Valutwarden install guide on Scale?
I’m looking to self-host my password manager and not very familiar with how to configure everything. Right now, I’m getting an installation failed error when I have the Certificate ID set to the truenas default, and host paths for both Data and Postgress storage.
Does anyone know of a guide on how to set all this up?
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 509, in run
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 556, in __run_body
    rv = await self.middleware.run_in_thread(self.method, *args)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1367, in run_in_thread
    return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1364, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 268, in nf
    rv = func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 55, in nf
    res = f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 183, in nf
    return func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 203, in do_create
    return self.create_internal(job, app_name, version, data['values'], complete_app_details)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 248, in create_internal
    raise e from None
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 241, in create_internal
    compose_action(app_name, version, 'up', force_recreate=True, remove_orphans=True)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/compose_utils.py", line 61, in compose_action
    raise CallError(err_msg)
middlewared.service_exception.CallError: [EFAULT] Failed 'up' action for 'vaultwarden' app. Please check /var/log/app_lifecycle.log for more details
I’d do what it suggests and check /var/log/app_lifecycle.log (obligatory note that I have no idea why it doesn’t just provide the latest log from this file).
Give this a watch, might be helpful:
I did see that video and was hoping there would be a way to automatically backup the vaults.
Automatic backups are going to work the exact same way for any other data.
If you’ve mounted it on a host path, you can create a replication task, cloud sync task, rsync task - whatever. It’s up to you.
As an example, I run vaultwarden on a pair of NVMEs, but I replicate the data daily to my much larger pool as a replication task (and also perform offsite backups manually). If something were to happen it would be as simple as replicating the data back.
