Upgrade from CE 25.04.2.6 to 25.10.3
i have CE Version 25.04.2.6
Hi, I’d like to update to version 25.10.3 , but when I click on update, I get this error message.
Can you help me?
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 1098, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs, sock=sock)
File “/usr/lib/python3.11/asyncio/base_events.py”, line 1113, in create_connection
transport, protocol = await self._create_connection_transport(
File “/usr/lib/python3.11/asyncio/base_events.py”, line 1146, in _create_connection_transport
await waiter
File “/usr/lib/python3.11/asyncio/sslproto.py”, line 578, in _on_handshake_complete
raise handshake_exc
File “/usr/lib/python3.11/asyncio/sslproto.py”, line 560, in _do_handshake
self._sslobj.do_handshake()
File “/usr/lib/python3.11/ssl.py”, line 979, in do_handshake
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate (_ssl.c:1006)
The above exception was the direct cause of the following exception:
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py”, line 323, in process_method_call
result = await method.call(app, params)
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py”, line 52, in call
result = await self.middleware.call_with_audit(self.name, self.serviceobj, methodobj, params, app)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 911, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 731, in _call
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 624, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 178, in nf
return func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/plugins/update.py”, line 105, in get_trains
trains_data = self.middleware.call_sync(‘update.get_trains_data’)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1030, in call_sync
return self.run_coroutine(methodobj(*prepared_call.args))
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1070, in run_coroutine
return fut.result()
File “/usr/lib/python3.11/concurrent/futures/_base.py”, line 449, in result
return self.__get_result()
File “/usr/lib/python3.11/concurrent/futures/_base.py”, line 401, in _get_result
raise self.exception
File "/usr/lib/python3/dist-packages/middlewared/plugins/update
/trains.py", line 63, in get_trains_data
**(await self.fetch(f"{self.update_srv}/trains.json"))
File “/usr/lib/python3/dist-packages/middlewared/plugins/update/trains.py”, line 25, in fetch
async with client.get(url) as resp:
File “/usr/lib/python3/dist-packages/aiohttp/client.py”, line 1359, in aenter
self._resp: _RetType = await self._coro
File “/usr/lib/python3/dist-packages/aiohttp/client.py”, line 663, in _request
conn = await self._connector.connect(
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 563, in connect
proto = await self._create_connection(req, traces, timeout)
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 1032, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 1366, in _create_direct_connection
raise last_exc
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 1335, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 1100, in _wrap_create_connection
raise ClientConnectorCertificateError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorCertificateError: Cannot connect to host update.ixsystems.com:443 ssl:True [SSLCertVerificationError: (1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate (_ssl.c:1006)’)]
The error message you’re getting indicates that update.ixsystems.com is serving a self-signed certificate, but when I browse to that site, it’s serving a cert from Google Trust Services issued 13 Mar 26 and expiring 11 Jun 26. Are you behind a firewall that does TLS inspection, by any chance? What happens if you try to open that site in your browser?
I finally managed to update.
When I tried to update again, the error appeared intermittently. After trying several times, I was able to do it.
Strange.
If I try to access the updae.ixsystems.comt with the Chrome browser, the PfSense firewall blocks access.
That’s likely your problem, then–Storj, which iX uses as their CDN, gets flagged for malware by lots of DNS-based blocklists. iX should probably reconsider their use of Storj for this purpose.
