Hello All,
I have TrueNAS Scale running on a VM and I want to use it as an iSCSI Initiator. I did the usual thing of discovering the target and then connecting to it via the terminal/shell. The Target was connected and the disk also showed up when the command ‘lsblk’ was used.
However I was not able to see this disk while creating the storage pool.
I tried finding the solution on forums, but didn’t found any some even suggesting that this can’t be done.
Has someone tried this and was successful in using TrueNAS as an iSCSI Initiator, if yes please share the process and if this is really not possible what is stopping this from happening.
Any suggestions are welcomed.
Thanks in advance.
