When checking for updates: The network connection was closed or timed out. Try again later
Current version: TrueNAS® Community Edition 25.10.1.
When checking for an update, I get: Network connection was closed or timed out. Try again later.
What went wrong?
Trace:
  File "/usr/lib/python3/dist-packages/aiohttp/client.py", line 770, in _request
    resp = await handler(req)
  File "/usr/lib/python3/dist-packages/aiohttp/client.py", line 725, in _connect_and_send_request
    conn = await self._connector.connect(
  File "/usr/lib/python3/dist-packages/aiohttp/connector.py", line 642, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/lib/python3/dist-packages/aiohttp/connector.py", line 1209, in _create_connection
    _, proto = await self._create_direct_connection(req, traces, timeout)
  File "/usr/lib/python3/dist-packages/aiohttp/connector.py", line 1550, in _create_direct_connection
    transp, proto = await self._wrap_create_connection(
  File "/usr/lib/python3/dist-packages/aiohttp/connector.py", line 1283, in _wrap_create_connection
    return await self._loop.create_connection(*args, **kwargs, sock=sock)
  File "/usr/lib/python3.11/asyncio/base_events.py", line 1113, in create_connection
    transport, protocol = await self._create_connection_transport(
  File "/usr/lib/python3.11/asyncio/base_events.py", line 1146, in _create_connection_transport
    await waiter
asyncio.exceptions.CancelledError
The above exception was the direct cause of the following exception:
  File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/trains.py", line 30, in fetch
    async with client.get(url) as resp:
  File "/usr/lib/python3/dist-packages/aiohttp/client.py", line 1488, in __aenter__
    self._resp: _RetType = await self._coro
  File "/usr/lib/python3/dist-packages/aiohttp/client.py", line 622, in _request
    with timer:
  File "/usr/lib/python3/dist-packages/aiohttp/helpers.py", line 685, in __exit__
    raise asyncio.TimeoutError from exc_val
TimeoutError
  File "/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py", line 360, in process_method_call
    result = await method.call(app, id_, params)
  File "/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py", line 57, in call
    result = await self.middleware.call_with_audit(self.name, self.serviceobj, methodobj, params, app,
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 954, in call_with_audit
    result = await self._call(method, serviceobj, methodobj, params, app=app,
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 771, in _call
  File "/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py", line 108, in wrapped
    result = await func(*args)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/profile_.py", line 65, in profile_choices
    current_profile = UpdateProfiles[await self.current_version_profile()]
  File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/profile_.py", line 84, in current_version_profile
    current_train_releases = await self.middleware.call('update.get_train_releases', manifest['train'])
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1051, in call
    return await self._call(
  File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/trains.py", line 69, in get_train_releases
    return await self.fetch(f"{self.update_srv}/{name}/releases.json")
  File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/trains.py", line 40, in fetch
    raise CallError('Connection timeout while fetching update manifest', errno.ETIMEDOUT)
middlewared.service_exception.CallError: [ETIMEDOUT] Connection timeout while fetching update manifest
Thank you in advance for your help.
Hmm. Didn’t do anything. And it worked.
Temporary rift in the Matrix. :detective:
Did you happen to see two identical cats pass by your house?
I was hoping there was an actual solution. I have had this issue since upgrading to the HalfMoon nightly from 15 Feb. (I had to use it, because 25.10.1 wouldn’t read my zpool that I was bringing over from FreeBSD Release 15.0 and OpenZFS 2.4.0 RC1…)
Are you on a bare metal install of TrueNAS 26? Use Report a Bug on upper right of forum and submit a Debug Dump to your ticket. The users that are testing 26 as a VM get their tickets closed because of not being on bare metal.
I have had the update problem after 2026-02-10 (works), all others nightly updates after fail update.
I would make sure to have excellent backups of your data since you are running a Nightly version
This is on bare metal. Specifically:
Supermicro X10SLH-F mainboard
Xeon E3-1275v3 / 32 GiB ECC.
480G SSD boot drive
1TB SSD data pool 1
6x8TB spinny SAS drives for bulk storage.
I’ll submit a report later this morning, thanks.
Tried to create a bug report, and even that is having issues: DNS issues at TrueNAS?
% ping support-proxy.truenas.com
ping: support-proxy.truenas.com: Name or service not known
% nslookup support-proxy.truenas.com
Server:         192.168.1.1
Address:        192.168.1.1#53
Non-authoritative answer:
*** Can't find support-proxy.truenas.com: No answer
% nslookup support-proxy.truenas.com 8.8.8.8
Server:         8.8.8.8
Address:        8.8.8.8#53
% nslookup support-proxy.truenas.com 1.1.1.1
Server:         1.1.1.1
Address:        1.1.1.1#53
% ping google.com
PING google.com (64.233.185.102) 56(84) bytes of data.
64 bytes from yb-in-f102.1e100.net (64.233.185.102): icmp_seq=1 ttl=106 time=22.3 ms
^C
--- google.com ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 22.292/22.292/22.292/0.000 ms
Did you click on the Report a Bug on the upper right of the forum?
Yep, and now it’s working anyway. Despite still not being able to resolve the above host.
I dont want to attempt to submit a bug report for that, however.
Did you happen to see two identical posts in the same thread?
Wound up trying to a report for something else, and that still fails, so I filed a report on Jira. My first time using Jira. I’m not exactly impressed. But maybe it’s because my current desktop is a Raspberry Pi 5. But holy hell was it slow.
I have the same issue. Network connection was closed or timed out. Try again later. But my internet connection is fine and nothing is blocked from my side…
