5346-8827-0cb94a1092aa/systems/57daffd4-096c-5535-8571-30aa0806e838’
Error Class: CallError
Trace: Traceback (most recent call last):
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py”, line 376, in process_method_call
result = await method.call(app, id_, params)
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py”, line 57, in call
result = await self.middleware.call_with_audit(self.name, self.serviceobj, methodobj, params, app,
message_id=id_)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 997, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
audit_callback=audit_callback_messages.append, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 821, in _call
File “/usr/lib/python3/dist-packages/middlewared/service/config_service.py”, line 100, in update
rv = await self.middleware._call(
f’{self._config.namespace}.update’, self, self.do_update, [data], app=app, message_id=message_id,
File “/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py”, line 138, in wrapped
result = await func(*args)
File “/usr/lib/python3/dist-packages/middlewared/plugins/truenas_connect/update.py”, line 151, in do_update
await self.unset_registration_details()
File “/usr/lib/python3/dist-packages/middlewared/plugins/truenas_connect/update.py”, line 274, in unset_registration_details
raise CallError(f’Failed to revoke account: {response[“error”]}')
middlewared.service_exception.CallError: [EFAULT] Failed to revoke account: 400, message=‘Bad Request’, url=‘https://account-service.tys1.truenasconnect.net/v1/accounts/572be5c5-e46b-5346-8827-0cb94a1092aa/systems/57daffd4-096c-5535-8571-30aa0806e838’
Did you report a bug in TrueNAS Connect WebUI?
We’d like to know specific daily/nightly and what version it came from.
26.04.0-MASTER-20251108-020646 - Halfmoon
Thanks for reporting, but until BETA, we expect issues like this.
The developers have a huge list to work through.
